Sonos - The Beginning
Wed Mar 14, 2012 10:48 am
terrydew offline
Re: Sonos - The Beginning
nlagaros
With polling off, I have been playing, stopping vol up dn next and previous on 2 zones with correct function and no errors!!
If I issue either a line-in or playlist, errors are generated and either plug-in has to be reloaded or sometimes restart sonospy. Sounds like you identified the line-in problem with names so I think it may be stable without polling. Suggestion that worked on another plug-in is to make the polling rate user settable so we can see at what rate/timing (if any) the polling is stable for a given setup.
I am very encouraged today as it is basically working as needed.
I hope after the basics you will add method to group/ungroup zones and a way to remember zone setup for announcements.
I have a lead on a zone player I let my son's fraternity house use that I may be able to get back. If so, I would be willing to send to you for testing. Would you please pm me and we can discuss.
Thanks for your efforts
Terry
Wed Mar 14, 2012 12:14 pm
terrydew offline
deleted
Wed Mar 14, 2012 7:00 pm
nlagaros offline
I have yet another release (v0.2.7) with what I believe to be correct Liine-In code. Terry - polling on/off should not have an impact on whether the plugin crashes or not. I do take your point on creating a variable for polling interval - I will try to wrap that in to the next release.
I did have an error on the reference zone - where a space in the name like you had created an issue. Give this latest release a shot. I think it will work a bit better. There will be some errors thrown on startup (figuring out line-in names) - this is normal.
Wed Mar 14, 2012 7:05 pm
nlagaros offline
Terry - thanks for all the testing and debug outputs. It has helped considerably getting to this point. Once I nail all of the basic functionality, I will look at the grouping.
I may also try to package SonosPy in and create some config UI for it, but that is a low priority at this point. Time is limited to work on this.
Wed Mar 14, 2012 7:52 pm
terrydew offline
No luck with 2.7. With polling off I get the following
Mar 14, 2012 9:40:00 PM
  Reloading plugin "Sonos 0.2.7"
  Stopping plugin "Sonos 0.2.7" (pid 8778)
  Sonos Debug                     Method: stopConcurrentThread
  Sonos Debug                     Method: shutdown
  Plugin "Sonos" disconnected
  Starting plugin "Sonos 0.2.7" (pid 8797)
  Plugin "Sonos" connected
  Plugin "Sonos 0.2.7" started
  Sonos Debug                     Getting Plugin Configuration Settings
  Sonos Debug                         Connection Type: Socket
  Sonos Debug                         Socket IP:            192.168.1.202
  Sonos Debug                         Socket Port:          50101
  Sonos Debug                         Reference ZonePlayer: Portable
  Sonos                           Saved Plugin Configuration
  Sonos                           Loading ZonePlayers...
  Sonos Debug                     Message: http://192.168.1.202:50101/data/deviceData
  Sonos Debug                     http://192.168.1.202:50101/data/deviceData
  Sonos Debug                     R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::Guest Room (ZP)_|_R::Guest Room (ZP)_|_R::Library (ZP)_|_R::Master Bedroom (ZP)_|_R::Office (ZP)_|_R::Portable (ZP)_|_R::Shop (ZP)_|_R::Sitting Room (ZP)_|_S::DIRECTV2PC Media Server_|_S::DIRECTV2PC Media Server_|_S::DIRECTV2PC Media Server_|_S::Guest Room (ZP)_|_S::Guest Room (ZP)_|_S::Library (ZP)_|_S::Master Bedroom (ZP)_|_S::Office (ZP)_|_S::Portable (ZP)_|_S::Shop (ZP)_|_S::Sitting Room (ZP)_|_
  Sonos                              ZonePlayer: Guest Room (ZP)
  Sonos                              ZonePlayer: Library (ZP)
  Sonos                              ZonePlayer: Master Bedroom (ZP)
  Sonos                              ZonePlayer: Office (ZP)
  Sonos                              ZonePlayer: Portable (ZP)
  Sonos                              ZonePlayer: Shop (ZP)
  Sonos                              ZonePlayer: Sitting Room (ZP)
  Sonos                           ----------------------------------------
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rootData?data=S::Portable%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rootData?data=S::Portable%20%28ZP%29
  Sonos Debug                     1::R::NONE::AUPEO!_|_2::R::NONE::DAR.fm Record Radio_|_3::R::NONE::Deezer_|_4::R::NONE::Global Search_|_5::R::NONE::iheartradio_|_6::R::NONE::Juke_|_7::R::NONE::Juke_|_8::R::NONE::Mac Mini_|_9::R::NONE::MOG_|_10::R::NONE::Music Library_|_11::R::NONE::Music Shares_|_12::R::NONE::Napster_|_13::R::NONE::QQ音乐_|_14::R::NONE::RadioTime_|_15::R::NONE::Rdio_|_16::R::NONE::Slacker_|_17::R::NONE::Songl_|_18::R::NONE::Sonora_|_19::R::NONE::Sonos Playlists_|_20::R::NONE::Spotify_|_21::R::NONE::Spotify_|_22::R::NONE::Stitcher SmartRadio_|_23::R::NONE::Twitter_|_24::R::NONE::WiMP_|_25::R::NONE::Wolfgang's Vault_|_26::R::NONE::多米音乐_|_MESSAGE::_|_
  Sonos Debug                     Loading Playlists...
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Portable%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Portable%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Portable
  Sonos Debug                     Message: http://192.168.1.202:50101/data/getData?data=19::R::NONE::Sonos%20Playlists::1,0,100
  Sonos Debug                     http://192.168.1.202:50101/data/getData?data=19::R::NONE::Sonos%20Playlists::1,0,100
  Sonos Debug                     19_1::C::ZP_LIST::Acker Bilk::SQ:16::SONOSMUSICSERVER_|_19_2::C::ZP_LIST::AcKer Bilk Terry::SQ:19::SONOSMUSICSERVER_|_19_3::C::ZP_LIST::ben::SQ:25::SONOSMUSICSERVER_|_19_4::C::ZP_LIST::Ben::SQ:13::SONOSMUSICSERVER_|_19_5::C::ZP_LIST::Christmas::SQ:10::SONOSMUSICSERVER_|_19_6::C::ZP_LIST::Claironet +  Memory::SQ:20::SONOSMUSICSERVER_|_19_7::C::ZP_LIST::Classical::SQ:26::SONOSMUSICSERVER_|_19_8::C::ZP_LIST::Country List::SQ:22::SONOSMUSICSERVER_|_19_9::C::ZP_LIST::Easy Listening::SQ:12::SONOSMUSICSERVER_|_19_10::C::ZP_LIST::Il Divo & Enya::SQ:23::SONOSMUSICSERVER_|_19_11::C::ZP_LIST::Pictures::SQ:21::SONOSMUSICSERVER_|_19_12::C::ZP_LIST::POP::SQ:15::SONOSMUSICSERVER_|_19_13::C::ZP_LIST::Reading::SQ:6::SONOSMUSICSERVER_|_19_14::C::ZP_LIST::Rick Nelson::SQ:14::SONOSMUSICSERVER_|_19_15::C::ZP_LIST::Sharon::SQ:11::SONOSMUSICSERVER_|_19_16::C::ZP_LIST::Terry::SQ:9::SONOSMUSICSERVER_|_19_17::C::ZP_LIST::TOP 50's::SQ:17::SONOSMUSICSERVER_|_19_18::C::ZP_LIST::Walk::SQ:8::SONOSMUSICSERVER_|_19_19::C::ZP_LIST::Xxxxx::SQ:24::SONOSMUSICSERVER_|_RETURN::19:19_|_
  Sonos Debug                        Playlist: SQ:16, Acker Bilk
  Sonos Debug                        Playlist: SQ:19, AcKer Bilk Terry
  Sonos Debug                        Playlist: SQ:25, ben
  Sonos Debug                        Playlist: SQ:13, Ben
  Sonos Debug                        Playlist: SQ:10, Christmas
  Sonos Debug                        Playlist: SQ:20, Claironet +  Memory
  Sonos Debug                        Playlist: SQ:26, Classical
  Sonos Debug                        Playlist: SQ:22, Country List
  Sonos Debug                        Playlist: SQ:12, Easy Listening
  Sonos Debug                        Playlist: SQ:23, Il Divo & Enya
  Sonos Debug                        Playlist: SQ:21, Pictures
  Sonos Debug                        Playlist: SQ:15, POP
  Sonos Debug                        Playlist: SQ:6, Reading
  Sonos Debug                        Playlist: SQ:14, Rick Nelson
  Sonos Debug                        Playlist: SQ:11, Sharon
  Sonos Debug                        Playlist: SQ:9, Terry
  Sonos Debug                        Playlist: SQ:17, TOP 50's
  Sonos Debug                        Playlist: SQ:8, Walk
  Sonos Debug                        Playlist: SQ:24, Xxxxx
  Sonos Debug                     ----------------------------------------
  Sonos Debug                     Loading RadioTime file
  Sonos Debug                     Radio_Continents: Africa
  Sonos Debug                     Radio_Continents: Asia
  Sonos Debug                     Radio_Continents: Australasia
  Sonos Debug                     Radio_Continents: Central America
  Sonos Debug                     Radio_Continents: Europe
  Sonos Debug                     Radio_Continents: North America
  Sonos Debug                     Radio_Continents: South America
  Sonos Debug                     Resetting States for zone: Guest%20Room
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_AIName, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_AIPath, Value:
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rootData?data=S::Guest%20Room%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rootData?data=S::Guest%20Room%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Guest%20Room
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Guest%20Room%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Guest%20Room%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/getData?data=NOCHANGE::0::0::0::1,0,100
  Sonos Debug                     http://192.168.1.202:50101/data/getData?data=NOCHANGE::0::0::0::1,0,100
  Sonos Debug
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 46, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 78, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 502, in getLineIn
<type 'exceptions.IndexError'>: list index out of range
  Sonos Error                     plugin runConcurrentThread function returned or failed; will attempt again in 10 seconds
  Sonos Debug                     Method: runConcurrentThread
  Sonos Debug                     Running Concurrent Thread
Listed below is log with two action linen commands to the Portable zone. The first was as is. For the second I changed the line in name in sons to LineIn. Neither worked.
Mar 14, 2012 9:45:58 PM
  Action Group                    Sonos Portable Line In
  Sonos Debug                     Sonos Action:
  Sonos Debug                     QUEUE::QQ::R::ZP_QUEUE::Current Queue_|_
  Sonos Debug                     Playing LineIn: ...
Mar 14, 2012 9:47:20 PM
Wed Mar 14, 2012 8:05 pm
nlagaros offline
Strange. Quick question: do you have two ZonePayers with the same name (Guest Room)? I would not know how to distinguish between the two if that were the case.
Wed Mar 14, 2012 8:06 pm
terrydew offline
With polling and debug on it is continuous in the log so I captured a sample. Without debug it is just a continuous stream of errors
  Enabling plugin "Sonos 0.2.7"
  Starting plugin "Sonos 0.2.7" (pid 9115)
  Sonos Debug                     1::R::NONE::AUPEO!_|_2::R::NONE::DAR.fm Record Radio_|_3::R::NONE::Deezer_|_4::R::NONE::Global Search_|_5::R::NONE::iheartradio_|_6::R::NONE::Juke_|_7::R::NONE::Juke_|_8::R::NONE::LineIn_|_9::R::NONE::MOG_|_10::R::NONE::Music Library_|_11::R::NONE::Music Shares_|_12::R::NONE::Napster_|_13::R::NONE::QQ音乐_|_14::R::NONE::RadioTime_|_15::R::NONE::Rdio_|_16::R::NONE::Slacker_|_17::R::NONE::Songl_|_18::R::NONE::Sonora_|_19::R::NONE::Sonos Playlists_|_20::R::NONE::Spotify_|_21::R::NONE::Spotify_|_22::R::NONE::Stitcher SmartRadio_|_23::R::NONE::Twitter_|_24::R::NONE::WiMP_|_25::R::NONE::Wolfgang's Vault_|_26::R::NONE::多米音乐_|_MESSAGE::_|_
  Sonos Debug
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Guest%20Room%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Guest%20Room%20%28ZP%29
  Sonos Debug                     POSITION::_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                     Parsing:Guest%20Room:POSITION::_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_STATE, Value: STOPPED
  Sonos Debug                     NOCHANGE::0_|_
  Sonos Debug                     Parsing:Guest%20Room:NOCHANGE::0_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Library%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Library%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Library%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Library%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Library%20%28ZP%29
  Sonos Debug                     POSITION::0:00:00_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                     Parsing:Library:POSITION::0:00:00_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_POSITION, Value: 0:00:00
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_STATE, Value: STOPPED
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_ART, Value:
  Sonos Debug                     Parsing:Library:NOCHANGE::0_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Master%20Bedroom%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Master%20Bedroom%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Master%20Bedroom%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Master%20Bedroom%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Master%20Bedroom%20%28ZP%29
  Sonos Debug                     POSITION::0:00:09 / 0:02:44_|_PERCENT::5.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                     Parsing:Master%20Bedroom:POSITION::0:00:09 / 0:02:44_|_PERCENT::5.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_POSITION, Value: 0:00:09 / 0:02:44
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_PERCENT, Value: 5.0
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_STATE, Value: STOPPED
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_ART, Value:
  Sonos Debug                     Parsing:Master%20Bedroom:NOCHANGE::0_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Office%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Office%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Office%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Office%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Office%20%28ZP%29
  Sonos Debug                     POSITION::0:00:00 / 0:03:25_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                     Parsing:Office:POSITION::0:00:00 / 0:03:25_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_POSITION, Value: 0:00:00 / 0:03:25
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_STATE, Value: STOPPED
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_ART, Value:
  Sonos Debug                     Parsing:Office:NOCHANGE::0_|_
  Sonos Error                     Error getting ZonePlayer data: Portable%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Portable%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Portable%20%28ZP%29
  Sonos Debug                     Parsing:Portable:POSITION::0:00:00_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_POSITION, Value: 0:00:00
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_STATE, Value: STOPPED
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_ART, Value:
  Sonos Debug                     Parsing:Portable:NOCHANGE::0_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Shop%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Shop%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Shop%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Shop%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Shop%20%28ZP%29
  Sonos Debug                     Parsing:Shop:POSITION::0:00:00_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_POSITION, Value: 0:00:00
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_STATE, Value: STOPPED
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_ART, Value:
  Sonos Debug                     Parsing:Shop:NOCHANGE::0_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Sitting%20Room%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Sitting%20Room%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Sitting%20Room%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Sitting%20Room%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Sitting%20Room%20%28ZP%29
  Sonos Debug                     Parsing:Sitting%20Room:POSITION::0:00:00_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_POSITION, Value: 0:00:00
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_STATE, Value: STOPPED
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_ART, Value:
  Sonos Debug                     Parsing:Sitting%20Room:NOCHANGE::0_|_
  Sonos Error                     Error getting ZonePlayer data: Guest%20Room%20%28ZP%29
Wed Mar 14, 2012 8:09 pm
nlagaros offline
Thanks for the logs. This is still all related to the Line-in code. Will work through it and get a release out on Friday latest.
Wed Mar 14, 2012 8:18 pm
terrydew offline
I have two play 3's setup in sonos to play stereo. One plays the left channel and one the right. I haven't tested for a few versions but it was working but now is not. Sonos only shows one zone, but two zones are shown in sonospy. When I first setup the device I just typed in Guest Bedroom. Now with the new device drop down it lists two?
Thu Mar 15, 2012 2:36 am
mat offline
Ended up working late last night so never got to test. You guys are progressing at some speed. Can't wait to see how it works here.
Late 2018 mini 10.14
Thu Mar 15, 2012 4:57 pm
mat offline
I too have the same errors as Terry with line in. I too have renamed.
All other functions are working perfectly! Great work.
Not tried radio yet.
One more thing to add that I think would be useful at this stage is "switch to queue". I have this working through AppleScript still. When you have line in selected, you can switch a zone back to the previous queue.
Unfortunately my AppleScript only restarts the current queue from the beginning again. I guess that leads onto another function - "annouce" which would save queue position or current playing, switch to line in for announcement, then switch back to current position. Just something to add to the list, for another day :shock:
Let me know if you need anything from me!
I still seem to have lots of python threads. 2000+ are we parking that issue for now, or do you want me to look into what's happening?
Regards and great work! So excited about this working! Thanks again!
Thu Mar 15, 2012 6:32 pm
mat offline
I've noticed that when the tread count reaches 2040 the plugin stops working. I have to restart sonospy, and occasionally the plugin.
This takes about 5 minutes.
Fri Mar 16, 2012 7:11 pm
nlagaros offline
Thanks for continuing to test! I have an update (0.2.8) that corrects a small logic issue with the Line-In. It needed to be smartened up to know when a Zone does not have a Line-In or can't be queried for one. I also added the Polling Interval.
I'm going to spend some more time on the threading issue. I'll likely have another update tomorrow. If I can get through the threading issue, I will move on to the queue functionality.
Fri Mar 16, 2012 7:30 pm
nlagaros offline
mat - if you have polling off, does the thread count still increase?
Sat Mar 17, 2012 5:19 am
nlagaros offline
Once I am able to have two ZonePlayers running, I will figure out how to handle two units with the same name. SonosPy asks for the ZonePlayer name, not any other identifier, so that will be tricky. I'm going to re-work the Line-In action so it lists all available Line-In sources instead of prompting for a ZonePlayer. Think that is more intuitive.
Page 10 of 37 1 ... 7, 8, 9, 10, 11, 12, 13 ... 37
