WUnderground Plugin Updates
Sun Nov 15, 2015 9:36 pm
Re: WUnderground Plugin Updates
WUnderground Plugin v0.9.29 is now available.
- Fixes a bug in precipitation UI display value routine where values were being improperly rounded.
You can download it here.
Sat Dec 12, 2015 5:59 am
WUnderground Plugin v0.9.30 is now available.
- Revises forecast email data to remove redundant precipitation forecast. Retains forecast QPF.
- Fixes a bug in comparison of yesterday's high to today's forecast.
Sun Dec 13, 2015 5:54 am
WUnderground Plugin v0.9.31 is now available.
- Additional work on the comparison of yesterday's high to today's.
Thu Dec 31, 2015 12:53 pm
WUnderground Plugin v0.9.32 is now available.
- Adds Weather Device State for last observation (epoch.)
- Fixes bug in long wind string where wind gust was reported using wind gust icon data (wrong decimal point placement.)
- Fixes bug for forecast precipitation units (where units displayed temperature format rather than percentage format - only standard was broken.)
- Fixes bug for precipitation value when weather station is not online (estimated conditions = True).
- Fixes bug for email forecast when weather station in not online (estimated conditions = True).
- More robust error logging.
Sun Jan 17, 2016 5:56 am
WUnderground Plugin v0.9.33 is now available.
- Consolidates or eliminates some internal control functions that may have caused the Indigo server to get caught in an endless loop. This update does not impact user-facing functionality.
Sat Mar 26, 2016 5:35 am
WUnderground Plugin v0.9.34 is now available.
- Fixes TypeError where barometric pressure will not float. Fix will return a string value in place of a float.
- Improves plugin configuration validation.
- Adds window screen error messages to the plugin config dialog.
Mon Apr 04, 2016 6:56 pm
WUnderground Plugin v0.9.35 is now available.
- Ensures that all uiValue assignments are coerced to a string.
- Refinements to plugin sleep routines.
- Refinements to device updates to ensure that device instances aren't reloaded unnecessarily.
- Minor code refinements.
Thu May 26, 2016 4:38 am
WUnderground Plugin v0.9.36 is now available.
- Adds plugin setting to control the decimal precision of wind values.
- Fixes bug in setting for MPS devices where setting was sometimes over-ridden as KPH.
- Fixes typo in config dialog for 10 Day Forecast devices (now MPS instead of KPS.)
Mon Jun 06, 2016 7:13 pm
WUnderground Plugin v0.9.37 is now available.
- Fixes bug in setting for 'UV' value (broken custom image heuristics.)
- Fixes bug in setting for 'windGustIcon' value (broken custom image heuristics.)
This is a minor update. If the WUnderground Plugin is working well for you, there's no reason to update now. You can download it here.
Mon Jun 20, 2016 4:27 am
WUnderground Plugin v0.9.38 is now available.
- Improves handling of legacy device types for forecast email settings (where settings were saved as a string rather than as a boolean value.)
Tue Aug 23, 2016 9:00 pm
WUnderground Plugin v0.9.39 is now available.
- Migrates some dynamic plugin settings from Indigo preferences file to custom plugin preferences file (i.e., call count, email sent, etc.)
- Converts string substitution operations to make way for future enhancements.
Thu Oct 20, 2016 7:23 pm
WUnderground Plugin v0.9.41 is now available.
- Fixes a bug that shows up when WUnderground sends a malformed temperature value.
Please note! If you install this version of the plugin and it begins cycling repeatedly (it shouldn't!) you'll need to delete the plugin preferences file and reconfigure. TO BE CLEAR, THIS SHOULD NOT BE A NECESSARY STEP FOR MOST PEOPLE. However, if needed.......follow these steps:
1) Make note of your settings within the plugin configuration screen (and be sure to copy your API key to a scratch pad).
2) Disable the plugin (if it’s not already disabled).
3) Stop the Indigo server.
4) Exit the Indigo application.
5) Delete the WUnderground plugin preferences file
(/Library/Application Support/Perceptive Automation/Indigo 6/Preferences/Plugins/com.fogbert.indigoplugin.wunderground.indiPref)
6) Restart the Indigo server.
7) Restart the plugin, and reconfigure.
Mon Oct 31, 2016 5:49 am
WUnderground Plugin v0.9.43 is now available.
- Fixes a bug that shows up when WUnderground does not send history data for a weather location.
Wed Nov 02, 2016 6:06 am
WUnderground Plugin v1.0.01 is now available.
- New! Adds solar radiation state to Weather Device type (units: W/^2).
- Fixes a bug for older installs where certain device props were instantiated incorrectly (improves upon change in v0.9.38).
- Minor changes to debug logging.
Sun Nov 06, 2016 7:49 am
WUnderground Plugin v1.0.02 is now available.
- Increased protection against defective data from the Weather Underground API.
