Best z-wave "two-wire" switch
Thu Feb 09, 2017 4:48 pm
mundmc offline
Hey all,
Long time Indigo guy here, using Insteon for most of my wall switches.
Alas, my "2-wire" Insteon switches (e.g. no neutral wire needed) have a 50% failure rate at two years, and I hear zwave switches are more reliable.
Question:
1) ARE zwave switches more reliable?
2) Are there any recommended zwave switches that don't require a neutral wire (that aren't special finds on eBay)? I know you can connect the neutral wire from some switches to the the load, though this isn't code, and it can be problematic in other ways.
Thu Feb 09, 2017 8:30 pm
Re: Best z-wave "two-wire" switch
http://www.vesternet.com/resources/appl ... es/apnt-23
http://www.vesternet.com/z-wave-fibaro- ... mer-2-250w
The Fibaro dimmer is the only one I've used; being a dimmer it is able to let a tiny amount of current through even when 'off' which allows it to get its own power, but not enough to light the bulb its connected to.
