Outdoor Motion Sensor best practices and recommendations
Mon Aug 05, 2019 9:06 am
eightball offline
I'm trying to setup some outdoor motion sensors and would love advice on best practices/model recommendations.
I have a mostly insteon based system but recently added z-wave to the mix.
Sensors I have:
2 - insteon sensors (1 old, 1 new)
3 - homeseer sensors attached to flood lights
In a perfect world:
1. These sensors would first trigger floodlights on the corresponding side of my house then trigger the remaining flood lights (i.e. north side motion detected: north triggers, pause, south, east, west trigger)
2. These sensors would work in tandem with insteon switches connected to these floodlights so they could be both bypassed and run at lower levels for regular illumination.
3. Ideally, these sensors would be hardwired (at least the Homeseer ones)
Questions:
1. Best practices generally?
2. Can I use both a dimmer and the motion sensor together? If so what's the best way to do that?
3. Can they be hardwired with a dimmer before the floodlight? Dimmer - sensor - light? Or do I need to have the sensor working independently of the dimmer? So - sensor triggers dimmer.
4. Other brand recommendations?
5. Experience with insteon sensors outdoors? These would be under eaves in southern California.
Thanks for any help/guidance.
Anthony
Tue Aug 13, 2019 9:13 am
johnpolasek offline
Re: Outdoor Motion Sensor best practices and recommendations
I guess if nobody else has any information to share, I'll drop in my nickles worth; In an outside motion detector, you're going to get lots of false alarms; whether it's PIR or optical, the current state of the art can't reliably differentiate between tree limbs moving in front of a sun heated patch of ground or a 30 lb pet dog near the sensor from a human being sneaking around with a crowbar. And in terms of getting a signal back to Indigo, it really depends on how rf resistant your walls are; Inside, I've found that almost any Z-wave sensor has better response and longer battery life than the Insteons, but their signals have a rough time getting through the walls of my super insulated foil backed energy efficient window house. Absent some kind of Z-wave to wired technology bridge (which I'd love to see somebody build), if I ever did put up external motion sensors, I'd have to go with insteons since I could also plug in an outdoor rated dual band insteon plugin switch that would pass the signals onto the power line.
As far as where to put them, I'd guess common sense rules; as far back under the eves or under the porch, and not where where they would be watching any ceiling fans you have installed...
Sat Aug 17, 2019 5:21 pm
johnfdl offline
I personally have had good experience with break-beam to detect visitors/intruders. I posted my solution here: viewtopic.php?p=170976#p170976
Note, the Dakota 2500 system I've used is being replaced by Dakota 4000 system. I can't speak to if that system can support my setup.
Like John who posted above, other motion sensors have too many false alarms or interference issues for my level of comfort. My break beams have almost no false alarms and I've been using them for years (though they must be properly aligned and get enough sun for the solar panels to recharge the batteries). I realize this is likely well outside the scope (and perhaps price tag) of what you are seeking, but thought I'd throw it out there.
Mon Aug 19, 2019 6:51 am
johnpolasek offline
The (current) problem with the 4000 series is that it has no relays that can be tied into a contact closure detector (Z-wave window sensor, insteon EZIO, Pibeacon rPi, alarm panel, etc); it's audio only. Dakota has been promising that there will be a version of the receiver with relays forthcoming in "early summer 2019", but haven't demonstrated or listed it on their website as of a week ago. The other problem with beam break detectors is that they cover only a single line; given that deer tend to use my driveway as a game trail, I went with the Dakota 2500 magnetic sensor for detecting vehicles only. But, of course that won't detect pedestrians unless they are carrying a LOT of metal. And at present, I am looking into a company called "safety Technology International" which has a whole series of devices similar to the Dakotas with an 8 relay board available. I haven't looked for a beam break in their product line because I was only interested in a new mag sensor for my mother's house.
Mon Aug 19, 2019 7:31 pm
johnfdl offline
Thanks John. Agreed there is no perfect solution, but for me, the break beam is as close as I can get. I am trying to detect either a car or a person so magnetic detectors won't work and motion sensors have too many false alarms. Yes, the break beam will trigger if a deer crosses it's path (I mount it a few feet off the ground so opossums and racoons won't trigger it), but for my use it works. Keep in mind, I am just looking to trigger the camera feed on my TVs when the break beam is triggered. So if it's a deer, that is fine....I will see that. I think you can still get the 2500 series which has the relay connections (required for my solution), but that may not last long.
If I only wanted to detect vehicles, then I agree a mag detector is the way to go.
Tue Aug 20, 2019 5:19 am
johnpolasek offline
FYI
You can get most of the 2500 Transmitters (I assume they are getting rid of stock) but as of about 3 months ago, the 2500 RECEIVERS (and any bundle including a receiver) were out of stock, no restock data available at every online supplier I could find. And still waiting for the 4000 receiver with relays. Dakota also has a sensor suite for their MURS one mile wireless intercom system that has ONE relay in it.
And the mag sensor works for me because the house is a quarter mile off the road, and nobody wants to walk that far. The security cameras are motion triggered (mostly waving leaves), but the sensor sends me a phone push if the sensor trips while none of the BLE beacons the family carry are home (so far just delivery guys).
Tue Aug 20, 2019 8:41 am
ELWOOD offline
I have been using Optex duel beam inferred detectors for 20 years with great success. My original was a hard wired version but now am using there battery powered wireless version. The detector is mounted about 3 1/2 to 4 feet above the ground. with duel infrared detectors one is set to be parallel to the ground the second is aimed at a downward angle and is adjustable. Both beams must be tripped before you get an activation. So animals under the 4 foot mounting hight are not detected. The down looking beam is adjustable to set the range the detector see's so at max it is about 40 feet, by setting an angle lower the range can be reduced to about 15 feet. Battery life id better than a year. You need to add your own transmitter so it will work with any wireless alarm. I an using a Honeywell vista 125 panel and the AD2USB alarm plugin. The detectors I have been using are there older VX detectors the newer version are the VXI.
Optex also makes break beam detectors that are also wireless. Here is a link to Optex https://www.optexamerica.com/security-products?f%5B0%5D=field_product_wire%3ABattery%20Powered&page=1
Does look like you can get them on Amazon or just search the part number.
Elwood
Wed Aug 21, 2019 3:34 am
agame offline
agree with comments on limitations with outdoor sensors. wombats, wind on plants,, and at night giant moths and bats continually set off a PIR based sensor
(use a microwave-based sensor rather than an infrared PIR for somewhat better results).
the recent upgrade to Security Spy (adding local human and vehicle recognition capability) has revolutionised outdoor recognition for me...much superior to beam break sensors which I agree are the next best thing.
Sat Sep 21, 2019 11:58 am
hamw offline
I have not been able to successfully integrate motion detectors because of the constant falsing. This includes Smarthome/Insteon. Z-wave and Ademco 5800 PIR series.
The Ademco work pretty well, but I have them set up on a separate partition so that they do not arm when I have the system armed… Otherwise they would set off the alarm. The problem is that after a week they stop registering the individual sensor and only fault the partition:
“ Zone faulted
press * for zone”
I did set up a trigger so that when the panel read out from partition 3 changes to “faulted“ that it executes a trigger, but this either stopped reporting or both the batteries have died in the detectors.
Elwood, I looked up the optex sensors that you posted. These look very promising with the dual PIR/microwave anti-falsing. How have you integrated those? I have run out of hardwire inputs for my panel, but it looks like these could be hardwired into a Phidgets or other I/O board. Or are you bringing them in via RF? If so, how did you do that and how did you set it up so that when you “arm away” that they do not set off the alarm?
Wed Sep 25, 2019 11:09 am
Busta999 offline
I have been trialling the Hue Outdoor Motion Sensor.
Using the Hue Plugin (Nathan's) it has been doing really well.
I was already using a dozen indoor Hue Motion Sensors and they have been absolutely solid and 2years of battery out of a couple of AAAs is really good, they also make very reliable temp sensors too along with luminance (less useful for me)
I mounted it above the garage door facing down the drive.
It 'sees' people walking down the drive very well. It has picked up squirrels and a cat but never had a problem with bushes/plants or trees and there are a lot of them around.
I could turn down the sensitivity, but the false alarms with animals is a rare occurrence.
For giggles I setup Alexa to report 'Drive' then play a sound effector someone walking on gravel whenever the Hue Motion sensor triggers, also did the same for the Ring Doorbell except it says 'Door', both are out loud on the Lounge Alex - quit enough to not be a pain, but enough to register when watch TV/Movie
Thu Sep 26, 2019 6:27 pm
masterblaster offline
I've successfully modulated the sensitivity of z-wave motion sensors to avoid most false positives outdoors, by partially obscuring the IR window with electrical tape.
Fri Sep 27, 2019 3:02 pm
hamw offline
Interesting idea. Could you post a picture or be a little more descriptive? Which brand of Z wave sensor?
Fri Sep 27, 2019 5:04 pm
citysnaps offline
Since I have cameras monitoring outdoor areas I'm interested in protecting, I'm using Security Spy's new AI-based human and vehicle motion detection to trigger various lights and warnings via Indigo.
Human and vehicle detection is not yet perfect, but work *far* better than any PIR sensors and sensor/lights I've tried.
Brad
Urban photoblog: www.citysnaps.net
Sat Oct 12, 2019 7:18 pm
agame offline
I note that with Catalina comes object recognition and iCloud storage of HomeKit-enabled camera feeds.
I guess coupled with the HomeKit Bridge plugin this would create another architecture for smart outdoor event detection. I must say the SecuritySpy/Indigo combo works really smoothly, however.
Sun Oct 13, 2019 2:39 am
siclark offline
I use this.
https://www.texe.com/uk/uploads/Premier ... et_Web.pdf
Only time an animal triggered it was when a cat dropped off a wall directly in front of it and broke both beams at once. Otherwise foxes walking past it never trigger it.
