V0.4.4 "No value found" error
Tue Jun 21, 2016 10:44 pm
davidw offline
Thanks so much for an awesome plugin! I just got my THX9421 Thermostat, and added it to my long running Indigo system, thanks to this plugin.
While it seems to be working correctly, I'm getting errors in the log (see below) every 30 seconds or so. Any feedback on how to resolve this?
Many thanks again!
Starting plugin "Honeywell 0.4.4" (pid 19301)
Started plugin "Honeywell 0.4.4"
Honeywell Your plugin version, v0.4.4, is current.
Honeywell Saved Plugin Configuration
Honeywell Error [Tue Jun 21 21:33:56 2016] No value found for device: Honeywell Thermostat, field: equipmentOutputStatus
Honeywell Error [Tue Jun 21 21:33:56 2016] No value found for device: Honeywell Thermostat, field: fanMode
Jun 21, 2016, 9:34:25 PM
Honeywell Error [Tue Jun 21 21:34:25 2016] No value found for device: Honeywell Thermostat, field: equipmentOutputStatus
Honeywell Error [Tue Jun 21 21:34:25 2016] No value found for device: Honeywell Thermostat, field: fanMode
Jun 21, 2016, 9:34:56 PM
Honeywell Error [Tue Jun 21 21:34:56 2016] No value found for device: Honeywell Thermostat, field: equipmentOutputStatus
Honeywell Error [Tue Jun 21 21:34:56 2016] No value found for device: Honeywell Thermostat, field: fanMode
Sat Jul 02, 2016 1:09 pm
davidw offline
Re: V0.4.4 "No value found" error
Is it bad form to be the first person to respond to your own post?
Further data:
I've been letting the plugin run and just ignored the errors in the log file, but this morning needed to do some other testing. I shut off the plugin, made a number of modifications and added devices to my AD2USB plugin (coincidently a different Honeywell system) then at the end re-enabled the Honeywell plugin.
It's come up with no errors and is running quietly. Previously there were errors continuously. I have no idea what may have changed, but am willing to experiment.
Sat Jul 30, 2016 2:05 pm
nlagaros offline
Would you update to the latest version of the plugin - we can use that as a baseline to debug any issues you are having. Thanks.
Sat Jul 30, 2016 2:26 pm
davidw offline
Upgrade complete. Will keep you posted. Thanks again.
Sun Mar 12, 2017 10:05 am
Adrian Osborn offline
I am having the same issue as described above, but have not been able to clear it. Basically I get the following in the error log every 30 seconds
Mar 12, 2017, 8:57:31 AM
Honeywell Error [Sun Mar 12 08:57:31 2017] No value found for device: Honeywell Thermostat, field: equipmentOutputStatus
Honeywell Error [Sun Mar 12 08:57:31 2017] No value found for device: Honeywell Thermostat, field: fanMode
Mar 12, 2017, 8:58:02 AM
Honeywell Error [Sun Mar 12 08:58:02 2017] No value found for device: Honeywell Thermostat, field: equipmentOutputStatus
Honeywell Error [Sun Mar 12 08:58:02 2017] No value found for device: Honeywell Thermostat, field: fanMode
I can control the thermostat just fine and it works fine through my control pages
I am using v0.5.0 on Indigo 7.0.3
Sun Mar 12, 2017 10:54 am
jalves offline
Perhaps this isn't helpful, but as another data point my Honeywell is working just fine. Try re-starting the plug-in?
Running Indigo 7.1.1 on a 27" iMac (mid-2017), 8G memory, 1T Fusion Drive, OS X 10.13.3
Jeff
Mon Apr 10, 2017 10:59 pm
TheJensen offline
Thank you for your work on this plugin! I just replaced my AC and Thermostats and was thrilled to see support already exists within Indigo.
That being said, I'm getting the same errors
Honeywell Error [Mon Apr 10 21:56:35 2017] No value found for device: Thermostat Downstairs, field: equipmentOutputStatus
Honeywell Error [Mon Apr 10 21:56:35 2017] No value found for device: Thermostat Downstairs, field: fanMode
Honeywell Error [Mon Apr 10 21:56:36 2017] No value found for device: Thermostat Upstairs, field: equipmentOutputStatus
Honeywell Error [Mon Apr 10 21:56:36 2017] No value found for device: Thermostat Upstairs, field: fanMode
Using "Honeywell 0.5.0" and Indigo 7.0.3
I reloaded the plugin and restarted the Mac. Any other suggestions???
Tue Apr 11, 2017 2:43 pm
jalves offline
It might be helpful to know what model thermostat you are using.
Jeff
Wed May 24, 2017 8:31 pm
wideglidejrp offline
Seems the problem is that some of the Honeywell thermostats may be installed in an environment where there is no Fan, hence the lack of a value for the device. One of my Honeywell Thermostats, for example, is in a basement where the only function is heat. There is no AC and no Fan. Looks like we need a way to configure a tstat with a third Fan option: None.
John Patrick
Author of Home Attitude
http://johnpatrick.com
Wed Jul 05, 2017 10:18 am
nlagaros offline
I just posted an update. Check it out: http://vulture:8000/wordpress/home/honeywell-thermostats/
