Battery level in Multitool
Sat Feb 04, 2023 8:54 am
jalves offline
I upgraded to the MultiTool plugin to 2022.1.8. But I don't see the Battery Level monitor in the drop-down menu. How do I enable this feature?
[Moderator's Note: moves topic to the Multitool plugin forum.]
Jeff
Sat Feb 04, 2023 11:04 am
Re: Battery level in Multitool
Hi Jeff, there's not a battery level monitor feature in the Multitool Plugin per se; instead, there's a battery level reporting tool which outputs to the Indigo Events log.
   Multitool                       ======================================= Battery Level Report =======================================
   Multitool                       Basement - Flood (Water)   |--------------------------------------------------| 100%
   Multitool                       Basement - Smoke           |--------------------------------------------------| 100%
   Multitool                       Foyer - Smoke (Main Floor) |--------------------------------------------------| 100%
   Multitool                       Foyer - Smoke (Upstairs)   |--------------------------------------------------| 100%
   Multitool                       Garage - Motion            |--------------------------------------------------| 100%
   Multitool                       Garage - Side Door         |--------------------------------------------------| 100%
   Multitool                       Guest Bedroom - Motion     |-----------------------------| 59%
   Multitool                       Main Attic - Motion        |--------------------------------------------------| 100%
   Multitool                       Master Bathroom - Motion   |----------------------------------| 69%
   Multitool                       Master Bedroom - Motion    |----------------------------------------------| 93%
   Multitool                       Master Closet - Motion     |------------------------------------------| 84%
   Multitool                       Office - Motion            |-----------------------------| 59%
   Multitool                       Outdoor - Luminance        |-------------------------| 50%
   Multitool                       Parlor - Motion            |--------------------------------------------------| 100%
There is a script I run every night around midnight which is a variation of this:
target_level = int(indigo.variables[VARIABLE ID NUMBER].value)  # lowBatteryLevel
email_address = indigo.variables[VARIABLE ID NUMBER].value  # "notificationEmailAddress"
email_body = ""
for dev in indigo.devices.itervalues():
    if dev.batteryLevel:
        if dev.batteryLevel <= target_level:
            email_body += f"{dev.name} battery level: {dev.batteryLevel}\n"
if email_body != "":
    email_body = "The following Indigo devices have low battery levels:\n" + email_body
    indigo.server.sendEmailTo(email_address, subject="Indigo Low Battery Alert", body=email_body)
Which is also available in the forums.
But you've given me the idea to add an Indigo Action to the plugin to send the battery level report to an email -- which I'll add to the TODO list.
Sat Feb 04, 2023 11:30 am
jalves offline
Thanks Dave!
Jeff
