Shared Device
Sat Sep 26, 2015 11:40 pm
Coolcaper offline
Shared Device
Thanks for the plugin. I am trying it out at the moment for mounting a shared NAS device. Is there a particular way I need to set it up to mount? I have set it up as a Disk Volume but no luck.
Wed Apr 27, 2016 3:27 am
Asconasny offline
Re: Shared Device
was this issue resolved? I'm trying to figure out the same. Have a NAS and would like the volume to mount and dismount with this plugin.
regards
Asconasny
Sat Apr 30, 2016 3:37 pm
Coolcaper offline
Re: Shared Device
Nope and haven't seen the developer active here for a while either.
Sat Apr 30, 2016 4:02 pm
Different Computers offline
Re: Shared Device
There's a pretty simple applescript that would do this, and then you could use Indigo to fire off the Applescript.
set diskName to "YourDiskNameHere"
tell application "Finder"
 if disk diskName exists then
  eject disk diskName
 else
  tell current application
   set deviceLine to (do shell script "diskutil list | grep \"" & diskName & "\" | awk '{ print $NF }' }'")
   if deviceLine = "" then
    display dialog "The disk \"" & diskName & "\" cannot be found." buttons {"OK"} default button 1 with title "Error" with icon caution
   end if
   set foundDisks to paragraphs of deviceLine
   repeat with i from 1 to number of items in foundDisks
    set this_item to item i of foundDisks
    if this_item contains "disk" then
     do shell script "diskutil mountDisk /dev/" & this_item
    end if
   end repeat
  end tell
 end if
end tell
SmartThings refugee & happy to be on Indigo now.
Mac OS 10.12.6 on a i5 MBP running Harmony Hub, Hue, DomoPad, Dynamic URL, EPS Device Extensions, HomeBridge Buddy, Smart Dimmer, MatplotLib, Plex, Scale Adapters, uniFAP, Wunderground, Airfoil Pro.
Thu Sep 22, 2016 12:18 pm
Coolcaper offline
Re: Shared Device
Thanks for that! Haven't been active on here either lol....life as usual :|
Mon Dec 26, 2016 1:34 pm
kmarkley offline
Re: Shared Device
I have forked bip.phillipe's plugin to work with local network shares. There is a new device type to accomplish this.
Tested on my system with afp and smb shares, but should theoretically also work for nfs, ftp, and webdav.
This is a bit of a butcher's job and there are large swaths of this plugin I do not understand. Right now it works for me, but if it breaks you should probably revert to the official version.
Download here: https://github.com/kmarkley/Indigo-Domo ... ses/latest
Mon Dec 26, 2016 6:04 pm
Asconasny offline
Re: Shared Device
Great! thank you for this
work good on my system with smb shares
Asconasny
