APC Power Distribution Unit (PDU) Plugin Added
Wed Sep 21, 2022 5:42 am
Re: APC Power Distribution Unit (PDU) Plugin Added
Just FYI I've finally had time to sit down and get this setup. It's all working great, although as you said it'll be best if the SNMP Trap functions were added as the states are often out of sync with the actual state now, but at least it's working as I wanted (really handy for forcing a reboot of my router/switch... the problem was if I just told indigo to turn off, then turn back on after 15 seconds because communication with the PDU was broken it couldn't switch back on.. with this it's all internal so does it correctly :D )
Wed Sep 28, 2022 8:49 am
anyone offline
Glad to hear the plugin is working well for you and thanks for sharing how you implement the "Use OFF for Reboot" feature, I have run into that problem.
I typically configure devices that should remain ON with that setting, to help prevent accidentally powering them off.
I am making progress getting the SNMP Trap functionality working.
