Humidity Issues
Tue Jun 30, 2015 3:57 pm
CraigM offline
Humidity Issues
Love the plugin :D , but
Why is there no Greater Than/Less Than condition choice for current humidity?
Why does the humidity reading in iTouch have a decimal. My pref is set to UI=0
Tue Jun 30, 2015 7:35 pm
Re: Humidity Issues
Because you found a bug that I did not! :D I will include a fix for this in the next version (which should be coming soon.)
That one will require a bit more digging, but I suspect that the fix above will correct this as well.
Thanks for bringing both to my attention!
Dave
Fri Jul 10, 2015 4:17 pm
CraigM offline
Re: Humidity Issues
By chance is the
- Fixes bug in reporting of relative humidity (now a float.)
in the v0.9.12 update a fix for the humidity decimal?
I'm still showing a x.x% readout
Fri Jul 10, 2015 5:40 pm
Re: Humidity Issues
CraigM wrote:
By chance is the
Unfortunately not. That fix was to address the fact that it was not possible to do a less than/greater than with humidity. Your request is still on the to-do list, but the more I thought about it, the more non-trivial it became.
On the one hand, I could switch the temperature UI decimal preference to become the "everything" UI decimal preference. On the other hand, I could make separate preferences for each major element--but how to decide? On the third hand, I could make separate preferences for every major data type, but that would really open up a can of worms.
I honestly haven't decided yet, but didn't want to hold up the update any longer as there were a few serious bugs that really needed to be addressed.
Would you prefer one single setting to affect all values?
Sun Jul 12, 2015 1:23 pm
CraigM offline
Re: Humidity Issues
Until reading your post I assumed that the pref was global ("everything UI").
Without polling the other users I feel that you either want to see decimals or don't want to see decimals, so global ("everything UI") would probably be fine.
On the other hand, more individual control is always a good thing. So I would base your decision on what MOST users would like, vs your TIME, DIFFICULTY to implement the change.
