Sonos
Fri Dec 23, 2016 5:30 pm
nlagaros offline
Sonos v1.0.0 Update
v1.0.0 - 12/23/2016
  • Requires Indigo v7+.
  • Updated pyvona library to v1.2.1. Internalized IVONA announcements code.
  • Group announcements volume now accepts variable substitutions. Format is: %%v:[id]%%
  • Update mutagen library to v1.36.
  • Updated twisted library to v16.6.0.
  • Updated zope.interfaces library to v4.3.3.
  • Bug Fix: Support Spotify Connect direct control.
Download here: http://vulture.lagaros.com:8000/wordpress/home/sonos/
Wed Dec 28, 2016 7:14 pm
nlagaros offline
Sonos v1.0.2 Update
v1.0.2 - 12/28/2016
  • Support for Single Song Repeat (REPEAT_ONE) in Queue. Device State Q_RepeatOne reflects status.
  • Added action Queue Repeat Song to support new state.
  • Added action Queue Repeat Toggle that will cycle through no repeat, repeat full queue, repeat song.
  • Added action Queue Shuffle Toggle.
  • Smartened up group announcement with Group Coordinator Only such that it will find the master ZonePlayer if the selected device is a slave.
  • Added actions to Thumbs Up and Thumbs Down Pandora tracks.
Sun Apr 16, 2017 7:31 am
nlagaros offline
Re: Sonos v1.0.2 Update
v1.0.3 – 04/16/2017
  • Added auto discovery for Reference ZonePlayer.
  • Internalized import of ElementTree library that is packaged with Python 2.7.
  • Error handling around code that determines life-state of ZonePlayers.
Sat Jun 17, 2017 2:26 pm
nlagaros offline
Sonos v1.0.4 Update
v1.0.4 – 06/17/2017
  • Added support for Amazon Polly. To use this, you must create an AWS account (http://aws.amazon.com) and create a key and secret for Polly.
  • Added Channel Up/Down for SiriusXM.
Fri Jul 28, 2017 8:37 pm
nlagaros offline
Sonos v1.0.5 Update
v1.0.5 – 07/28/2017
  • Added support for local Apple voices for group announcements.
  • Library updates:
    • Requests v2.18.2
    • Twisted 17.5.0
    • zope.interfaces 4.4.2
    • service_identity 17.0.0
    • pyOpenSSL 17.2.0
    • gTTS 1.2.0
    • Mutagen 1.38
Sun Aug 06, 2017 4:28 am
nlagaros offline
Sonos v1.0.6 Update
v1.0.6 - 08/06/2017
  • Added six.moves library for gTTS
Tue Nov 21, 2017 3:09 pm
nlagaros offline
Sonos v1.0.7 Update
v1.0.7 – 11/21/2017
  • Re-wrote SiriusXM support.
  • Library updates:
    • SoCo v0.13 with customizations. Added back Event IP address in plugin configuration. Must open configuration dialog and enter Ip address of Indigo server.
    • Twisted 17.9.0
Wed Nov 22, 2017 8:24 am
nlagaros offline
Sonos v1.0.8 Update
v1.0.8 – 11/22/2017
  • Implemented event subscription checking (5 second interval).
Sun Nov 26, 2017 4:49 pm
nlagaros offline
Sonos v1.0.9 Update
v1.0.9 – 11/26/2017
  • Unicode bug fixes.
Download here: http://vulture.lagaros.com:8000/wordpress/home/sonos/[/quote]
Sun Mar 11, 2018 4:02 pm
nlagaros offline
Sonos v1.0.10 Update
v1.0.10 - 03/11/2018
  • Re-wrote SiriusXM support (again) with Sonos Music API.  Note that you now need to enter your SiriusXM ID and Password in the plugin configuration dialog.
  • Fixed Pandora station calls.
  • Fixed Playbar Home Theatre events.
  • Update SoCo to v0.14 with customizations.
Sat Mar 24, 2018 6:24 pm
nlagaros offline
Sonos v1.0.11 Update
v1.0.11 – 03/25/2018
  • Library Updates:
    • requests v2.18.4
    • pyOpenSSL v17.5.0
I also started cleaning up my download site and have plugin configuration notes as well as a couple of side posts for album art and testing. If anyone has other posts to contribute or wants me to reference any material from the past let me know and I will try to post it on the blog.
Sat Mar 31, 2018 7:48 pm
nlagaros offline
Sonos v1.0.12 Update
v1.0.12 – 03/31/2018
  • Bug Fix: Group Mute on ZonePlayer that is not coordinator of group.
  • Bug Fix: Syntactical errors on SiriusXM channel lineup.
  • Will error out ZonePlayer if not contactable on plugin startup.
  • Added plugin configuration interval options for checking ZonePlayer health and subscriptions.
  • Added state ZP_RELATIVE that should represent time into current track or program for supported sources.
Sun Apr 07, 2019 9:30 am
nlagaros offline
Sonos v1.0.13 Update
v1.0.13 – 04/07/2019
  • Code Fixes for Sonos Firmware v10.1
  • Library Updates:
    • Twisted v18.9.0
    • attr v18.1.0
    • pyOpenSSL 18.0.0
    • zope.interfaces v4.6.0
    • gTTS v2.0.0
    • gTTS-token v1.1.1
    • mutagen 1.41.1
    • requests 2.20.1
    • urllib3 1.24.1
I do not think this is backward compatible with Sonos firmware less than 10.1.
Download from the Plugin Store.
Sat Oct 19, 2019 5:02 pm
nlagaros offline
Sonos v1.0.16 Update
v1.0.16 - 10/19/2019
  • Reduced some error logging
  • Can play Spotify playlists and tracks from Sonos Favorites
  • Library Updates:
    • SoCo v0.18 with customizations
    • requests 2.22.0
    • Twisted v19.7.0
The SoCo library update is very significant. Please test and let me know if there are any issues.
Sat Mar 28, 2020 9:45 am
nlagaros offline
Sonos v1.0.17 Update
v1.0.17 – 03/28/2020
  • Variable substitution for Volume and Group Volume actions.
  • Library Updates:
    • SoCo v0.19 with customizations
    • requests 2.23.0
    • Twisted 20.0.3
    • zope.interfaces 5.0.1
    • pyOpenSSL 19.1.0
    • attrs v19.3.0
    • certifi v2019.11.28
