Plugin Exception
Wed Aug 20, 2014 10:18 am
Plugin Exception
Probably a result of a non-standard path here since I don't have a Honeywell thermostat/account, but I installed the plugin then cancelled out of the plugin config dialog (since I didn't have an account) and I got this python exception several times:
  Honeywell                       Your plugin version, v0.1.0, is current.
  Honeywell Error                 There was an error reading the plugin preferences. Please check your configuration.
  Honeywell Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 50, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 78, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 163, in get_all
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 159, in login
<type 'exceptions.NameError'>: global name 'server' is not defined
Oh, and thanks for another great plugin contribution!
Wed Aug 20, 2014 11:56 am
nlagaros offline
Re: Plugin Exception
Thanks - had a small typo in the code.
Thu Aug 21, 2014 8:52 am
jalves offline
Just tried this plugin (ver 0.1) and am getting errors:
  Honeywell Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Honeywell Error                 Bad R3 status: 500:Internal Server Error
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 166, in get_all
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 218, in get_one
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/simplejson/__init__.py", line 307, in loads
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/simplejson/decoder.py", line 335, in decode
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/simplejson/decoder.py", line 353, in raw_decode
<type 'exceptions.ValueError'>: No JSON object could be decoded
The device shows up in the Indigo Home window but doesn't appear to be connecting to my thermostat.
Jeff
Thu Aug 21, 2014 8:56 am
nlagaros offline
Did you configure the device with the device number in the url line on the website? I have very weak error handling right now so errors will by quite cryptic.
Thu Aug 21, 2014 9:33 am
jalves offline
No, apparently I didn't. I only entered my login info. I wasn't sure about the device number and had entered the name of my device instead. Perhaps that's the issue, but I'll have to dig around a bit to find the number.
Jeff
Thu Aug 21, 2014 9:40 am
jalves offline
OK, just entered the thermostat number in the device settings and now it is communicating. Set points read correctly, as does the actual temperature. Humidity shows strange results though, reporting 128%!!!!
Jeff
Thu Aug 21, 2014 9:45 am
nlagaros offline
What model thermostat do you have?
Thu Aug 21, 2014 10:31 am
jalves offline
Its a "RET97E5D series" according to the user guide manual.
Jeff
Thu Aug 21, 2014 6:38 pm
nlagaros offline
The plugin was written for the 9580, but I'm sure I can adjust for your model. I will release a version this weekend with some debugging support that will help us carve out the appropriate fields for your model.
Fri Aug 22, 2014 5:44 am
jalves offline
Great!
Jeff
Fri Aug 22, 2014 1:14 pm
jalves offline
Here is another snippet from my error log, if it helps:
Aug 22, 2014, 2:50:10 PM
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 129, in login
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 866, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 889, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 860, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 732, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 699, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 1135, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/socket.py", line 79, in ssl
<class 'socket.sslerror'>: The connect operation timed out
Aug 22, 2014, 2:50:42 PM
  Honeywell Error                 Honeywell warning: waiting for command execution [0]
  Honeywell Error                 Honeywell warning: waiting for command execution [1]
Aug 22, 2014, 2:51:04 PM
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 1134, in connect
  File "<string>", line 1, in connect
<class 'socket.timeout'>: timed out
Aug 22, 2014, 2:51:36 PM
Aug 22, 2014, 2:52:00 PM
Aug 22, 2014, 2:53:33 PM
Aug 22, 2014, 2:53:58 PM
Aug 22, 2014, 2:54:22 PM
Aug 22, 2014, 2:54:46 PM
Aug 22, 2014, 2:55:08 PM
Aug 22, 2014, 2:58:04 PM
Aug 22, 2014, 2:58:39 PM
Aug 22, 2014, 2:59:54 PM
Aug 22, 2014, 3:01:03 PM
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.indigoPlugin/Contents/Server Plugin/Honeywell.py", line 197, in get_one
Aug 22, 2014, 3:01:34 PM
Jeff
Sat Aug 23, 2014 9:43 am
nlagaros offline
I just posted an update with an action to dump the JSON payload to the Indigo log. If you execute the action and post results here, I can try to isolate what is unique about your model thermostat. I will also add some additional error handling in the next version.
Sat Aug 23, 2014 11:42 am
jalves offline
Here's what I got when I loaded ver 0.11.
Aug 23, 2014, 12:57:48 PM
  Upgrading plugin "Honeywell" to newer version 0.1.1 (previous version moved to trash)
  Loading plugin "Honeywell 0.1.1"
  Starting plugin "Honeywell 0.1.1" (pid 89014)
  Started plugin "Honeywell 0.1.1"
  Honeywell                       Your plugin version, v0.1.1, is current.
  Honeywell                       Saved Plugin Configuration
  SQL Logger                      adding column "uidata_rawmessageid" to table device_history_1015164383 ("AC Heat")
  SQL Logger                      adding column "uidata_uidataid" to table device_history_1015164383 ("AC Heat")
  Honeywell                       [AC Heat]: RawMessage: 64559169244759453
  Honeywell                       [address : 521607
batteryLevel : None
buttonGroupCount : 0
configured : True
coolIsOn : False
coolSetpoint : 75.0
dehumidifierIsOn : False
description :
deviceTypeId : HoneywellThermostat
displayStateId : temperatureInputsAll
displayStateValRaw : 75
displayStateValUi : 75
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
fanIsOn : False
fanMode : Auto
folderId : 0
     com.ssi.indigoplugin.Honeywell : (dict)
          NumHumidityInputs : 1 (string)
          ShowCoolHeatEquipmentStateUI : true (bool)
          address : 521607 (string)
heatIsOn : False
heatSetpoint : 65.0
humidities : [128.0]
humiditySensorCount : 1
hvacMode : Cool
lastChanged : 2014-08-22 15:17:30
model : Honeywell Thermostat
pluginId : com.ssi.indigoplugin.Honeywell
pluginProps : com.ssi.indigoplugin.Honeywell : (dict)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     fanData_fanMode : 0 (integer)
     fanData_fanModeAutoAllowed : true (bool)
     fanData_fanModeCirculateAllowed : false (bool)
     fanData_fanModeFollowScheduleAllowed : false (bool)
     fanData_fanModeOnAllowed : true (bool)
     humidityInput1 : 128 (real)
     humidityInputsAll : 128 (string)
     hvacCoolerIsOn : off (on/off bool)
     hvacDehumidifierIsOn : off (on/off bool)
     hvacFanIsOn : off (on/off bool)
     hvacFanMode : 0 (integer)
     hvacFanModeIsAlwaysOn : false (bool)
     hvacFanModeIsAuto : false (bool)
     hvacHeaterIsOn : off (on/off bool)
     hvacHumidifierIsOn : off (on/off bool)
     hvacOperationMode : 2 (integer)
     hvacOperationMode.ui : cool on (string)
     hvacOperationModeIsAuto : false (bool)
     hvacOperationModeIsCool : true (bool)
     hvacOperationModeIsHeat : false (bool)
     hvacOperationModeIsOff : false (bool)
     hvacOperationModeIsProgramAuto : false (bool)
     hvacOperationModeIsProgramCool : false (bool)
     hvacOperationModeIsProgramHeat : false (bool)
     setpointCool : 75 (real)
     setpointHeat : 65 (real)
     temperatureInput1 : 75 (real)
     temperatureInputsAll : 75 (string)
     uiData_CoolLowerSetptLimit : 50 (real)
     uiData_CoolNextPeriod : 88 (integer)
     uiData_CoolSetpoint : 75 (real)
     uiData_CoolUpperSetptLimit : 99 (real)
     uiData_HeatLowerSetptLimit : 40 (real)
     uiData_HeatNextPeriod : 88 (integer)
     uiData_HeatSetpoint : 65 (real)
     uiData_HeatUpperSetptLimit : 90 (real)
     uiData_RawMessageID : 64559169244759453 (string)
     uiData_SchedCoolSp : 75 (real)
     uiData_SchedHeatSp : 65 (real)
     uiData_StatusCool : 0 (integer)
     uiData_StatusHeat : 0 (integer)
     uiData_SystemSwitchPosition : 5 (integer)
     uiData_UIDataID : 31495981 (string)
     weather_HasStation : true (bool)
     weather_Humidity : 52 (real)
     weather_Icon : https://rs.alarmnet.com/TotalConnectComfort/images/Icons/Weather/2_mostly_sunny%402x.png (string)
     weather_Phrase : Partly sunny (string)
     weather_Temperature : 95 (real)
subModel :
supportsAllOff : False
supportsStatusRequest : True
temperatureSensorCount : 1
temperatures : [75.0]
version : 0]: UIData: 31495981
Aug 23, 2014, 12:58:48 PM
  File "plugin.py", line 49, in runConcurrentThread
Aug 23, 2014, 1:00:10 PM
Aug 23, 2014, 1:02:04 PM
Aug 23, 2014, 1:03:40 PM
Aug 23, 2014, 1:04:32 PM
  Honeywell                       [AC Heat]: RawMessage: 1487395948764166565
Aug 23, 2014, 1:05:08 PM
Aug 23, 2014, 1:06:46 PM
Hope this helps
Jeff
Sat Aug 23, 2014 12:57 pm
nlagaros offline
are you able to run the action i added? i want to see what comes back from the honeywell site. thanks.
Sat Aug 23, 2014 1:09 pm
jalves offline
I guess I don't know what/how to do that. If you can explain what I need to do I'll be happy to give it a try. Never mind. I think I figured it out. Hope this helps:
Aug 23, 2014, 3:07:54 PM
  Indigo Cocoa client authenticated (192.168.0.15)
  Enabling plugin "Honeywell 0.1.1"
  Starting plugin "Honeywell 0.1.1" (pid 5013)
  Honeywell                       [AC Heat]: RawMessage: 1567758811456639471
Aug 23, 2014, 3:10:31 PM
  Honeywell                       [AC Heat]: Setting Heat Setpoint to: 66.0
  Honeywell                       [AC Heat]: Heat Setpoint changed to: 66.0
  Honeywell                       [AC Heat]: RawMessage: 0
batteryLevel : None
configured : True
coolIsOn : False
coolSetpoint : 75.0
description :
enabled : True
errorState :
fanIsOn : False
fanMode : Auto
folderId : 0
heatIsOn : False
heatSetpoint : 65.0
hvacMode : Cool
lastChanged : 2014-08-23 15:10:20
protocol : Plugin
     setpointHeat : 66 (real)
     uiData_HeatSetpoint : 66 (real)
     uiData_RawMessageID : 0 (string)
     uiData_StatusCool : 1 (integer)
     uiData_StatusHeat : 1 (integer)
     uiData_UIDataID : 38317063 (string)
     weather_Humidity : 54 (string)
     weather_Temperature : 95 (string)
subModel :
version : 0]: UIData: 38317063
  Honeywell                       [AC Heat]: Setting Heat Setpoint to: 67.0
  Honeywell                       [AC Heat]: Heat Setpoint changed to: 67.0
batteryLevel : None
configured : True
coolIsOn : False
coolSetpoint : 75.0
description :
enabled : True
errorState :
fanIsOn : False
fanMode : Auto
folderId : 0
heatIsOn : False
heatSetpoint : 66.0
hvacMode : Cool
lastChanged : 2014-08-23 15:10:34
protocol : Plugin
     setpointHeat : 67 (real)
     uiData_HeatSetpoint : 67 (real)
     uiData_UIDataID : 38317068 (string)
subModel :
version : 0]: UIData: 38317068
batteryLevel : None
configured : True
coolIsOn : False
coolSetpoint : 75.0
description :
enabled : True
errorState :
fanIsOn : False
fanMode : Auto
folderId : 0
heatIsOn : False
heatSetpoint : 66.0
hvacMode : Cool
protocol : Plugin
subModel :
Aug 23, 2014, 3:11:09 PM
  Honeywell                       [AC Heat]: RawMessage: 2816170196142931430
batteryLevel : None
configured : True
coolIsOn : False
coolSetpoint : 75.0
description :
enabled : True
errorState :
fanIsOn : False
fanMode : Auto
folderId : 0
heatIsOn : False
heatSetpoint : 67.0
hvacMode : Cool
lastChanged : 2014-08-23 15:10:52
protocol : Plugin
     uiData_RawMessageID : 2816170196142931430 (string)
subModel :
Jeff
