DaveL17 wrote:I spent a fair bit of time searching available options and flatDict seemed to be the best available option.
The plugin is for the community to develop together, but my own personal preference would be to avoid expanding it to cover what might be one-off solutions (admittedly, a json array is probably not a one-off solution) when flatDict is expecting a json object. It wouldn't be too tough for a user to create a script to snag a copy of the data, convert it to a json object and save it to a local file--which could then be easily read by the plugin.
I had a far briefer look I'm sure and couldn't find anything else either.
My current thoughts though are why go to Json --> Dict --> Flat Dict; isn't there an option to go straight from Json --> Flat Dict ?
(bearing in mind that I struggle a bit with python (particularly the editing environment )- mainly preferring C#)
Glenn
