trazanka wrote:Interested to know which system most people are using with Indigo so quick survey, if you use more then one pick your primary:
Zwave Insteon or Other?
Which controller is used with the above?
Z-wave is replacing the original LightwaveRF.
A lot of Hue, mainly under Hue Motion detectors do most of the lights in transit areas, garage, hallway, landing, closet, ensuite, sunroom,utility room and WC etc.
Hue on LightwaveRF remotes with and zwave sockets for night lights.
Zwave sockets controlling kitchen task and mood lighting with zwave motion detector.
Hue in Lounge controlled through timers/Alexa.
Zwave sockets throughout managing / monitoring everything else, ie when loading drop occurs on robot vacuum cleaner/ rechargeable screw drivers/drills, window cleaners etc then turn off socket send iMessage.
Harmony for AV controls.
Plex for TV/Movies/Music.
A pile of temp sensors using RFXCOM which also monitors door bell.
Plus a bunch of Foscams.
Indigo brings all my islands of HA together under one piece of software to rule them all
