WUnderground Error These are estimated conditions
Wed Nov 09, 2016 8:36 am
WouterK offline
Since I upgraded to the latest version I am seeing a lot of messages like this in the log screen:
WUnderground Debug Line 2688 Reason: 'error'
WUnderground Error These are estimated conditions. There may be other functioning weather stations nearby.
or:
WUnderground Debug Line 1377 Reason: 'estimated'
Is there something I have to (re)configure ?
Thanks.
Wouter
Wed Nov 09, 2016 9:23 am
Re: WUnderground Error These are estimated conditions
Hi Wouter - these errors are now appearing in the logs due to changes that I'm making to future-proof the plugin and can be ignored. The next version of the plugin will hide these notices completely--precisely because there is nothing that you can (or should) do as a result of them.
Thanks for reaching out, and I hope that you're (otherwise) enjoying the plugin.
Dave
Wed Nov 09, 2016 9:34 am
WouterK offline
Hi Dave,
Thanks for the quick reply. And yes I am enyoing your plugin for a long time :D
Thing is that when I see the line "WUnderground Error These are estimated conditions. There may be other functioning weather stations nearby" the temp value is wrong.
In this case it is 4.4 degrees (my Davis value and WU value) while the plugin returns 16 degrees.
Is this related or something else?
Regards,
Wouter
Wed Nov 09, 2016 10:33 am
It is related. I do no math on temperature--just some string operations for display. The plugin gives you whatever WU is sending.
Wed Nov 09, 2016 11:43 am
WouterK offline
Ok, thanks.
I will see what WU is sending........ :D
Regards,
Wouter
Wed Nov 09, 2016 4:52 pm
WouterK wrote:
Ok, thanks.
Regards,
Wouter
Thanks. Please let me know if you see any discrepancies between what WU is sending and what you're seeing in the plugin. Happy to try to address anything you find, but there should be no numeric differences.
Wed Nov 09, 2016 8:37 pm
I'm more convinced than ever that this is WU. I was humming along nicely and then I looked down and saw this:
Screen Shot 2016-11-09 at 8.30.18 PM.png (8.35 KiB) Viewed 2478 times
These two weather sites are 6 miles apart. The bottom one is estimated. :roll:
Wed Nov 09, 2016 8:55 pm
I have uploaded an update that allows estimated conditions to be ignored.
http://forums.indigodomo.com/viewtopic.php?f=149&t=12482&start=75#p125937
