Leviton 2 and 4 button controllers
Sat Dec 02, 2017 3:01 pm
egclrich offline
New to Indigo and successfully added numerous switches but cannot figure out how to include the following Leviton switches:
VRCZ4
VRCS4
VRCS2
I tried with the network inclusion process as well as with Gen5 Z-stick with no success. If I could get assistance with this it would be much appreciated.
Sun Dec 03, 2017 6:34 am
Re: Leviton 2 and 4 button controllers
Welcome to Indigo - hopefully, we'll be able to get you sorted.
When you say "include" do you mean that you can not get the devices added to the Z-Stick, or that you can not get Indigo to recognize them?
If the former, try excluding them from the controller again and then try to re-include them. You may not be able to configure a full Indigo device for each device, but you should still be able to see them in Indigo.
Are you trying to include them using network-wide inclusion, or are you taking the stick to the device?
Sun Dec 03, 2017 8:32 am
Once you get them included, they’re unlikely to work natively in Indigo but my Scene Controller Plugin should help.
viewtopic.php?t=18147
However although a handful of users have asked about Leviton, and been pointed at my plugin, none have reported back yet so I don’t know if it does work or if I need to facilitate it.
Sun Dec 03, 2017 11:24 am
egclrich offline
I can include them but cannot sync. When I attempt to sync indigo states that device is not reachable. Appreciate the help.
Sat Dec 09, 2017 12:47 pm
If Indigo is saying it isn't reachable, then Indigo probably is not getting a response back from the queries/commands Indigo is sending the module. How far away is the module? Do you have any other Z-Wave modules between your Mac and the Levitons (if so, try re-syncing those first)?
Lastly,, after you perform the sync open the Event Log window and copy/paste its contents into a reply so we can see exactly what is occurring.
Sat Dec 09, 2017 1:06 pm
egclrich offline
After successful inclusion, I attempt to sync and here is the log...
Dec 9, 2017 at 2:05:36 PM
Z-Wave Syncing - started for "074 - Static Scene Controller"
Z-Wave Syncing - retrieved module neighbors list: 8, 9, 10, 11, 12, 13, 14, 17, 18, 20, 22, 34, 49, 64
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "074 - Static Scene Controller". Module might be asleep, or is unreachable.
Sat Dec 09, 2017 1:17 pm
Try turning on Indigo's Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item), then try the sync again. Copy/paste the results from that – it might give us more details as to where it is failing in the sync process.
Sat Dec 09, 2017 3:47 pm
egclrich offline
Apparently I was including incorrectly. For those trying to get these 4 button switches to sync, you must first push the first and third switches until the switch's lights blink amber, THEN go to Indigo and include a new device. Once it includes the device you will see the controller and can sync without issue(I was originally simply trying to do a network inclusion by starting with Indigo then pushing the switch - it included but would not sync). The inclusion process that I described works the same for all Leviton controllers - I was able to do this for single button and 2 button controllers without issue. Appreciate the responses. Hopefully this helps others.
Sun Dec 10, 2017 3:07 am
Great that you got them synced.
Are they working as scene controllers?
Thu Dec 21, 2017 9:43 pm
egclrich offline
Yes. Work without any issue. Thanks.
Thu Feb 08, 2018 11:02 pm
joel.snyder offline
Well, I can report back... I have connected in a VRCZ4-M0Z. It's successfully linked up to Indigo, but Indigo seems to know absolutely nothing about it.
The plugin (downloaded today, so should be most recent) seems to accept that this is a device that it should do something with, and it exposes it as a trigger, with options to select a button ID (no idea what to put there) and then an action. But it doesn't give a dropdown with button ids, and putting in a button number (like 1) doesn't seem to trigger the trigger.
So it's not working, I'm pretty sure. I do see that the plugin gets some event when any button is pressed, but it doesn't actually do anything.
What can I do to help debug?
Joel
Fri Feb 09, 2018 1:57 am
Hi Joel.
I’ll reply now, but you might not get further replies all weekend from me, or sporadic if you do.
Turn on debugging for my plugin (Plugins menu > Zwave Scene Controller > Configure > Debug on) then press a button on your Controller
The Indigo log should give you button ID and action, to put in the trigger.
Let me know what you see in the log, and what happens, with log snippets and/or screenshots if you don’t get anywhere.
Peter
Fri Feb 09, 2018 9:30 am
joel.snyder offline
Peter:
Here is the debug with both Z-Wave on and plugin on.
The first button press is 1-OFF; the second is 4-ON.
Looking at these, I wonder if this controller needs some programming first. It doesn't have a switch embedded, but button 1/ON and 1/OFF definitely does more than buttons 2, 3, 4 ON/OFF.
I don't know if it's relevant, but the time between Z-wave received and plugin debug printout seems to be long, on the order of 2 seconds. Perhaps there's a timer that is firing after incomplete message expected?
Z-Wave Debug RCVD nodeInfoFrame: 01 15 00 49 84 12 0F 02 01 00 85 2D 7C 77 82 73 86 72 91 EF 2B 2C E6
Z-Wave Debug RCVD basicSetState: 01 09 00 04 08 12 03 20 01 00 CA
Z-Wave Debug . . basicSetState: node 018, endpoint None, value 0 (no node dispatch)
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 12 03 20 01 00 C2
Z-Wave Debug RCVD requestReply1: 01 09 00 04 00 12 03 2C 02 00 CD (hex)
Z-Wave Scene Controller Debug -----
Z-Wave Scene Controller Debug Actuator Config Get received:
Z-Wave Scene Controller Debug Raw command: 01 09 00 04 00 12 03 2C 02 00 CD
Z-Wave Scene Controller Debug Node: 18
Z-Wave Scene Controller Debug Scene: 0
Here's a second debug, showing the sequence 1/on, 2/on, 3/on, 4/on, 1/off, 2/off, 3/off, 4/off
Feb 9, 2018 at 8:29:24 AM
Z-Wave Debug RCVD basicSetState: 01 09 00 04 08 12 03 20 01 FF 35
Z-Wave Debug . . basicSetState: node 018, endpoint None, value 255 (no node dispatch)
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 12 03 20 01 FF 3D
Fri Feb 09, 2018 10:09 am
joel.snyder offline
A bit more information I found... It looks like the Zone controller needs to have some programming done before it's going to send non-null events for buttons 2-4. According to a post I found in the home-assistant area (https://community.home-assistant.io/t/h ... lers/36773), one has to associate Scene IDs with each button, and the default is not useful.
I am guessing that this will require some raw Z-Wave code to be sent to the device, so I'm trying to find an API/developer's manual for that. Any pointers from anyone who has worked with this device would be welcome.
Joel (jms@opus1.com)
Sun Feb 11, 2018 3:37 am
Hi Joel.
I’ve already got code in the plugin for associating scenes to buttons, as one of the other manufacturers needs it. However it’s not working great due to poor documentation and implementation by them.
I’ll read what you’ve posted and check if it matches / tweak it accordingly and let you know.
If I don’t get to it this afternoon, it will be another week before I do - it’s Pantomime Time this week!
Peter
