Allow Python to Accept Incoming Connections - Solution?
Thu Aug 25, 2016 6:17 am
Caution! I'm WAY outside my element, so if you choose to try anything here, you are on your own.
These are the steps that I took to overcome the "Allow Python to Accept Incoming Connections" nag screen from the OS X Firewall. This nag screen occurs on upgraded installs of OS X (it doesn't seem to happen with clean installs) and has nothing to do with Indigo. Note: If you don't have XTools installed, you may need to do that in order for these steps to work (I'm not sure if it's a requirement. I performed these steps with it installed.)
1. Create a signing certificate. Note the name that you give the certificate as you'll need it later. (Source: AskDifferent)
- Open Keychain Access.
- In Keychain Access, Keychain Access > Certificate Assistant > Create a certificate. This launches the Certificate Assistant:
- Name: Enter some arbitrary string here that you can remember. Avoid spaces otherwise you'll need to escape the cert's name when using codesign from the command line.
- Identity type: Self Signed Root
- Certificate Type: Code Signing
- Check the box "Let me override defaults", this is quite important
- Serial number: 1 (OK as long as the cert name/serial no. combination is unique)
- Validity Period: 3650 (gives you 10 years) <-- (I chose 7200.)
- Email, Name, etc. fill out as you wish.
- Key pair info: set to RSA, 2048 bits. Does not really matter IMHO.
- From "Key usage extension" up to "Subject Alternate Name Extension": accept the defaults.
- Once it is created, set to "Always trust" in the Login keychain.
2. Boot into recovery mode (hold CMD-R or alternatively, hold option and select Recovery.) If you have a Bluetooth keyboard, you may be well served to use a wired keyboard to gain access to Recovery Mode (doing it with a BT keyboard can be tricky.)
3. Disable System Integrity Protection (SIP). Open a terminal window and enter:
csrutil disable
and exit terminal normally.
4. Reboot into normal mode.
5. Open the OS X Firewall, right click on the Python entry and select "Reveal in Finder." Copy the full path to the file. Mine was:
/System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app
6. open a terminal window and enter (replace 'certificate_authority_name ' with the name of your certificate and replace your path from #5 if it's different.)
sudo codesign -s certificate_authority_name -f /System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app
At this point, XTools will prompt you to accept the license agreement if you haven't already done so. I found that codesign continued after accepting the terms. OS X will ask if you want to allow access to your Keychain; select yes for each prompt. Exit terminal normally.
7. Boot into recovery mode.
8. Re-enable SIP. Open a terminal window and enter:
csrutil enable
9. Reboot into normal mode and allow Python to accept incoming connections one more time.
Your mileage may vary, but following these steps solved the issue for me.
Cheers,
Dave
ETA: By the way, I should mention that there is every possibility that Apple may make changes in its OS updates that invalidates this fix--requiring either that it be reapplied (Apple replaces a signed binary with an unsigned one) or a different fix.
Sat Sep 03, 2016 11:38 am
tons offline
Re: Allow Python to Accept Incoming Connections - Solution?
This worked fine for me.
I did not even create the certificate upfront (step 1). I just used:
sudo code sign -f -s - /System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app
Ton
Sat Sep 03, 2016 11:43 am
Ton
Glad to hear that this worked for you.
Cheers,
Dave
Sun Sep 04, 2016 7:56 am
Japple55 offline
So, you started at step six, or only skipped step one?
Jim
Sun Sep 04, 2016 12:19 pm
Gysbert offline
Jim
Good question, what did you do?
Verzonden vanaf mijn iPad met Tapatalk
15x dimmer, 6x switch, 12 sets of outdoor blinds with switches, 17x electric curtain rails with switches, 2x electric roof lights with switches, 1x multisensor, 2x door sensors, Aeotec Siren, Geohopper, WUnderground plug-in, TOON smart thermostat
Wed Sep 07, 2016 7:56 pm
Updated the OP to note that this fix may also be transient. There is every possibility that Apple could do something in the future that requires the fix to be reapplied or require a whole new fix.
Dave
Sun Sep 18, 2016 8:47 pm
hamw offline
Anyone figure out what japple did? Do we still have to make a certificate?
Tue Sep 20, 2016 5:35 am
Japple55 offline
Japple didn't have the solution...it was Tons. I've sent him a PM in hopes he'll provide us an answer.
Tue Sep 20, 2016 3:36 pm
tons offline
I only skipped step 1
And in step 6 i used the command i mentioned in my previous post instead of the command from the topic starter
Sun Jan 22, 2017 7:49 pm
benish offline
This seems to have worked for me. Thank you!
