Control page is not updated
Sun Jun 26, 2016 12:23 pm
Mattias offline
I've been running Indigo for some time with success, but only automated. Today I created my first control page, with some light switches.
It works fine to turn on/off the lights from the Control Page, and the icons+server are updated correct. But if I hit a light switch (I have a few built in relays) Indigo (server+control page) is not updated with the status.
So, in Indigo, the light indicates that it's on, but in reality it's not. If I toggle the light from Indigo or the control page, it works but I need to do it two times since the status in indigo is not matching reality.
Is this possible to solve? Have any of you seen this before?
//Mattias
Sun Jun 26, 2016 1:10 pm
Re: Control page is not updated
What kind of device is the switch you're toggling manually? Insteon, Z-wave, X-10?
Sun Jun 26, 2016 1:14 pm
Mattias offline
Zwave, its a qubino 1relay and a philio
Sun Jun 26, 2016 1:20 pm
When you toggle the light using the manual switch, do you see anything about that in the Indigo log?
Sun Jun 26, 2016 1:25 pm
Mattias offline
I just checked, and the log is updated when switching the light switch
Sun Jun 26, 2016 1:28 pm
Mattias offline
No, i checked again and its only the power change i saw in the log, no the On command
Sun Jun 26, 2016 1:29 pm
Post a segment of the log file showing both the switch actions and the UI controlled changes.
Sun Jun 26, 2016 1:52 pm
Mattias offline
So, below is when I switch On / Offvia Indigo UI
26 juni 2016 21:36:43
Z-Wave sent "006 - Entré-inne" off
Z-Wave received "006 - EntréKnapp-ej använd" status update is off
Z-Wave received "006 - EntréKnapp-ej använd" power load to 0.3 W
Z-Wave sent "006 - Entré-inne" on
Z-Wave received "006 - EntréKnapp-ej använd" status update is on
Z-Wave received "006 - EntréKnapp-ej använd" power load to 76.0 W
and when I switch with the wall light switch, nothing happens in the log (but the light turns on/off in reality)
Sun Jun 26, 2016 1:54 pm
So that Z-wave relay isn't reporting status changes to Indigo. There's probably a way to make it do so, but I don't use much Z-wave stuff so I can't help.
Mon Jun 27, 2016 12:13 am
When you edit the device in Indigo, what is the polling set to?
By default it should be "only when activity is detected". I'd be surprised if the Qubinos don't support this.
Let us know what it's set to.
Mon Jun 27, 2016 12:24 am
Ah, looking in the manual, I suspect the associations are wrong.
Go to indigo, interfaces, ZWave, associations.
Choose your device 006 in the first box, then choose Group 1 in the second box.
Do you see the ZWave controller listed?
Now change to Group 4 in the second box - do you see the ZWave controller listed?
Mon Jun 27, 2016 5:37 am
Mattias offline
Great! Suddenly there is hope. I'll test when i'm back from work.
Mon Jun 27, 2016 1:14 pm
Mattias offline
I checked the groups, and in group 1 its associated with 001-indigo zwave interface, and no other group have any associations. I added the same (001-indigo...) to all other groups, but still no status updates when switching the light switch :( I also tested with different polling options, but no good result.
Mon Jun 27, 2016 2:12 pm
You need 001 on group 4 for Qubino.
Remove it from group 1, then add to group 4?
Mon Jun 27, 2016 2:33 pm
Mattias offline
Tested with changing group, but not working. I also have two philio pan04-1 and they have the same issue.
