Building a smart home in the Costa Rican Rainforest
Mon Jan 25, 2016 10:23 am
captcurrent offline
Re: Building a smart home in the Costa Rican Rainforest
I am in the dutch caribbean we use 50 cycle power here which for me has rendered Insteon useless
Most of my system uses X-10 , old but works I have had MAJOR issues with z-wave range i think from construction techniques
right now I am bout max of 30 feets
good luck
Mon Feb 01, 2016 10:19 am
Coolcaper offline
If going with z wave I would like to suggest to stick to the new zwave plus/gen5 products as their range is much better than first generation stuff. Speaking from experience and kudos on your plan OP!!
Mon Feb 01, 2016 11:05 am
johnpolasek offline
If going with Insteons and starting from scratch, I'd suggest putting micromodules and fanlincs in the light fixtures and going with all keypadlincs in the switchboxes. These will let you control either 5 devices (in the 6 button mode) or 8 devices (in the 8 button mode) and if you get the clear button changesets, you can print out your own labels to stick inside them. When I retrofitted the house I recently bought I ended up with a whole lot of spare places where the original wiring had 3 and 4 switches and I needed only one keypadlinc to control more things than they had originally. And setting up 3 or more keypadlincs to control a single light is extremely easy once you understand how scenes work.
And for security/ wildlife cameras, I've been reasonably pleased with the Ubiquiti bullet cameras and their free Unifi software as long as you are willing to pull cat5 cable from the camera to the router. And you will have to supply external IR or visible spotlights at night, their motion detection is a bit tricky to set up, and you will have to have a bit of expertise with setting up a virtual Linux machine on the mac, all of which might make you choose some of the wireless alternatives that are out there and can talk to the DComplex universal server, but I have had some reliability issues with that one.
Wed Apr 26, 2017 6:37 pm
nexx offline
Is Teptron Move supported in indigo? How to interface distant Move's? (it only supports bluetooth)
Wed Apr 26, 2017 7:44 pm
Different Computers offline
Looks like I'm jumping in late here, but so glad you're considering Indigo!
As a former ST user, it would take me a week to explain how much better is than SmartThings. In particular, if your internet is less than 100%, your ST system will never be solid.
As to your Internet, I recommend Ubiquiti point to point wifi bridges. Hard to be more specific without knowing a lot more about the distance you have to span, but the guys at Ubiquti will be able to help.
Thu Apr 27, 2017 7:10 am
johnpolasek offline
Ubiquiti actually has a tool to figure the p2p signal strength based on the location and height of the towers...
https://airlink.ubnt.com/#/
Thu Apr 27, 2017 10:04 am
I don't see where you mention you want cameras, but I see someone else talking about them, so I thought I'd point out that the Indigo Security Camera plugin available for free will let you manage all your cameras inside of Indigo, possibly saving a good bit of money on any other camera management software you might otherwise need.
