Log Error
Fri Jul 29, 2016 9:02 pm
CraigM offline
Log Error
I have been getting this error consistently
WUnderground Error              There was a problem parsing 10-day forecast data. Please
                                check your settings. Note: You _must_ have a Cumulus or
                                Anvil plan to obtain hourly forecast data.
WUnderground Error              float argument required, not NoneType
v0.9.38
Fri Jul 29, 2016 9:21 pm
RogueProeliator offline
Re: Log Error
I was seeing that as well... probably a WUnderground feed error since nothing else has been updated. If I am not mistaken the last data pull went through okay (for me at least).
Sat Jul 30, 2016 4:31 am
Re: Log Error
I was seeing these as well--from about 21:30 - 23:30 (US Central Time). I think that Adam's right in that it was something on WU's end. I was also getting periodic "estimated conditions" messages when one of my local PWSs was offline. Perhaps I could have a better log message though in this instance to differentiate between those that don't have sufficient access and data supply problems.
FYI, I also had a couple stretches of errors with the Device Extensions Plugin:
2016-07-29 15:38:25.083   EPS - Device Extensions Error   Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 101, in deviceUpdated
  File "plugin.py", line 140, in updateDevice
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Device Extensions.indigoPlugin/Contents/Server Plugin/eps/Weathersnoop.py", line 51, in updateWeather
ValueError: empty string for float()
Which is probably related to the WU error.
Dave
