Moving To Indigo
Sat Nov 07, 2015 9:43 pm
Skiman offline
Moving To Indigo
Hi, I am currently using indigo in Trial coming from Home Genie. So far i have found Indigo to work well for my needs.
I have all my devices connected and functioning except one. It is a DHS-LIT-SWW-DHS-02. It is a Double in Wall Switch Relay.
Indigo detects it but it is setting both channels to on when turned on and both channels off when turned off. I appears that it is not
working correctly due to the multi channel. Any assistance would be great. I have included the info from the device:
Z-Wave Indigo Device "Lounge Room Light" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.355
Node ID: 20
Model: Relay Power Switch
Model ID: 11225501
Manufacturer: Digital Home Systems
Manufacturer ID: 0097
Protocol Version: 3.42
Application Version: 1.04
Model Definition Version: 0
Library Type: 6
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v2 25v1 86v1 27v1 2Bv1 2Cv1 72v1 00v1
Multi-Endpoint Types: 1:(10 : 03), 2:(10 : 03)
Multi-Endpoint Classes: 1:[20 27 00 00], 2:[20 27 00 00]
Features: routing, beaming
Neighbors: 1, 17
Associations: - none -
Config Values: - none -
Sun Nov 08, 2015 7:03 am
Re: Moving To Indigo
Hello and welcome. It may very well be that Indigo does not directly support this device (yet.) Indigo has a model where the authors create "device definitions" in order to support various devices. These device definitions are added as updates to the Indigo software are rolled out. There's no guarantee that a device definition will become available for this device (it's a supply and demand thing), but Matt and Jay will certainly note the device you mentioned, and may ask you to submit some more information about it.
Good luck with Indigo, I'm sure you'll love it.
Sun Nov 08, 2015 1:03 pm
Just a note: devices that meet the general Z-Wave specs should work without specific model definitions. Unfortunately, Z-Wave doesn't really specify how multi-button controllers (scenes, multiple loads, etc) should work, so they all work somewhat differently. Annoying, but it means that we have to do a little extra work for each of these types of devices. We'll add this one to the long list of devices to look into for the next major Indigo release.
Sun Nov 08, 2015 2:51 pm
Skiman offline
Thanks for the response. I have found http://www.indigodomo.com/devices/70/ with a similar dhs device. Is multi channel supported in indigo or was this a device specific issue. As i only have one of these i would replace it with one that is supported (multi channel device). Thanks again Great stable reliable product.
Sent from my SM-G900I using Tapatalk
Mon Nov 09, 2015 7:53 pm
Indigo has the ability to send multi-channel commands, but the device definitions for multi-channel devices have to be custom defined by us to work. That is, they don't work out-of-the-box with Indigo and require some development work on our end.
Sat Nov 21, 2015 12:59 am
manwithavan offline
+1 for future support of this device.
Sat Feb 20, 2016 5:58 pm
Hank.wheeler offline
DHS In-Wall Double Switch ... not working correctly.
Any news around support for this Device (DHS-LIT-SWW-DHS-02).
I am having the same issues as the OP.
When Indigo communicates with the device (Relay 1), it controls both Relays together (for both on and off control)
When Indigo communicates with Relay 2, then it correctly controls Relay 2 only.
Are there plans to have this device supported for the next Indigo release?
Thanks.
Mon Feb 22, 2016 10:03 am
Adding support for this is on the feature request list, but we aren't providing updates or time estimates as to when individual hardware models will be supported.
Tue Feb 23, 2016 5:52 am
ok, Thanks for the feedback.
Fri Dec 23, 2016 4:35 pm
I am still having the same issues with this device (DHS-LIT-SWW-DHS-02) ... Indigo controls both relay channels when operating on Relay 1.
I have upgraded to Indigo 7, and did a fresh install of everything (reset Z-Stick) ... but still have the issue with this device? ... not sure why?
Fri Dec 23, 2016 9:40 pm
We still need to create a custom device definition for that module (it didn't make it into 7.0). I believe I know how it needs to be defined, so I'm hopeful it make it into an upcoming minor release.
