TED 2.0.0 Acting Up
Mon Jul 17, 2017 6:44 pm
HFTobeason offline
TED 2.0.0 Acting Up
Sometime in the last several weeks - not sure exactly - my TED 2.0.0 plugin started locking up. I don't know what changed, if anything.
Symptoms: The plugin will simply freeze up and stop polling. If I reload it, it will poll for a few minutes and then lock up again. Polling interval 5 seconds. Note that this behavior is new - I've never had an issue before.
I enabled debug, but that wasn't instructive - the plugin simply listed out all the polled values every five seconds - until it didn't.
Note that when I reload, I see this in the Indigo Log:
Jul 17, 2017, 5:32:39 PM
Reloading plugin "TED - The Energy Detective 2.0.0"
Stopping plugin "TED - The Energy Detective 2.0.0" (pid 760)
Jul 17, 2017, 5:32:54 PM
Error process (pid 760) failed to quit after polite request -- forcing it to quit now
Stopped plugin "TED - The Energy Detective 2.0.0"
Debugging plugin "TED - The Energy Detective 2.0.0" (pid 782)
Started plugin "TED - The Energy Detective 2.0.0"
TED - The Energy Detective Your plugin version, v2.0.0, is current.
TED - The Energy Detective Polling Interval: 5
I'd appreciate any ideas/solutions. Thank you!
EDIT: Forgot to list my config -- Indigo 7.0.3, macOS 10.12.5 (16F2073), TED 2.0.0, all running on a brand new iMac (Retina 5K, 27-inch, 2017)
Thu Jul 27, 2017 8:58 am
HFTobeason offline
Re: TED 2.0.0 Acting Up
Still suffering... BTW, direct access to my TED5000 via web browser works fine - so it's not the TED. Something is killing the plugin.
Thu Jul 27, 2017 12:24 pm
HFTobeason offline
Apparent solution...
After many hours of investigation, it seems that a very simply problem lay at the root of this issue... Namely, my TED 5000 unit had "lost" its time. It was reporting JAN01, 2000. I reset it to the correct time, with automatic updates through time.apple.com, and now all seems well...
