Not a good start, need to understand a working system.
Tue Nov 14, 2017 9:05 pm
aauno offline
Re: Not a good start, need to understand a working system.
It has synced. :D :D :D
Many thanks for all your help and encouragement. Now I'll do some reading to see how to trigger the light when the door is opened..
Tue Nov 14, 2017 9:19 pm
aauno offline
I have a door sensor turning on and off the laundry room light. :D :D
That's enough for tonight. Tomorrow I tackle my Lutron Caseta lights which have a smart bridge.
Wed Nov 15, 2017 9:58 am
Different Computers offline
Once you've got your head around these basics that you've now got, things will really start clicking into place. Every now and then I get a mind expansion feeling as I play with some feature, and suddenly a whole new level of capability and possibility opens up.
For your Caseta stuff, I think you need this plugin. viewtopic.php?f=134&t=10806&start=180&hilit=Caseta
But I'm unsure, as I don't use it and have no Lutron stuff in my set up.
Wed Nov 15, 2017 12:16 pm
siclark offline
Welcome from Vera. It took me a few weeks to get my head round the change in logic for triggering actions etc from Vera but love it now.
Fri Nov 17, 2017 8:36 pm
aauno offline
It's starting to become interesting. Not sure how to research question, except asking. Current question: I have added the ZWave lock manager plugin, but not sure of getting started with reading the current pins. I will also need to set new pin codes, and then I get to explore all the things the plugin can accomplish.
Fri Nov 17, 2017 8:54 pm
To get the current PINs, create a new Action Group. Add a "Get User PIN" action (under Z-Wave Lock Manager actions) for each user. Start with user 1 and add additional actions for however many user PINs you have in use. Then execute the action group and read the PINs from the Indigo log.
To set new PINs, it's basically the same thing. Put the actions in an Action group.
Sat Nov 18, 2017 6:05 pm
aauno offline
After trying to get pins from lock:
Nov 18, 2017, 7:00:45 PM
Action Group Get Pin 1
Action Group Get Pin 2
Action Group Get Pin 3
Action Group Get Pin 4
Action Group Get Pin 5
Action Group Get Pin 6
Z-Wave Lock Manager Requesting PIN for user 1
Z-Wave Debug SENT sendRawZwaveCommand: 01 0A 00 13 04 03 63 02 01 25 11 B5
Z-Wave Error rcvd unexpected bytes (sent ACK): 07 00 13 11 00 00 8B 71
Nov 18, 2017, 7:01:46 PM
Z-Wave Error no ack/nak/busy reply (004) for sendRawZwaveCommand (re-sending)
Z-Wave sent "Mudroom Lock" raw command [63 02 01]
Z-Wave Lock Manager Requesting PIN for user 2
Z-Wave Debug SENT sendRawZwaveCommand: 01 0A 00 13 04 03 63 02 02 25 12 B5
Z-Wave sent "Mudroom Lock" raw command [63 02 02]
Z-Wave Lock Manager Requesting PIN for user 3
Z-Wave Debug SENT sendRawZwaveCommand: 01 0A 00 13 04 03 63 02 03 25 13 B5
Z-Wave Error rcvd incomplete interface packet (skipping): 01 07 00 13 00 00 05 FD
Z-Wave sent "Mudroom Lock" raw command [63 02 03]
Z-Wave Lock Manager Requesting PIN for user 4
Z-Wave Debug SENT sendRawZwaveCommand: 01 0A 00 13 04 03 63 02 04 25 14 B5
Z-Wave sent "Mudroom Lock" raw command [63 02 04]
Z-Wave Lock Manager Requesting PIN for user 5
Z-Wave Debug SENT sendRawZwaveCommand: 01 0A 00 13 04 03 63 02 05 25 15 B5
Z-Wave Error rcvd unexpected bytes (sent ACK): 07 00 13 15 00 00 05 FB
Sat Nov 18, 2017 6:08 pm
aauno offline
What documentation do I read to get better with these actions?
Sat Nov 18, 2017 7:05 pm
Only do one at a time. I think you're confusing the lock trying to send commands to get a bunch at once.
Are you sure this lock works with the Plugin?
Mon Nov 20, 2017 1:52 am
What lock have you got?
I’m the lock manager author so I’ll keep an eye on replies.
Peter
Thu Nov 23, 2017 11:40 pm
mssearch offline
@howartp , do you still have a pin manager in the works or is it released now?
Fri Nov 24, 2017 2:41 am
Basic pin features are published.
The advanced Manager I’ve referred to is still under construction.
Thu Nov 30, 2017 7:44 pm
aauno offline
I got away from configuring for a bit of real life. I have a Kwikset zwave lock.
Nov 30, 2017, 8:48:48 PM
WebServer request to execute action group "Get Pin 1" from 192.168.3.170
Z-Wave Debug SENT sendRawZwaveCommand: 01 0A 00 13 04 03 63 02 01 25 F7 53
Nov 30, 2017, 8:53:59 PM
Error email send connection failed
Error email re-send scheduled in 10 minutes
Nov 30, 2017, 9:03:15 PM
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 03 02 84 07 71
Z-Wave Debug . . nodeAwake: node 003
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 03 02 80 02 25 F8 BB
Z-Wave Error rcvd unexpected bytes (sent ACK): 07 00 13 F8 00 00 11 02
Z-Wave Error rcvd unexpected bytes (sent ACK): 09 00 04 00 03 03 80 03 34 45
