StandardError detected
Sat Dec 02, 2017 2:20 pm
petematheson offline
I'm getting this on regular occasions. Any ideas?
Autolog Smappee Error StandardError detected in 'handleSmappeeResponse'. Line '1662' has error=''Plugin' object has no attribute 'consumptionLast''
Autolog Smappee Error Response from Smappee was:'[{"serviceLocationId": 21040,"consumptions": []}]'
Sun Dec 03, 2017 6:51 am
Re: StandardError detected
Please download the latest version of the Smappee Plugin in the Indigo Plugin Store.
Hopefully that will resolve the issue, if not at least we will be working on a common base version to fix the problem. :)
Sun Dec 03, 2017 1:48 pm
Ah thanks.
It's downloaded a new version, and not upgraded the old version FYI. Is that right?
I've removed the old plugin and installed this one, and now I'm getting:
Error creating debug folder - please correct error.
..when I try and save all of the initial configuration info.
Mon Dec 04, 2017 5:03 am
Looks like it could be a permissions problem (I have just tested a new install). :|
Th plugin obviously isn't as robust as it needs to be. :oops:
The fix is to do the following: In the Configure Smappee dialogue, tick Show logging Options and specify the Debug logging folder as:
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.autologplugin.indigoplugin.smappeecontroller
Click Save and then reload the the plugin.
You should then be able to define your Smappee devices.
