Transfer from smartthings to indigo
Sat Dec 02, 2017 12:18 pm
Tashyface offline
Hi guys, I’m sorry if this has been asked before.
After browsing on fb tesla forum there are folk on there using indigo to control the house and the car. From my understanding you need a plug-in for the tesla, not sure. I’m not computer savvy. Is it easy to go from smartthings to indigo? I’m using zwave, do I need to exclude them from smartthings before I start with indigo. I have no experience with indigo at all, I’m told it is better than smartthings, is this right. Any advise or tips would be appreciated.
Sun Dec 03, 2017 3:43 am
Re: Transfer from smartthings to indigo
Welcome!
There’s a number of folk on here moved from Smartthings to Indigo and most will tell you good things of Indigo.
I seem to recall discussion of a Tesla plugin but it’s not made it into the (brand new) plugin store if it exists. I’m a Leaf driver and there’s a plugin for that.
If your Zwave network is already using a compatible ZStick then in theory you can just plug it into Indigo and start adding the devices without excluding them - though I’m sure folk are usually told you’ll need to exclude/include so maybe there’s something I don’t know about Smartthings that changes this logic.
Sun Dec 03, 2017 6:32 am
Hello!
Here’s the link for the Tesla plugin - can’t say I’ve had the luxury of using it myself (I have a Renault Zoe EV) but certainly other seem to use it successfully:
viewtopic.php?f=182&t=17728&p=150424&hilit=Tesla#p132530
As for the Z Wave stuff yeah I believe you’d have to unpair your existing devices and re pair them with a new Z-Stick that’d work with indigo. How many devices do you have?
Sun Dec 03, 2017 6:38 am
CliveS offline
You can find the Indigo Tesla plugin at http://forums.indigodomo.com/viewtopic.php?f=182&t=17728#p132530 but as I have not won the EuroMillions lottery again this week I have not tried it.
I had a "Smartthings" and could not get on with it, tried several other software products and they were also too complexed for me to grasp until I found Indigo.
It actually worked for me running on a Dell 6420 laptop with Mavericks installed (Hackintosh), that was just over a year ago and now using a 2012 Mac Mini and learning more each day (learning I have a love/hate relationship with python).
The first few months finding your way around is the worst and then gradually it all starts to come together, python is not required as someone usually has a plugin to do most things and if you get stuck then just ask as this is a place were you get friendly, free advice.
CliveS
Sun Dec 03, 2017 7:02 am
Although it's probably not a factor here, I feel compelled to add that Indigo Domotics doesn't guarantee that Indigo will run nor do they guarantee support for installations on non-Apple hardware.
My advice is to start small and work your way up. Stick to the standard Indigo features until you get your footing. You can do a remarkable amount of things when combining the elements of the system--devices, schedules, actions, triggers and variables. As said, adding Python is not necessary, but it does in many respects make the system limitless. (Avoid using AppleScript if possible as that's on the way out.)
I was never on SmartThings. I came to Indigo from MCV Vera and have never looked back.
Mon Dec 04, 2017 2:38 pm
Different Computers offline
I came over from the awful SmartThings and would be happy to discuss the process. The biggest thing I made a mistake with is that I thought I HAD to use ST to remove each device from ST's z-wave interface, which meant removing each thing from every single smartApp they were in in ST. Really the most tedious thing.
But I found out after that once you have your z-wave interface configured in Indigo, it can exclude ANY device, even ones it has not previously included! This would have turned about 5 hours of ST work into about 15 minutes of Indigo work.
The other tip I have is that the ST forums are the best place to get rid of Zigbee sensors. You might even be able to straight up trade them for z-wave devices. I did.
