Powerview Plugin issue
Sat Jun 06, 2020 3:23 pm
alang_94526 offline
I have installed Eric Hodel's V1.0.0 Powerview plugin but it doesn't seem to call the API in the hub from the "activateScene" command in powerview.py.
I see the correct scene ID from the debugLog statement in python.py but it seems the call is never made.
In Safari, I can issue the API scenes commands and they work fine.
When I start the plugin, I get the following errors. Not sure if these are relevant to this issue.
Jun 6, 2020 at 2:21:36 PM
Reloading plugin "PowerView 1.0.0"
Stopping plugin "PowerView 1.0.0" (pid 7922)
Stopped plugin "PowerView 1.0.0"
Starting plugin "PowerView 1.0.0" (pid 8072)
Started plugin "PowerView 1.0.0"
PowerView Debug Updating shade 192.168.0.26:48295
PowerView Error exception in deviceStartComm(Door): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:64316
PowerView Error exception in deviceStartComm(Master 1): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:43728
PowerView Error exception in deviceStartComm(Master 2): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:15484
PowerView Error exception in deviceStartComm(No shade Connected To This): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:16881
PowerView Error exception in deviceStartComm(Shade 1): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:31651
PowerView Error exception in deviceStartComm(Shade 2): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:17365
Error device "Shade 3" state key signalStrength not defined (ignoring update request)
PowerView Error exception in deviceStartComm(Shade 3): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:62458
PowerView Error exception in deviceStartComm(Shade 4): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:9307
PowerView Error exception in deviceStartComm(Shade 5): state value type must be bool, int, real, or string
PowerView Debug Updating shade 192.168.0.26:44329
PowerView Error exception in deviceStartComm(Shade 6): state value type must be bool, int, real, or string
All the other setup/config features work as expected.
All shade functions work perfectly through the Powerview App and Siri
Alan
Sat Jun 06, 2020 4:19 pm
alang_94526 offline
Re: Powerview Plugin issue
Never Mind. I figured out the issue. There is a case sensitivity in the API for scene ID.
sceneid should be sceneId.
Instead of:
def activateScene(self, hubHostname, sceneId):
activateSceneUrl = \
'http://%s/api/scenes?sceneid=%s' % (hubHostname, sceneId)
self.__GET(activateSceneUrl)
It should be:
'http://%s/api/scenes?sceneId=%s' % (hubHostname, sceneId)
Works now.
I'm guessing the SW changed somewhere in the hub
Sun Sep 27, 2020 8:01 pm
7rdr7 offline
Hi Allan,
How did you resolve the issue? I'm experiencing the same issue. Did you modify the code?
Thanks, Ron
Sun Sep 27, 2020 8:47 pm
7rdr7 offline
Made the change in the plugin code. I could only find a single instance, but I still have the same issue. Is it still working for you?
Fri Oct 02, 2020 8:12 am
7rdr7 offline
Thanks @chase, Appreciate the fix!
Fri Sep 17, 2021 12:47 am
dawson1331 offline
I believe that the PowerView plugin in the Indigo Plugin Store is an old version/link (2017). This version will not activate scenes. The latest version on GitHub (2018) works. Capitalization issue.
Bill
Fri Sep 17, 2021 12:04 pm
Unfortunately, the developer never created a Github release for any updates. The only one there is from 12/2017 which is what's in the store. He'll need to create a new release in Github then update it in the store for the store to automatically pick up the later version.
