Autelis Jandy
Sun Dec 04, 2016 2:29 am
Korey offline
Re: Autelis Jandy
Bollar wrote:
Got the cable pulled thru the house and all wired in, fired up the plugin and it's working nicely after downgrading the firmware to 1.5.5 so the PC100JZ could see my old Rev G RS8. :shock:
Korey
Sun Dec 04, 2016 5:38 pm
Korey offline
Re: Autelis Jandy
Well I spoke too soon, I can receive data but I can't seem to control anything from the Plugin. :cry:
Not sure if this is because I am running 1.5.5 in the Autelis, I do have control of the equipment by using the built in web server in the Autelis. (Port 80)
Port 6000 is configured and the debug looks like its sending the correct data, but no response from the Autelis.
I have asked if they can point me to 1.5.4 TCP firmware to see if this is it.
I have tried sending a raw jandy command from the plugin with no luck either.
Any suggestions?
   Autelis Jandy                   Socket: 192.168.0.36:6000 connected succesfully
   Autelis Jandy Debug             TX: #AUX1?
   Autelis Jandy Debug             TX: #AUX2?
   Autelis Jandy Debug             TX: #AUX3?
   Autelis Jandy Debug             TX: #AUX4?
   Autelis Jandy Debug             TX: #AUX5?
   Autelis Jandy Debug             TX: #AUX6?
   Autelis Jandy Debug             TX: #AUX7?
   Autelis Jandy Debug             TX: #AIRTMP?
   Autelis Jandy Debug             TX: #POOLHT?
   Autelis Jandy Debug             TX: #POOLHT2?
   Autelis Jandy Debug             TX: #POOLSP?
   Autelis Jandy Debug             TX: #POOLSP2?
   Autelis Jandy Debug             TX: #POOLTMP?
   Autelis Jandy Debug             TX: #ORPLVL1
   Autelis Jandy Debug             TX: #SWCPOOL
   Autelis Jandy Debug             TX: #SALTPOOL
   Autelis Jandy Debug             TX: #ORPFEED1
   Autelis Jandy Debug             TX: #PHLVL1
   Autelis Jandy Debug             TX: #PUMP?
   Autelis Jandy Debug             TX: #PUMPLO?
   Action Group                    Pool Aux 1 ON
   Autelis Jandy Debug             TX: #AUX1=1
   Autelis Jandy Debug             TX: #SPA?
   Autelis Jandy Debug             TX: #SPAHT?
   Autelis Jandy Debug             TX: #SPASP?
   Autelis Jandy Debug             TX: #SPATMP?
   Autelis Jandy Debug             TX: #SOLHT?
   Autelis Jandy Debug             TX: #SOLTMP?
   Autelis Jandy Debug             TX: #OPMODE?
   Autelis Jandy Debug             TX: #WFALL?
   Autelis Jandy Debug             TX: #CLEANR?
   Autelis Jandy Debug             TX: #VBAT?
   Autelis Jandy Debug             TX: #OPTIONS?
   Autelis Jandy Debug             TX: #MODEL?
   Autelis Jandy Debug             TX: #UNITS?
   Autelis Jandy Debug             TX: #KPEN=1
   Autelis Jandy Debug             RX: !00 PUMP=0
   Autelis Jandy Debug                 Updating Device: Pool, State: PUMP, Value: off
   Autelis Jandy Debug             RX: !00 SPA=0
   Autelis Jandy Debug                 Updating Device: Pool, State: SPA, Value: off
   Autelis Jandy Debug             RX: !00 POOLHT=0
   Autelis Jandy Debug                 Updating Device: Pool, State: POOLHT, Value: off
   Autelis Jandy Debug             RX: !00 SPAHT=0
   Autelis Jandy Debug                 Updating Device: Pool, State: SPAHT, Value: off
   Autelis Jandy Debug             RX: !00 SOLHT=0
   Autelis Jandy Debug                 Updating Device: Pool, State: SOLHT, Value: off
   Autelis Jandy Debug             RX: !00 AUX1=0
   Autelis Jandy Debug                 Updating Device: Pool, State: AUX1, Value: off
   Autelis Jandy Debug             RX: !00 AUX2=0
   Autelis Jandy Debug                 Updating Device: Pool, State: AUX2, Value: off
   Autelis Jandy Debug             RX: !00 AUX3=0
   Autelis Jandy Debug                 Updating Device: Pool, State: AUX3, Value: off
   Autelis Jandy Debug             RX: !00 AUX4=0
   Autelis Jandy Debug                 Updating Device: Pool, State: AUX4, Value: off
   Autelis Jandy Debug             RX: !00 AUX5=0
   Autelis Jandy Debug                 Updating Device: Pool, State: AUX5, Value: off
   Autelis Jandy Debug             RX: !00 AUX6=0
   Autelis Jandy Debug                 Updating Device: Pool, State: AUX6, Value: off
   Autelis Jandy Debug             RX: !00 AUX7=0
   Autelis Jandy Debug                 Updating Device: Pool, State: AUX7, Value: off
Korey
Tue Dec 06, 2016 2:19 pm
Korey offline
Re: Autelis Jandy
Just updating my progress.
I found: FirmwareUpdater-PC100JZL-TCPSerial-1.6.2 buried in the Autelis fourms, This fixed the issue of the Autelis not responding to the plugins commands. :wink:
Autelis support then sent the legacy version of TCP Firmware 1.6.9, I upgraded the firmware and everything works as it should!
Thanks for this great Plugin!
:D :D :D
Korey
Tue Dec 20, 2016 6:26 pm
roquej offline
Re: Autelis Jandy
Was wandering if anyone could help.
Have the plugin configured and working. Can successfully turn the PUMP, HEATER, and AUX device ON/OFF. Can even set the temperature set-point. However, when trying to set a Speed, any speed, I get the following error:
Action Group Pool Pump-SetSpeed-1
Error (client) timeout waiting for plugin response from com.ssi.indigoplugin.AutelisJandy for request UiGetValues1
Error (client) timeout waiting for plugin response from com.ssi.indigoplugin.AutelisJandy for request CallPluginFunc
Error (client) runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
When this happens, the entire Indigo becomes unresponsive and needs to be reset. King of ugly...
Using plug version 1.2.9 with a Jandy Aqualink RS and a Intelliflow VS pump. The Autelis is using version 1.6.9. The Speed labels in the Autelis setup and the plugin match (Speed1, Speed2, etc.)
Any suggestion would be appreciate it. Thank you in advance.
JP
Thu Dec 22, 2016 6:51 pm
roquej offline
Re: Autelis Jandy
After readying the entire thread and looking through the code, I think the issues I am having with setting the speed for my Intelliflow VS is that the plugin is only configured to support the Jandy ePump. Does that make sense?
If it does, any idea when, if at all, the Intelliflow be supported?
JP
Sun Jan 15, 2017 3:22 pm
Korey offline
Re: Autelis Jandy
For the Incase this helps anyone file:
I was having issues with the plugin not being able to completely control a Rev "T" RS8 power centre.
The issues were some of the devices ( Cleaner / Solar / Spillover) not responding to the OFF command from the plugin.
It seems this newer revision RS8 control center does not seem to recognize (zero) 0 = Off, but it does respond to FALSE. :roll:
The quick solution was to have the plugin send "Jandy Commands" i.e.: #WFALL=FALSE to turn off the appropriate device (in this case the spillover).
I then later modded the plugin changing the autelis.py file so it would send TRUE / FALSE instead of 1 / 0.
Here's a snippet:
if action == "AuxDev":
         AuxDev = str(int(pluginAction.props.get("AuxDev")) + 1)
         setting = pluginAction.props.get("setting")
         if setting == "Off":
            outmsg = ("#AUX" + AuxDev + "=FALSE")
         elif setting == "On":
            outmsg = ("#AUX" + AuxDev + "=TRUE")
         elif setting == "Toggle":
            outmsg = ("#AUX" + AuxDev)
         self.sendMessage(outmsg)
All working as it should now. :D :D :D
Korey
Wed Jul 05, 2017 12:44 pm
roquej offline
Re: Autelis Jandy
A quick question, is anyone still working on this plugin? I am getting errors like this one:
plugin "Autelis Jandy 1.2.9.6" (pid 526) unexpectedly stopped -- restarting in 5 seconds
Reloading plugin "Autelis Jandy 1.2.9.6"
Starting plugin "Autelis Jandy 1.2.9.6" (pid 81558)
Started plugin "Autelis Jandy 1.2.9.6"
Autelis Jandy Your plugin version, v1.2.9.6, is current.
Autelis Jandy Saved Plugin Configuration
Autelis Jandy Error Socket: 192.168.X.X:6000 not open to close
Autelis Jandy Socket: 192.168.X.X:6000 connected succesfully
Trigger Pool Cleaner-ON
Any suggestions? The plugin functionality has become a great addition to my HA system, just hope to address this type of issues as is causing the plugin to not respond to the triggers until reloading it.
Thank in advance.
JP
Wed Jul 19, 2017 2:47 pm
hamw offline
Re: Autelis Jandy
Saw some posts over on the Autelis forum. Any advantage to upgrading to 1.6.2 from 1.4, which is what I am currently running?
Tue Jul 25, 2017 4:37 pm
hamw offline
Re: Autelis Jandy
I restart the plugin every six hours.
Sat Jul 29, 2017 6:24 am
nlagaros offline
Re: Autelis Jandy
Are you running the advanced firmware on the AquaLink? I'm cleaning up the plugin and want to properly support variable speed pumps, color lights, and salt water generators.
Sat Jul 29, 2017 10:13 am
nlagaros offline
Re: Autelis Jandy
I am re-rewriting some of the logic - should work better than the current code. What firmware to you have on your Jandy AquaLink?
JP
Sat Jul 29, 2017 11:31 am
roquej offline
Re: Autelis Jandy
Great news!
Using 1.6.9, the advance version.
JP
Tue Sep 19, 2017 7:02 pm
roquej offline
Re: Autelis Jandy
Any update on a new version?
Thank you in advance!
JP
Mon Oct 16, 2017 12:12 pm
Korey offline
Re: Autelis Jandy
Now with Autelis Firmware 1.6.13 out, my Pentair IntelliFlo pump data shows up in the Autelis web page. :D
Any chance of a plugin update so I can get this data into indigo?
Here is the data from the pumps.htm page:
Thanks.
<response>
<pumps>
<vsp1>3</vsp1>
<vsp1rpm>2200</vsp1rpm>
<vsp1watts>588</vsp1watts>
<vsp2/>
<vsp2rpm/>
<vsp2watts/>
<vsp3/>
<vsp3rpm/>
<vsp3watts/>
<vsp4/>
<vsp4rpm/>
<vsp4watts/>
</pumps>
</response>
Korey
Wed Dec 06, 2017 3:58 pm
Korey offline
Re: Autelis Jandy
Here is the data from the pumps.xml page:
Thanks.
<response>
<pumps>
<vsp1>3</vsp1>
<vsp2/>
<vsp2rpm/>
<vsp2watts/>
<vsp3/>
<vsp3rpm/>
<vsp3watts/>
<vsp4/>
<vsp4rpm/>
<vsp4watts/>
</pumps>
</response>
Anyone have any Idea how I can modify the plugin to get this data into Indigo? I've looked at the plugin code but it's a over my head.
Anyone?
Korey
