Japple55 wrote:nlagaros wrote:What version of OS X are you running? The IVONA announcements require Python 2.7.
El Capitan,
Python 2.7.10 (default, Jul 14 2015, 19:46:27)
[GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)] on darwin
El Capitan,
wideglidejrp wrote:The Sonos plugin does not show any detail inside of action groups. For lighting and switches, I can see what the device is. For a Sonos Player, I cannot see which one it is. Notice the volume settings for various rooms in the screenshot. When I want to make changes to the volume settings, I can't tell which one is which except by opening the actions. This is not productive. See screenshot.
nlagaros wrote:There should be a file called pyvona.input in the Sonos plugin directory as well as a script called pyvona_voices.py. The script will take the input file, make the call out and create the mp3 announcement. Would you try running that in a terminal and checking the output. The result should be the creation of a file called announcement.mp3 that is greater than zero bytes.
nlagaros wrote:You have to change to the directory with the script in it and run from there.
nlagaros wrote:Don't apologize. I'm a rookie myself. Would you download the latest update to the plugin and try the announcement again? I added a bunch of logging that makes the error pop-out more gracefully. We can examine the error output and hopefully figure out what is going on. Just one note: if it does error out, your Ivona key and password will be printed in the log .. don't want you pasting those in the forum!
Japple55 wrote:nlagaros wrote:Don't apologize. I'm a rookie myself. Would you download the latest update to the plugin and try the announcement again? I added a bunch of logging that makes the error pop-out more gracefully. We can examine the error output and hopefully figure out what is going on. Just one note: if it does error out, your Ivona key and password will be printed in the log .. don't want you pasting those in the forum!
Thanks for the warning. Here is what I got:
Trigger Alexa turn on switch announce to Sonos
Sonos Error IVONA Input: xxx
Sonos Error IVONA Input:xxx
Sonos Error IVONA Input: Jennifer
Sonos Error IVONA Input: 400
Sonos Error IVONA Input: medium
Sonos Error IVONA Input: This is a test of Ivona text to speech
Sonos Error IVONA Error: Traceback (most recent call last):
Sonos Error IVONA Error: File "./pyvona_voices.py", line 13, in <module>
Sonos Error IVONA Error: IVONAsentence_break = int(f.readline().rstrip('\n'))
Sonos Error IVONA Error: ValueError: invalid literal for int() with base 10: 'Jennifer'
Japple55 wrote:I assume you're referring to these lines: Sonos Error IVONA Input: xxx
I just ran it again and it appears to be 3 separate lines. Line 1 is the Ivona access key and lines 2 and 3 are the secret code, and they are identical.
Hope that helps.
Jim
nlagaros wrote:Can you check your plugin configuration and make sure you didn't type in the secret code twice - perhaps hidden with a carriage return??Japple55 wrote:I assume you're referring to these lines: Sonos Error IVONA Input: xxx
Hope that helps.
Jim
