Thingspeak Plugin
Sat Feb 21, 2015 3:15 pm
Re: Thingspeak Plugin
I didn't even know that you could run your own Thingspeak server.
So, in modifying the plugin, I'm assuming that you changed this:
f = httplib.HTTPConnection("api.thingspeak.com:80")
to this:
f = httplib.HTTPConnection("YOUR_IP_ADDRESS:3000")
Were there any other changes that you needed to make? (It won't be possible for me to be able to test a local server...)
Dave
Sun Feb 22, 2015 9:33 am
BassMint offline
That was the only change I had to make.
I followed the linux install instructions to install on the OS X Lion MBP I have Indigo running on.
I don't like to be dependent to running stuff in the "cloud".
https://gist.github.com/abythell/8225124
that is what I used to install in on the mac. I did not use the script, followed the steps manually.
Sun Feb 22, 2015 11:56 am
Thanks BassMint. I'll have that functionality included in the next version. I think I will have each device use its own IP as you suggested--and may move the upload frequency setting to the device config as well--which would allow for each device to be truly independent.
Wed Feb 25, 2015 8:49 am
BassMint offline
Nice!!!
Thu Feb 26, 2015 9:31 pm
@BassMint: I've uploaded a revised version of the plugin that will allow direct assignment of local IPs. I'm unable to test it myself, so would appreciate any bug reports if you find something fishy.
I didn't include individual update frequencies in this version because it's more of a non-trivial change. Still on the ToDo list, however.
Cheers,
Dave
Sat Feb 28, 2015 3:38 am
BassMint offline
Updated and running. All appears to be OK.
Thanks !!!!!
Sat Feb 28, 2015 5:59 am
Thanks !!!!!
Excellent. Thanks for letting me know.
Dave
