- New! The plugin now queries once per location rather than once per device (substantially reducing the number of API calls.) Note that the location information must be identical for similar locations in order for this to work. For example, a city name and its longitude/latitude are not the same..
in the log file report set to high says in one log cycle I have used up 4 calls / 500 is this a normal action I usually have my log set to off but realizing my weather data was not updating I turn it on to check why. I have my interval set for every 15 min. In the past my limit was OK so is the only fix to set it to 30 min now?
