Replacing ceiling fans with automated
Posted: Wed Aug 12, 2020 10:00 pm
I have two manual wall controlled ceiling fans in two different rooms, one with a light and the other without. The light fan has two side by side wall switches; one toggle for the light and the other a 3-speed slider for the fan. The other fan with just a 3-speed slider.
I would like to replace both fans with a light/fan model but don't really know the recommended way or switch to use to control both fan and light using Indigo. It seems there are so many switch choices. And if I end up with a fan that has already has wireless control, can I use both the wireless remote that comes with the fan as well as an automated switch? I do want to retain the use of a wall switch. I use Insteon for lighting but not adverse to using Z-Wave as I have an Aeotec Z-Stick I've not used yet.
I would really appreciate any help in getting started with this project including what to look for in fans and switches.
Thank you so much!
Thank you so much!
