[ANSWERED]: Help with FortrezZ water / temp sensor
Tue May 19, 2015 11:12 am
CraftGeek offline
I hav 10 FortrezZ sensors model number WWA-01AA installed. They are all included in the network and properly trip the alarm if a leak is detected.
The manual indicates that they should also report temperature too. None of them do this. In the Indigo device list, they all show 22 C, regardless of the actually temp. I put one in the freezer and I put one in a 50 degree garage. they still say 22 C in the list.
I set the wake up time to 30 minutes. nope.
I looked through the log file and noticed that there has never been a temperature report from any of the sensors. I know there is an option to hide temperature reports from the log, this is NOT set.
On the FortrezZ support site, there is an FAQ where the question was asked about this model of sensor reporting temperature and the answer was
Yes, but only if the controller is set up to request the updated temperature reading when it receives the 'wakeup notification' from the WWA01 / WWA01AA. In order to use the WWA01 / WWA01AA for reporting temperatures that change often, a short wakeup interval time is necessary (with the attendant reduction in battery life).
Does something need to happen on the Indigo side to enable this?
Here is a profile of the sensor:
Indigo Z-Wave Version: 1.0.350
Node ID: 14
Model: Water/Temperature Sensor (WWA01AA)
Model ID: 00530216
Manufacturer: FortrezZ
Manufacturer ID: 0084
Protocol Version: 2.48
Application Version: 2.22
Model Definition Version: 4
Library Type: 6
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 31v1 72v1 9Cv1 9Dv1
Features: routing, battery, beaming, waking
Neighbors: - none -
Associations: 1:[1] 2:[]
Config Values: - none -
Sean
Wed May 20, 2015 12:15 am
Help with FortrezZ water and temp sensor
I'm not sure, but try editing your device and setting it to poll the device every x minutes, instead of the default which is to poll when activity is detected.
(Note that's not the same as setting the wake interval)
Wed May 20, 2015 12:18 am
Re: Help with FortrezZ water and temp sensor
See screenshot.
Wed May 20, 2015 8:37 am
That Status Polling UI isn't shown/available for this FortrezZ module since it is battery operated.
I just modified the device definition for this module to send a temperature sensor request whenever the module wakes up. Email us if you would like to try this updated version.
Wed May 20, 2015 10:57 am
Re: [ANSWERED]: Help with FortrezZ water / temp sensor
Oops :-(
Sat May 23, 2015 10:19 am
CraftGeek offline
Email sent. Just in case you haven't seen it...
Yes! I would love to try the new code. How?
Sean
Sean
Sat May 23, 2015 3:09 pm
Hi Sean,
I didn't see your email come through. Did you send it via the form on our home page? If not, can you try via the form?
Sat May 23, 2015 7:02 pm
CraftGeek offline
Hi Sean,
i clicked the email icon next to your avatar on your post. should have gone straight to you. I will find and use the form on the main (non-forum) page.
Sean
Thu May 28, 2015 8:00 pm
CraftGeek offline
:D Woo Hoo!!!! :P
Matt sent a link to the new code that fixes this and it works GREAT, so far.
:!: Thanks Matt! :!:
Sean
Thu Jun 27, 2019 5:23 am
eme jota ce offline
Matt,
Would it be possible for Indigo to show the battery level of the WWA01AA in the Device Details window, like Indigo does for other battery controlled devices, such as the FGFS111?
The Indigo log does indicate battery level of the WWA01AA.
MJC
Thu Jun 27, 2019 1:06 pm
It should show that currently, I believe. Can you re-sync it (after you wake it) and then copy/paste your Event Log results of the sync into a reply for me? I'd like to see if it is reporting that it supports the battery command class or not. Also include a screen grab of the device details area for me.
