Sonos - The Beginning
Sun Aug 09, 2015 10:01 am
wideglidejrp offline
Re: Sonos - The Beginning
Text to speech worked. If using an MP3 file, where should the file be placed?
John R Patrick
Author of
Home Attitude
Sun Aug 09, 2015 2:16 pm
steinis offline
Thanks for updating the sonos plugin. But I can't seem to get the download link to work?
Fri Aug 14, 2015 5:45 am
nlagaros offline
In the plugin configuration, there is an option to enter the sound file path. You would set this to whatever directory you have your mp3 files in.
Fri Aug 14, 2015 5:46 am
nlagaros offline
Please try again. I had been working on my server when you attempted to download. Thanks.
Fri Aug 14, 2015 7:22 am
steinis offline
Thanks, working great noe:)
Fri Aug 14, 2015 4:03 pm
Hi Nick. I got a new router. Set everything up: new IP addresses for the devices, updated, config. Getting an error when I try to do something.
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 109, in actionMuteToggle
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-2 5.58.49 PM.indigoPlugin/Contents/Server Plugin/Sonos.py", line 724, in actionDirect
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
John R Patrick
Author of
Home Attitude
Wed Sep 09, 2015 11:40 am
richo offline
Hi, after upgrading to 0.8.13 I don'f see the status and also Volume UP/Down don't work with the following error in log:
  WebServer                       request to execute "Sonos" control #23 from 192.168.0.28
  File "plugin.py", line 121, in actionVolumeDown
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 741, in actionDirect
Looks like plugin can't get the system info from Sonos. Please have a look at this log:
Sonos Debug                     Getting Plugin Configuration Settings
  Sonos Debug                         Reference ZP IP:        192.168.0.121
  Sonos Debug                         Publish/Subscribe Port: 9999
  Sonos Debug                         HTTP Streaming IP:      192.168.0.190
  Sonos Debug                         HTTP Streaming Port:    8888
  Sonos Debug                         Sound File Path:        /Users/indigo/Music
  Sonos Debug                         Pandora:                False
  Sonos Debug                         Pandora User ID:
  Sonos Debug                         Pandora Email Address:
  Sonos Debug                         Pandora Password:       *****
  Sonos Debug                         SiriusXM:               False
  Sonos                           Saved Plugin Configuration
  Sonos Debug                     Loading Sonos Favorites...
  Sonos Debug                     zoneIP: 192.168.0.121, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
  Sonos                              Sonos Favorites: FV:2/26, 1.FM - 50s &amp; 60s, x-sonosapi-stream:s47713?sid=254&flags=32&sn=0
  Sonos                              Sonos Favorites: FV:2/2, 1.FM - Adore Jazz, x-sonosapi-stream:s74986?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/18, 1.FM - America's Best Ballads, x-sonosapi-stream:s98682?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/36, 1.FM - Bay Smooth Jazz, x-sonosapi-stream:s47723?sid=254&flags=32&sn=0
  Sonos                              Sonos Favorites: FV:2/33, 1.FM - Classic Rock, x-sonosapi-stream:s116726?sid=254&flags=32&sn=0
  Sonos                              Sonos Favorites: FV:2/16, 1.FM - Otto's Opera House, x-sonosapi-stream:s74990?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/21, AAA Soul Radio, x-sonosapi-stream:s150122?sid=254&flags=32&sn=0
  Sonos                              Sonos Favorites: FV:2/3, Guitar Jazz on JAZZRADIO.com, x-sonosapi-stream:s109603?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/34, Jazz ladies, x-file-cifs://iMacGabinet/iTunes/iTunes%20Library.xml#826C7E8ECECE84F5
  Sonos                              Sonos Favorites: FV:2/9, Nostalgie Italia, x-sonosapi-stream:s157618?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/5, Nostalgie Jazz, x-sonosapi-stream:s143747?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/8, Nostalgie Rock, x-sonosapi-stream:s66476?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/19, Piano Jazz on JAZZRADIO.com, x-sonosapi-stream:s109602?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/0, PR3 Trójka, x-sonosapi-stream:s15984?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/6, Radio Italia Anni 60, x-sonosapi-stream:s87513?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/35, Radio Rivieradolcissima, x-sonosapi-stream:s165937?sid=254&flags=32&sn=0
  Sonos                              Sonos Favorites: FV:2/1, RMF Classic, x-sonosapi-stream:s48202?sid=254&flags=32
  Sonos                              Sonos Favorites: FV:2/4, Zet Chilli 92.0 (Chill), x-sonosapi-stream:s15989?sid=254&flags=32
  Sonos Debug                     Loading Playlists...
  Sonos Debug                     ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:3" parentID="SQ:" restricted="true"><dc:title>Blues</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#3</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:6" parentID="SQ:" restricted="true"><dc:title>Christmas</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#6</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:4" parentID="SQ:" restricted="true"><dc:title>Classic</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#4</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:1" parentID="SQ:" restricted="true"><dc:title>Grzegorza</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#1</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:10" parentID="SQ:" restricted="true"><dc:title>Italian</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#10</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:7" parentID="SQ:" restricted="true"><dc:title>Jazz Ladies</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#7</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:5" parentID="SQ:" restricted="true"><dc:title>Nat I Frank</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#5</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:0" parentID="SQ:" restricted="true"><dc:title>Nice music</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#0</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:8" parentID="SQ:" restricted="true"><dc:title>Opera Ladies</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#8</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:11" parentID="SQ:" restricted="true"><dc:title>Pink ect</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#11</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:2" parentID="SQ:" restricted="true"><dc:title>Rock</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#2</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:9" parentID="SQ:" restricted="true"><dc:title>Tenory</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#9</res><upnp:class>object.container.playlistContainer</upnp:class></container></DIDL-Lite></Result><NumberReturned>12</NumberReturned><TotalMatches>12</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
  Sonos                              Playlist: SQ:3, Blues, file:///jffs/settings/savedqueues.rsq#3
  Sonos                              Playlist: SQ:6, Christmas, file:///jffs/settings/savedqueues.rsq#6
  Sonos                              Playlist: SQ:4, Classic, file:///jffs/settings/savedqueues.rsq#4
  Sonos                              Playlist: SQ:1, Grzegorza, file:///jffs/settings/savedqueues.rsq#1
  Sonos                              Playlist: SQ:10, Italian, file:///jffs/settings/savedqueues.rsq#10
  Sonos                              Playlist: SQ:7, Jazz Ladies, file:///jffs/settings/savedqueues.rsq#7
  Sonos                              Playlist: SQ:5, Nat I Frank, file:///jffs/settings/savedqueues.rsq#5
  Sonos                              Playlist: SQ:0, Nice music, file:///jffs/settings/savedqueues.rsq#0
  Sonos                              Playlist: SQ:8, Opera Ladies, file:///jffs/settings/savedqueues.rsq#8
  Sonos                              Playlist: SQ:11, Pink ect, file:///jffs/settings/savedqueues.rsq#11
  Sonos                              Playlist: SQ:2, Rock, file:///jffs/settings/savedqueues.rsq#2
  Sonos                              Playlist: SQ:9, Tenory, file:///jffs/settings/savedqueues.rsq#9
  Sonos Debug                     Loading RadioTime Favorite Stations...
  Sonos Debug                     ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/28" parentID="R:0/0" restricted="false"><dc:title>1.FM - Adore Jazz</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s74986?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/20" parentID="R:0/0" restricted="false"><dc:title>1.FM - America's Best Ballads</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s98682?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/27" parentID="R:0/0" restricted="false"><dc:title>AAA Soul Radio</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s150122?sid=254&amp;amp;flags=32&amp;amp;sn=0</res></item><item id="R:0/0/31" parentID="R:0/0" restricted="false"><dc:title>Nostalgie Italia</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s157618?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/32" parentID="R:0/0" restricted="false"><dc:title>Nostalgie Jazz</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s143747?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/30" parentID="R:0/0" restricted="false"><dc:title>Nostalgie Rock</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s66476?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/10" parentID="R:0/0" restricted="false"><dc:title>PR3 Trójka 99.9 (Variety)</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s76066?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/29" parentID="R:0/0" restricted="false"><dc:title>Radio Italia Anni 60</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s87513?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/11" parentID="R:0/0" restricted="false"><dc:title>RMF Classic 88.4 (Classic Hits)</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s76265?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/12" parentID="R:0/0" restricted="false"><dc:title>Zet Chilli 92.0 (Chill)</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s15989?sid=254&amp;amp;flags=32</res></item></DIDL-Lite></Result><NumberReturned>10</NumberReturned><TotalMatches>10</TotalMatches><UpdateID>1</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
  Sonos                              RadioTime Favorite Station: R:0/0/28, 1.FM - Adore Jazz, x-sonosapi-stream:s74986?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/20, 1.FM - America's Best Ballads, x-sonosapi-stream:s98682?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/27, AAA Soul Radio, x-sonosapi-stream:s150122?sid=254&flags=32&sn=0
  Sonos                              RadioTime Favorite Station: R:0/0/31, Nostalgie Italia, x-sonosapi-stream:s157618?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/32, Nostalgie Jazz, x-sonosapi-stream:s143747?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/30, Nostalgie Rock, x-sonosapi-stream:s66476?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/10, PR3 Trójka 99.9 (Variety), x-sonosapi-stream:s76066?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/29, Radio Italia Anni 60, x-sonosapi-stream:s87513?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/11, RMF Classic 88.4 (Classic Hits), x-sonosapi-stream:s76265?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/12, Zet Chilli 92.0 (Chill), x-sonosapi-stream:s15989?sid=254&flags=32
  Sonos Debug                     ZonePlayer: PM-Sonos Gabinet, Enabled: True
  Sonos Debug                     Resetting States for zone: 192.168.0.121
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_CREATOR, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_CurrentURI, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_ZoneName, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_LocalUID, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_AIName, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_AIPath, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_NALBUM, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_NART, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_NARTIST, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_NTRACK, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: Q_Crossfade, Value: off
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: Q_Repeat, Value: off
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: Q_Shuffle, Value: off
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: GROUP_Coordinator, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: GROUP_Name, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_CurrentTrack, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_CurrentTrackURI, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZoneGroupID, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZoneGroupName, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZonePlayerUUIDsInGroup, Value:
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_ZoneName, Value: Gabinet
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZP_LocalUID, Value: RINCON_000E58A5835001400
  Sonos Debug                     zoneIP: 192.168.0.121, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZoneGroupName, Value: Gabinet
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZoneGroupID, Value: RINCON_000E58A5835001400:44
  Sonos Debug                         Updating Device: PM-Sonos Gabinet, State: ZonePlayerUUIDsInGroup, Value: RINCON_000E58A5835001400
  Sonos                           Adding ZonePlayer: RINCON_000E58A5835001400
  Sonos Debug                     ZonePlayer: PM-Sonos Kuchnia, Enabled: True
  Sonos Debug                     Resetting States for zone: 192.168.0.122
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_CREATOR, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_CurrentURI, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_ZoneName, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_LocalUID, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_AIName, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_AIPath, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_NALBUM, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_NART, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_NARTIST, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_NTRACK, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: Q_Crossfade, Value: off
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: Q_Repeat, Value: off
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: Q_Shuffle, Value: off
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: GROUP_Coordinator, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: GROUP_Name, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_CurrentTrack, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_CurrentTrackURI, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZoneGroupID, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZoneGroupName, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZonePlayerUUIDsInGroup, Value:
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_ZoneName, Value: Kuchnia (L)
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZP_LocalUID, Value: RINCON_B8E937823E8C01400
  Sonos Debug                     zoneIP: 192.168.0.122, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZoneGroupName, Value: Kuchnia
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZoneGroupID, Value: RINCON_000E58A5835001400:43
  Sonos Debug                         Updating Device: PM-Sonos Kuchnia, State: ZonePlayerUUIDsInGroup, Value: RINCON_B8E937823E8C01400
  Sonos                           Adding ZonePlayer: RINCON_B8E937823E8C01400
  Sonos                           Subscribing on port: 9999
  Sonos                           SonosEvents INFO: Publishing on port: 9999
  Sonos                           Event Ignition...
  Sonos Debug                     SonosEvents: WARN  coherence                   Sep 09 19:38:08  Coherence UPnP framework version 0.6.6.2 starting... (coherence/base.py:283)
  Sonos Debug                     SonosEvents: WARN  coherence                   Sep 09 19:38:08  detection of own ip failed, using 127.0.0.1 as own address, functionality will be limited (coherence/base.py:308)
  Sonos Debug                     SonosEvents: WARN  webserver                   Sep 09 19:38:08  WebServer on port 49730 ready (coherence/base.py:124)
  Sonos Debug                     SonosEvents: ./lib/coherence/extern/louie.py:44: UserWarning: extern.louie will soon be deprecated in favor of coherence.dispatcher.
  Sonos Debug                     SonosEvents:   warnings.warn("extern.louie will soon be deprecated in favor of coherence.dispatcher.")
  Sonos Debug                     SonosEvents: Unhandled error in Deferred:
  Sonos Debug                     SonosEvents: Unhandled Error
  Sonos Debug                     SonosEvents: Traceback (most recent call last):
  Sonos Debug                     SonosEvents: Failure: twisted.internet.error.ProcessTerminated: A process has ended with a probable error condition: process ended with exit code 1.
  Sonos                           Serving HTTP Streamer on 192.168.0.190 [0.0.0.0], port 8888
Ryszard
Sat Dec 26, 2015 1:45 am
koensayr offline
Any thoughts or chance you'll add Apple Music to this?
Sat Dec 26, 2015 8:03 am
Apple Music already works with the plug-in. All you have to do is add something from Apple Music to your Sonos favorites. You can then select them from. The plugin.
John R Patrick
Author of
Home Attitude
Sat Dec 26, 2015 11:54 pm
koensayr offline
Can you elaborate a little bit more?
If I wanted to trigger playing of Apple Music from an Insteon action, what would I do?
Sun Dec 27, 2015 12:44 pm
Step one is to create an Action Group. Select a Sonos action such as Sonos Play Apple Music Smooth Jazz. Then create your trigger. A trigger can be any of many things such as a time of day, a mini remote button press, etc. Or if you are using an iPhone with the Indigo app, just select the Action Group.
John R Patrick
Author of
Home Attitude
Tue Dec 29, 2015 6:13 pm
koensayr offline
Thank you this is helpful, and I'll give this a try later tonight.
I have one other problem I'm working on though.
I'm trying to use a 6 Button KeypadLinc (model 2334-232) to control the Sonos. The middle four buttons used for next/previous and play/stop work perfectly.
I'm trying to use the two long buttons for volume up and volume down. I have the triggers working well, but I don't have the behavior of the backlight for the button quite right.
When I push the off (volume down) button, the light comes on and then stays off.
When I push the on, or top button (volume up), the light comes on and stays on. It only goes off after a volume down push.
Now I've tried to play around with Toggle Mode using Indigo's builtin in command, but it appears as if it has no effect. Last night I confirmed in the manual that this is indeed true. There is a note on page 12 that says you cannot change the behavior of the ON/OFF in a six button configuration.
So any thoughts on ideas on what I can do here? Has anybody else been able to come up with a clean way using either a 6 button or 8 button keypad to control sonos and volume cleanly?
-Josh
Tue Dec 29, 2015 8:59 pm
I have 20+ keypadlincs and constantly have issues. If you look at Insteon commands you will see a command to turn buttons on or off. This sometimes works but not always.
John R Patrick
Author of
Home Attitude
Wed Dec 30, 2015 12:46 am
koensayr offline
We all have problems with the KPLs :-)
What I am saying is I'm aware of those on/off commands, and the idea of using a PowerLinc scene to control them more reliably.
I guess what I'm asking is: Do you or anybody else on the forum use a KPL to control a Sonos device including the volume? If so, I'd really like some ideas, either for 6 or 8 button configs.
Thu Dec 31, 2015 10:07 am
I have experimented with KPL to control music volume, mute, and channel change. A better solution for me has been using the handheld or desk mini remotes such as the following. I use both of them for music control.
http://smile.amazon.com/Aeon-Labs-DSA03 ... s=minimote
http://www.smarthome.com/insteon-2342-2 ... scene.html
John R Patrick
Author of
Home Attitude
Users browsing this forum: Google [Bot] and 9 guests
