How to find out what the returned values are?
Thu Jan 12, 2017 7:50 pm
Jim offline
I have set up a device (Type=WUnderground, Model=Wunderground Weather).
I then set up a trigger that if Forecast Precipitation - Day 2 > 40 skip watering
Does seem to be working. I tried the "Write Weather data to File ..." but does not seem to be writing out the file.
1) Does Forecast Precipitation - Day 2 return percent change of precipitation?
2) Is there a way to see what is coming back from the Underground API call to help debug?
3) In general is there a document that shows what values are returned for each of the API values? I found some older ones on the forum but not one for Wunderground Weather
Jim
Thu Jan 12, 2017 9:35 pm
Re: How to find out what the returned values are?
It does. Specifically, POP (Probability of Precipitation). http://help.wunderground.com/knowledgebase/articles/129082-what-is-pop
2) Is there a way to see what is coming back from the Underground API call to help debug? I tried the "Write Weather data to File ..." but does not seem to be writing out the file.
What version of Indigo are you using? The plugin generally requires Indigo 6 or above and should be writing all the weather data in question to either of two places (depending on your version of Indigo):
/Library/Application Support/Perceptive Automation/Indigo 6/Logs/
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/
If that's not the case, I may have a bug that needs tending to.
Not as such. There is a Weather Underground API site located at: https://www.wunderground.com/weather/api/d/docs which is where I get my information. But I should note that not all the data that are available are included in the plugin.
Dave
Thu Jan 12, 2017 9:51 pm
Jim offline
Thanks for the quick response Dave.
I am running Indigo 7
When I select "Write Weather data to File ..." is a dialog suppose to come up. Nothing happens and the Logs directory is empty.
Jim
Thu Jan 12, 2017 9:55 pm
Jim
Hmmm. You should see a note to the Indigo log window that says something akin to:
   WUnderground                    Weather data written to: /Library/Application Support/Perceptive Automation/Indigo 7/Logs/2017-01-12 Wunderground.txt
I've just tested it here on my production server and it seems to be working fine.
Screen Shot 2017-01-12 at 9.54.51 PM.png (74.72 KiB) Viewed 2067 times
Thu Jan 12, 2017 10:03 pm
Jim offline
Dave I was looking in /Library on the machine running the front-end and not on the Mac running the server. The log is there. Sorry about that and thanks for the other answers.
Jim
Fri Jan 13, 2017 4:40 am
Jim
Wunderbar. Glad I could help.
Please feel free to post back with any other questions.
Dave
