Current Weather variable
Mon Feb 02, 2015 4:43 am
bluefightingcat offline
I'm using this great plugin as a trigger for some of my devices. However I have a question.
Essentially I have created a trigger that turns on my device for a certain amount of time when it snows outside. I have used the "CurrentWeather=" to check whether it's snowing outside.
However this variable has a text value e.g. light snow, heavy snow, rain, sun etc. If I want to trigger based on snow, do I need to create a trigger for each possible situation e.g. light snow, heavy snow etc. or is it enough to just use the word "snow" to get the trigger to work?
Mon Feb 02, 2015 5:10 am
Re: Current Weather variable
I think this should work, you can set-up a Trigger as:
  • Device State Changed
  • Weather
  • Current Conditions - Weather
  • Has Any Change
and then add a Condition which says:
  • If conditions match rules
  • Any
    • if device
    • Weather
    • contains
    • Snow
    • if device
    • Weather
    • contains
    • snow
Not sure whether you need to check for 'Snow' (Title case) and 'snow' (Lower case) but better safe than sorry. :)
Mon Feb 02, 2015 5:20 am
Thanks. Will try that. :D
Mon Feb 02, 2015 5:36 am
Thanks for the help Jon. I can confirm that this works. I just happen to be getting snow here right now. I'd trigger on "Snow' and 'snow' as Jon suggests.
Cheers,
Dave
