[Mac System] Should status requests work for App devices?
Sun May 03, 2015 1:14 pm
Just installed this plugin and created an application device for AirFoil.
AirFoil wasn't already running, so I 'Turned On' the device, which correctly runs AirFoil - but the status still shows it as not running, even after a Status Request.
Peter
Fri May 08, 2015 1:28 pm
Re: [Mac System] Should status requests work for App devices
Bump?
Thu May 28, 2015 1:43 pm
bip.philippe offline
I have worked the last week on an enhanced version of the plug-in that will offer new devices to manage special applications as helpers and daemons.
I a going to publish it this week-end.
I think that Airfoil is launching either an helper or a daemon. I am going to investigate this when publishing the new version.
Sincerely,
Tue Jun 02, 2015 1:57 pm
From the test I made with the Airfoil trial version you can now declare Airfoil as an application device and this should word.
Let me know,
Tue Jun 02, 2015 4:02 pm
I'll have a look - I didn't have chance to commit to it if something went wrong, so I held off on the update as it's working ok at moment, the bits that work.
Wed Jun 03, 2015 10:05 am
I understand how airfoil can be critical.
If you want to secure things, you could set the actual plug-in configuration to the upper debug level, do a status request, and send me the log.
Regards,
