Weather Underground Plugin
Fri May 02, 2014 4:03 am
Re: Weather Underground Plugin
colinpartridge wrote:
DaveL17 wrote:
@Colin:
Please do me a favor and inspect the custom states for one of your weather devices--do you see blocks of states for:
alertDescription[1-4]
alertExpires[1-4]
alertMessage[1-4]
alertStatus[1-4]
Dave
HI Dave,
Yes I do. Obviously I don't see the errors if I turn off debugging, sorry I forgot to mention that.
Colin
Hmmm. I can't reproduce the error, so I'm going to have to do a bit more digging. According to the WU docs, there are somewhat different calls that must be made for European alerts--and apparently I'm not calling them quite right.
http://www.wunderground.com/weather/api/d/docs?d=data/alerts
Let me do a deeper dive on this. Please stay tuned.
Dave
Fri May 02, 2014 4:13 am
haavarda wrote:
DaveL17 wrote:
@haavarda - I have figured out what was causing the celcius forecast to come through as fahrenheit. The plugin was downloading the metric forecast properly, but this value was then being instantly overwritten with fahrenheit values.
This will be fixed in v0.3.5.
Sorry for the trouble.
Dave
It works now. Thank your for the update. My HI/LOW are now presented in C.
Can you or someone else point me in the right direction on how to show weather icons with data from Wunderground?
regards
Glad that did the trick. Amazing what a misplaced tab will do...
Sorry that I completely glossed over your question about the icons. The plugin handles the icon value in two ways: The first is Icon All Day which retains the icon name that WU sends. The second is Proper Icon Name which prepends a flag to the icon name to indicate whether it is day or night (see above in this thread for an example of day/night icons.)
Clear = 'Clear' (all day)
Clear = 'Clear' or 'nt_Clear' (proper)
To use the icon name, follow the instructions found on the Wiki for Custom Images:
http://www.perceptiveautomation.com/wiki/doku.php?id=cp_custom_images&s[]=control&s[]=page
Hope that helps.
Dave
Fri May 02, 2014 6:51 am
haavarda offline
Thank you for your feedback.
I think I am a bit slow here, but I don't understand how these variable images should be added. I have read the wiki that you link to, but I don't understand if I should change image names etc...??
Should I select "variable value" CP editor? I have all the different icons listed there, but I can not find something called Icon All Day or Proper Icon Name.
regrads
Håvard
Fri May 02, 2014 12:03 pm
regrads
No worries.
Under the Indigo tree, look for a folder named 'IndigoWebServer/images/controls/devices'. Within that (and other folders too depending on the thing you're linking to) are images for control pages. The names of the images are linked to what the control pages will display. In this case, you'll link to:
Device State -> Your Weather Device -> Current Conditions - Icon (All Day) or Current Conditions - Icon (Day/Night)
(properIconName and properIconNameAllDay are the actual device states)
For your custom images, name them whatever you want, using the following conventions:
etc.
The actual names of the conditions that Weather Underground sends can be found on the developers site where you got your API key (look for documentation.) The icon name could include any of these depending on your area.
EDIT: here a link to the API documentation: http://www.wunderground.com/weather/api ... e-glossary
Hope this helps,
Dave
Sat May 03, 2014 5:02 am
haavarda offline
Thank you for your instructions.
I managed to set it up now!
regards
Håvard
Sat May 03, 2014 5:24 am
regards
Glad to hear that you were able to make it work. Have fun!
Dave
Mon May 12, 2014 7:17 pm
Now Available: Wunderground Plugin v0.3.6 -- This version adds what I hope will be much more stable handling of alert information. This update should also be stable for both U.S. and European alerts. Due to limitations with multi-line strings, I am presently printing the long form of the alert to the log.
In order to upgrade successfully, after installing the new version, open each weather device, select "Edit Device Settings", and select Save. Alternatively, you can delete existing devices and create new ones.
As always, post questions and bug reports here.
Cheers,
Dave
Tue May 13, 2014 1:43 am
colinpartridge offline
Hi Dave,
Have just updated to the latest version and am now getting the following error messages..
Wunderground Error              Error in plugin execution runConcurrentThread:
  File "plugin.py", line 339, in runConcurrentThread
<type 'exceptions.UnboundLocalError'>: local variable 'alertArray' referenced before assignment
  Wunderground Error              plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I wonder if this is related to the European Alert messages you referred to earlier.
cheers
Colin
Tue May 13, 2014 4:44 am
Dang. Sorry about that. Please try this version and see if it's better.
https://dl.dropboxusercontent.com/u/2796881/Wunderground.indigoPlugin.zip
Tue May 13, 2014 4:56 am
haavarda offline
I am getting that error message as well. I am unable to install your fix because I am only prompted to enable the plugin. Because it is the same version?
regards
Håvard
Tue May 13, 2014 5:04 am
Thanks Dave,
Have installed that version and not getting errors. Haavarda, I downgraded to a previous version and then upgraded to the current version, or you could just delete the Wunderground plugin before reinstalling it.
Colin
Tue May 13, 2014 5:28 am
Thanks Colin. Please let me know if the error comes back (it shouldn't.)
haavarda - Colin's advice should work for you. I'll renumber the patch ASAP.
EDIT: The version number has been updated. Should be okay now.
Tue May 13, 2014 5:30 am
haavarda offline
That worked. Thanks for the tips
Håvard
Tue May 13, 2014 5:38 am
Good. Sorry for he hassle. That's what I get for posting a patch before the morning coffee kicks in...
Tue May 13, 2014 10:48 am
Korey offline
Seeing errors every time I try to start the plugin, API key is correct and so are device settings..
I've tried zip codes and PWS setting in the device config.
Deleted pulgin and devices and started from scratch..
still no joy.
 Reloading plugin "Wunderground 0.3.6"
  Stopping plugin "Wunderground 0.3.6" (pid 18787)
  Stopped plugin "Wunderground 0.3.6"
  Starting plugin "Wunderground 0.3.6" (pid 18803)
  Started plugin "Wunderground 0.3.6"
  Wunderground                    Weather Underground: 89117
  File "plugin.py", line 477, in runConcurrentThread
May 13, 2014 9:43:53 AM
  Trigger                         Pool Temp Update Variable
May 13, 2014 9:44:23 AM
  Trigger                         Spa Temp Update Variable
With debugging enabled:
  Wunderground Debug              runConcurrentThread initiated.
  Wunderground Debug              pressSym() method called.
  Wunderground Debug              convStr() method called.
Korey
Page 5 of 56 1, 2, 3, 4, 5, 6, 7, 8 ... 56
