Sonos Error Error getting Pandora feed
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 46, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 91, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 194, in checkDirect
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 181, in checkTopology
<type 'exceptions.NameError'>: global name 'zoneName' is not defined
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
nlagaros wrote:eme jota ce:
I see I have some old code in there for errors that I will have to clean up. What I think is the issue is that your root ZonePlayer is not contactable. Did you put the ip address of the reference ZonePlayer in the plugin configuration? That should solve this for now.
Sonos Debug Getting Plugin Configuration Settings
Sonos Debug Connection Type: Socket
Sonos Debug Reference ZP IP: 192.168.1.7
Sonos Debug Direct Poll: True
Sonos Debug Polling Interval: 1
Sonos Debug Pandora: True
Sonos Debug Pandora User ID: terrydew@me.com
Sonos Debug Pandora Email Address:terrydew@me.com
Sonos Debug SiriusXM: False
Sonos Saved Plugin Configuration
Sonos Debug Loading Playlists...
Sonos Debug <?xml version="1.0" encoding="utf-8"?>
<s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">
<s:Body>
<ns0:Browse xmlns:ns0="urn:schemas-upnp-org:service:ContentDirectory:1">
<InstanceID>0</InstanceID>
<ObjectID>SQ:</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter></Filter><StartingIndex>0</StartingIndex><RequestedCount>1000</RequestedCount><SortCriteria></SortCriteria>
</ns0:Browse>
</s:Body>
</s:Envelope>
Sonos Debug <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:16" parentID="SQ:" restricted="true"><dc:title>Acker Bilk</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#16</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:19" parentID="SQ:" restricted="true"><dc:title>AcKer Bilk Terry</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#19</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:25" parentID="SQ:" restricted="true"><dc:title>ben</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#25</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:13" parentID="SQ:" restricted="true"><dc:title>Ben</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#13</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:10" parentID="SQ:" restricted="true"><dc:title>Christmas</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#10</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:20" parentID="SQ:" restricted="true"><dc:title>Claironet + Memory</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#20</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:26" parentID="SQ:" restricted="true"><dc:title>Classical</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#26</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:22" parentID="SQ:" restricted="true"><dc:title>Country List</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#22</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:12" parentID="SQ:" restricted="true"><dc:title>Easy Listening</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#12</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:23" parentID="SQ:" restricted="true"><dc:title>Il Divo &amp; Enya</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#23</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:21" parentID="SQ:" restricted="true"><dc:title>Pictures</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#21</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:15" parentID="SQ:" restricted="true"><dc:title>POP</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#15</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:6" parentID="SQ:" restricted="true"><dc:title>Reading</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#6</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:27" parentID="SQ:" restricted="true"><dc:title>Ricky Nelson</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#27</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:11" parentID="SQ:" restricted="true"><dc:title>Sharon</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#11</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:9" parentID="SQ:" restricted="true"><dc:title>Terry</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#9</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:17" parentID="SQ:" restricted="true"><dc:title>TOP 50&apos;s</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#17</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:8" parentID="SQ:" restricted="true"><dc:title>Walk</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#8</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:24" parentID="SQ:" restricted="true"><dc:title>Xxxxx</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#24</res><upnp:class>object.container.playlistContainer</upnp:class></container></DIDL-Lite></Result><NumberReturned>19</NumberReturned><TotalMatches>19</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:16" parentID="SQ:" restricted="true"><dc:title>Acker Bilk</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#16</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:19" parentID="SQ:" restricted="true"><dc:title>AcKer Bilk Terry</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#19</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:25" parentID="SQ:" restricted="true"><dc:title>ben</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#25</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:13" parentID="SQ:" restricted="true"><dc:title>Ben</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#13</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:10" parentID="SQ:" restricted="true"><dc:title>Christmas</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#10</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:20" parentID="SQ:" restricted="true"><dc:title>Claironet + Memory</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#20</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:26" parentID="SQ:" restricted="true"><dc:title>Classical</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#26</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:22" parentID="SQ:" restricted="true"><dc:title>Country List</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#22</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:12" parentID="SQ:" restricted="true"><dc:title>Easy Listening</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#12</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:23" parentID="SQ:" restricted="true"><dc:title>Il Divo &amp; Enya</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#23</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:21" parentID="SQ:" restricted="true"><dc:title>Pictures</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#21</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:15" parentID="SQ:" restricted="true"><dc:title>POP</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#15</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:6" parentID="SQ:" restricted="true"><dc:title>Reading</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#6</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:27" parentID="SQ:" restricted="true"><dc:title>Ricky Nelson</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#27</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:11" parentID="SQ:" restricted="true"><dc:title>Sharon</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#11</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:9" parentID="SQ:" restricted="true"><dc:title>Terry</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#9</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:17" parentID="SQ:" restricted="true"><dc:title>TOP 50's</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#17</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:8" parentID="SQ:" restricted="true"><dc:title>Walk</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#8</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:24" parentID="SQ:" restricted="true"><dc:title>Xxxxx</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#24</res><upnp:class>object.container.playlistContainer</upnp:class></container></DIDL-Lite></Result><NumberReturned>19</NumberReturned><TotalMatches>19</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Playlist: SQ:16, Acker Bilk, file:///jffs/settings/savedqueues.rsq#16
Sonos Playlist: SQ:19, AcKer Bilk Terry, file:///jffs/settings/savedqueues.rsq#19
Sonos Playlist: SQ:25, ben, file:///jffs/settings/savedqueues.rsq#25
Sonos Playlist: SQ:13, Ben, file:///jffs/settings/savedqueues.rsq#13
Sonos Playlist: SQ:10, Christmas, file:///jffs/settings/savedqueues.rsq#10
Sonos Playlist: SQ:20, Claironet + Memory, file:///jffs/settings/savedqueues.rsq#20
Sonos Playlist: SQ:26, Classical, file:///jffs/settings/savedqueues.rsq#26
Sonos Playlist: SQ:22, Country List, file:///jffs/settings/savedqueues.rsq#22
Sonos Playlist: SQ:12, Easy Listening, file:///jffs/settings/savedqueues.rsq#12
Sonos Playlist: SQ:23, Il Divo & Enya, file:///jffs/settings/savedqueues.rsq#23
Sonos Playlist: SQ:21, Pictures, file:///jffs/settings/savedqueues.rsq#21
Sonos Playlist: SQ:15, POP, file:///jffs/settings/savedqueues.rsq#15
Sonos Playlist: SQ:6, Reading, file:///jffs/settings/savedqueues.rsq#6
Sonos Playlist: SQ:27, Ricky Nelson, file:///jffs/settings/savedqueues.rsq#27
Sonos Playlist: SQ:11, Sharon, file:///jffs/settings/savedqueues.rsq#11
Sonos Playlist: SQ:9, Terry, file:///jffs/settings/savedqueues.rsq#9
Sonos Playlist: SQ:17, TOP 50's, file:///jffs/settings/savedqueues.rsq#17
Sonos Playlist: SQ:8, Walk, file:///jffs/settings/savedqueues.rsq#8
Sonos Playlist: SQ:24, Xxxxx, file:///jffs/settings/savedqueues.rsq#24
Sonos Debug Loading RadioTime Favorite Stations...
<s:Body>
<ObjectID>R:0/0</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter></Filter><StartingIndex>0</StartingIndex><RequestedCount>1000</RequestedCount><SortCriteria></SortCriteria>
</ns0:Browse>
</s:Body>
</s:Envelope>
Sonos Debug <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/6" parentID="R:0/0" restricted="false"><dc:title>5-The 50s</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://www.xstreamxm.com/mobile/stream.asx?email=terrydew@comcast.net&amp;pass=ts7278&amp;chan=5&amp;speed=high</res></item><item id="R:0/0/7" parentID="R:0/0" restricted="false"><dc:title>73 Jazz XM</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://www.xstreamxm.com/mobile/stream.asx?email=terrydew@comcast.net&amp;pass=ts7278&amp;chan=73&amp;speed=high</res></item><item id="R:0/0/2" parentID="R:0/0" restricted="false"><dc:title>Avro Klassiek Best of</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://shoutcast.omroep.nl:8072/listen.pls</res></item><item id="R:0/0/1" parentID="R:0/0" restricted="false"><dc:title>Peach</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://www.radio-locator.com/cgi-bin/url?bc=y&amp;call=WLTM&amp;band=FM&amp;service=FM</res></item><item id="R:0/0/8" parentID="R:0/0" restricted="false"><dc:title>WGST</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s29162?sid=254&amp;flags=32</res></item></DIDL-Lite></Result><NumberReturned>5</NumberReturned><TotalMatches>5</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/6" parentID="R:0/0" restricted="false"><dc:title>5-The 50s</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://www.xstreamxm.com/mobile/stream.asx?email=terrydew@comcast.net&amp;pass=ts7278&amp;chan=5&amp;speed=high</res></item><item id="R:0/0/7" parentID="R:0/0" restricted="false"><dc:title>73 Jazz XM</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://www.xstreamxm.com/mobile/stream.asx?email=terrydew@comcast.net&amp;pass=ts7278&amp;chan=73&amp;speed=high</res></item><item id="R:0/0/2" parentID="R:0/0" restricted="false"><dc:title>Avro Klassiek Best of</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://shoutcast.omroep.nl:8072/listen.pls</res></item><item id="R:0/0/1" parentID="R:0/0" restricted="false"><dc:title>Peach</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://www.radio-locator.com/cgi-bin/url?bc=y&amp;call=WLTM&amp;band=FM&amp;service=FM</res></item><item id="R:0/0/8" parentID="R:0/0" restricted="false"><dc:title>WGST</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s29162?sid=254&amp;flags=32</res></item></DIDL-Lite></Result><NumberReturned>5</NumberReturned><TotalMatches>5</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos RadioTime Favorite Station: R:0/0/6, 5-The 50s, x-rincon-mp3radio://www.xstreamxm.com/mobile/stream.asx?email=terrydew@comcast.net&pass=ts7278&chan=5&speed=high
Sonos RadioTime Favorite Station: R:0/0/7, 73 Jazz XM, x-rincon-mp3radio://www.xstreamxm.com/mobile/stream.asx?email=terrydew@comcast.net&pass=ts7278&chan=73&speed=high
Sonos RadioTime Favorite Station: R:0/0/2, Avro Klassiek Best of, x-rincon-mp3radio://shoutcast.omroep.nl:8072/listen.pls
Sonos RadioTime Favorite Station: R:0/0/1, Peach, x-rincon-mp3radio://www.radio-locator.com/cgi-bin/url?bc=y&call=WLTM&band=FM&service=FM
Sonos RadioTime Favorite Station: R:0/0/8, WGST, x-sonosapi-stream:s29162?sid=254&flags=32
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 88, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 100, in initZones
<type 'exceptions.KeyError'>: key address not found in dict
Sonos Debug Method: runConcurrentThread
Sonos Debug Running Concurrent Thread
Sonos Debug Updating Device: Sonos Portable, State: GROUP_Coordinator, Value: true
Sonos Debug Updating Device: Sonos Portable, State: GROUP_Name, Value: RINCON_000E5888168C01400:22
Sonos Debug Updating Device: Sonos Living Room, State: GROUP_Coordinator, Value: false
Sonos Debug Updating Device: Sonos Living Room, State: GROUP_Name, Value: RINCON_000E581053BE01400:51
Sonos Debug Updating Device: Sonos Shop, State: GROUP_Coordinator, Value: false
Sonos Debug Updating Device: Sonos Shop, State: GROUP_Name, Value: RINCON_000E581053BE01400:51
Sonos Debug Updating Device: Sonos Sitting Room, State: GROUP_Coordinator, Value: false
Sonos Debug Updating Device: Sonos Sitting Room, State: GROUP_Name, Value: RINCON_000E581053BE01400:51
Sonos Debug Updating Device: Sonos Master BR, State: GROUP_Coordinator, Value: false
Sonos Debug Updating Device: Sonos Master BR, State: GROUP_Name, Value: RINCON_000E581053BE01400:51
Sonos Debug Updating Device: Sonos Library, State: GROUP_Coordinator, Value: true
Sonos Debug Updating Device: Sonos Library, State: GROUP_Name, Value: RINCON_000E581053BE01400:51
Sonos Debug Updating Device: Sonos Office, State: GROUP_Coordinator, Value: true
Sonos Debug Updating Device: Sonos Office, State: GROUP_Name, Value: RINCON_000E581053BE01400:52
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 92, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 197, in checkDirect
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 200, in checkOneDirect
