Super basic syntax question
Tue Apr 12, 2016 10:30 am
Different Computers offline
Technically this is more "how does someone who doesn't know curl make this work" , but it crops up for me here because it's the first time I've tried something like this.
I'm trying to get WU's satellite image following their instructions at https://www.wunderground.com/weather/ap ... llite&MR=1
Well first off I have to curl not GET, but it seems to pull something from their servers. But it's all just going in the terminal. I've read the man page for curl, and this seems like it should work:
curl http://api.wunderground.com/api/myAPIkeyHere/animatedsatellite/image.gif?lat=00&lon=00&radius=100 --output "/Users/myname/Desktop/"
nope. Junk to the terminal/STOUT
curl http://api.wunderground.com/api/myAPIkeyHere/animatedsatellite/image.gif?lat=00&lon=00&radius=100 --output "/Users/myname/Desktop/satellite.gif"
also nope. These also nope when I use -o instead of -output or when I try the -G option:
curl -G http://api.wunderground.com/api/myAPIkeyHere/animatedsatellite/image.gif?lat=00&lon=00&radius=100 --output "/Users/myname/Desktop/satellite.gif"
"myAPIkey" is replaced with my actual API key and the real lat and longitude are in the actual URLs I tried.
Any help? I'm sure someone here has this working.
Tue Apr 12, 2016 10:56 am
forestfield offline
Re: Super basic syntax question
Quick guess. If you're running this from the command line, the & in the url is being interpreted by the command line shell, and you need to escape it.
One way to do this is to put the url in ' or " characters, i.e.
curl "http://api.wunderground.com/api/myAPIkeyHere/animatedsatellite/image.gif?lat=00&lon=00&radius=100" --output "/Users/myname/Desktop/satellite.gif"
This gives me an "this key does not exist" error - which is what I'd expect, not having an api key.
Tue Apr 12, 2016 11:31 am
Totally worked! Well, kinda. The GIF that downloads is blank, but that's a different problem.
Thanks very much.
So now I wonder under what circumstances the examples used in man curl DO work. Shell scripts?
Tue Apr 12, 2016 1:19 pm
ckeyes888 offline
Just a heads up that as yet, natively anyway, animated gifs aren't supported on control pages.
Carl
Tue Apr 12, 2016 2:57 pm
The animated gif is working on my page.
Tue Apr 12, 2016 3:01 pm
In my experience, animated GIFs *will* animate in a browser, but will not animate in Indigo Touch.
Tue Apr 12, 2016 3:29 pm
DC -
First, GET is an http command type, like POST. You're using the "curl" command line utility to send HTTP commands. The default for curl is to do a GET, so you don't need to specify it. The full form of the command would be
curl --get "http://api.wunderground.com/api/myAPIkeyHere/animatedsatellite/image.gif?lat=00&lon=00&radius=100" --output "/Users/myname/Desktop/satellite.gif"
I think you missed this line in the man page:
When using [] or {} sequences when invoked from a command line prompt, you probably have to put the full URL within double quotes to avoid the shell from interfering with
it. This also goes for other characters treated special, like for example '&', '?' and '*'.
None of the examples on the man page have an ampersand in them, so they don't show the quotes.
