Mac System Plugin: Some Apps recognized, some not so much
Posted: Fri Dec 16, 2016 10:42 am
Mac System Plugin 2.0.1 on Yosemite
I see a lot of potential for this plugin, but I'm running into issues with setup.
My goal is to use the plugin to monitor the 4 other applications on my indigo computer that have indigo responsibilities: Airfoil, Growl, Plex, RemoteSight.
End goal is to have triggers to re-open an application if it suddenly quits.
Secondary goal is to have an action group to turn on/off Plex whenever I'm updating my Alexa-Hue plugin (Port conflict).
All four of my applications are running on that computer, but the plugin is only showing Plex and RemoteSight as running.
I can tell the plugin is communicating with Airfoil and Growl.... If I send a "Turn On" command to either, an application window will pop-up... but the status still shows "Off". If I close the programs (through the program) then turn them on via plugin... they will turn on, but the status still shows as "off".
Without status, I can't do triggers to re-start an application if it randomly quits.
Any assistance would be helpful.
