Script need it
Sun May 03, 2020 3:29 am
Kamen offline
Script need it
Hi could someone help me to write a script for me? I need to execute this via script.
local http = require("socket.http")
local ltn12 = require("ltn12")
local path =  "http://IP:47147/api/v1/runactivity"
local payload = [[ {"activity_uuid":"CBD5ADC7-1E1A-4D28-AD0A-36518EE4785B"} ]]
local response_body = { }
local res, code, response_headers, status = http.request
   url = path,
   method = "POST",
   headers =
     ["Content-Type"] = "application/json",
     ["Content-Length"] = payload:len()
   source = ltn12.source.string(payload),
   sink = ltn12.sink.table(response_body)
It comes from Vera plus Luup code. Thanks in advance!
Sun May 03, 2020 4:35 am
Re: Script need it
Can you explain what the script does and what you're trying to accomplish? It looks like you're grabbing data from an API, but I'm not clear on what you're doing with that data once you request it. This is usually very easy to do in Python.
(I don't know LUUP, and it's one of the reasons I left Vera.)
Tue May 05, 2020 2:05 am
Kamen offline
Script need it
Hi I'm using a app called simple control remote for my AV equipment and it is compatible with Indigo server. The sinking of all devices is done from a Hub running on a Mac mini so basically with this script I need to send a comment to the Hub to start activity.watch TV. http://IP:47147/api/v1/runactivity"
{"activity_uuid":"CBD5ADC7-1E1A-4D28-AD0A-36518EE4785B"} I hope that helps. Thank you very much!
Tue May 05, 2020 3:39 am
Re: Script need it
import requests
payload = {"activity_uuid":"CBD5ADC7-1E1A-4D28-AD0A-36518EE4785B"}
requests.post("http://IP:47147/api/v1/runactivity", data=payload)
Tue May 05, 2020 4:39 am
Re: Script need it
See? So much easier than LUUP.
Wed May 06, 2020 2:40 am
Kamen offline
Re: Script need it
Thank you very much for your help! But is not working!
Wed May 06, 2020 2:47 am
Re: Script need it
Log output? Error messages?
Also, did you edit the script to put in the actual IP address of the device you're sending that to? You just had "IP" in the sample script. That needs to be changed to the actual IP address.
Wed May 06, 2020 3:20 am
Kamen offline
Re: Script need it
Hi thank you for your reply yes I did put the correct IP address, no error message!
Wed May 06, 2020 7:40 am
Re: Script need it
I think maybe requests needs to be told the payload is json:
 import requests
requests.post("http://IP:47147/api/v1/runactivity", json=payload)
note that the data parameter from the previous script was changed to json - that's the only change.
Wed May 06, 2020 1:01 pm
Kamen offline
Re: Script need it
:D :D :D Thank you very much it works perfectly now! I really appreciate your help!
