Sonos - The Beginning
Tue Mar 13, 2012 5:30 pm
nlagaros offline
Re: Sonos - The Beginning
terrydew:
It still appears that you are not running the latest SonsoPy extensions. The following query should have a Line-In entry:
  Sonos Debug                     R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::DIRECTV Mediashare Renderer_|_R::Guest Room (ZP)_|_R::Guest Room (ZP)_|_R::Library (ZP)_|_R::Master Bedroom (ZP)_|_R::Office (ZP)_|_R::Portable (ZP)_|_R::Shop (ZP)_|_R::Sitting Room (ZP)_|_S::DIRECTV2PC Media Server_|_S::DIRECTV2PC Media Server_|_S::DIRECTV2PC Media Server_|_S::Guest Room (ZP)_|_S::Guest Room (ZP)_|_S::Library (ZP)_|_S::Master Bedroom (ZP)_|_S::Office (ZP)_|_S::Portable (ZP)_|_S::Shop (ZP)_|_S::Sitting Room (ZP)_|_
The filename from the github download should have been: henkelis-sonospy-13d1950.zip Can you verify this? Nonetheless, I've put up a new revision that will bypass Line-In queries if it is not found in the root list.
Tue Mar 13, 2012 5:33 pm
nlagaros offline
Another release... v0.2.6 with the following fixes:
  • Device setup now a pulldown menu with available ZonePlayers
  • Line-In will not be queried if path not found
Tue Mar 13, 2012 5:37 pm
nlagaros offline
terry - I looked through all the debug log postings (thanks very much for that!) and it appears all is related to Line-In not being picked up on plugin initialization. I'm hopeful it is due to the SonosPy not being the most current unstable branch. You can bring up the SonosPy web interface and if you click on one of your ZonePlayers as a server you should see Line-In in the list of available sources.
Let me know if you need help validating that SonosPy is running properly.
Tue Mar 13, 2012 6:05 pm
nlagaros offline
Sorry Terry, I meant this query should have the Line-In Entry:
  Sonos Debug                     1::R::NONE::AUPEO!_|_2::R::NONE::Deezer_|_3::R::NONE::Global Search_|_4::R::NONE::iheartradio_|_5::R::NONE::Juke_|_6::R::NONE::Juke_|_7::R::NONE::Mac Mini_|_8::R::NONE::MOG_|_9::R::NONE::Music Library_|_10::R::NONE::Music Shares_|_11::R::NONE::Napster_|_12::R::NONE::QQ音乐_|_13::R::NONE::RadioTime_|_14::R::NONE::Rdio_|_15::R::NONE::Slacker_|_16::R::NONE::Songl_|_17::R::NONE::Sonora_|_18::R::NONE::Sonos Playlists_|_19::R::NONE::Spotify_|_20::R::NONE::Spotify_|_21::R::NONE::Stitcher SmartRadio_|_22::R::NONE::Twitter_|_23::R::NONE::WiMP_|_24::R::NONE::Wolfgang's Vault_|_25::R::NONE::多米音乐_|_MESSAGE::_|_
Tue Mar 13, 2012 6:07 pm
nlagaros offline
Here is my debug output for comparison:
  Sonos Debug                     Message: http://192.168.0.5:50101/data/rootData?data=S::Russound%20%28ZP%29
  Sonos Debug                     http://192.168.0.5:50101/data/rootData?data=S::Russound%20%28ZP%29
  Sonos Debug                     1::R::NONE::AUPEO!_|_2::R::NONE::Deezer_|_3::R::NONE::Global Search_|_4::R::NONE::iheartradio_|_5::R::NONE::Juke_|_6::R::NONE::Juke_|_7::R::NONE::Line-In_|_8::R::NONE::MOG_|_9::R::NONE::Music Library_|_10::R::NONE::Music Shares_|_11::R::NONE::Napster_|_12::R::NONE::QQ音乐_|_13::R::NONE::RadioTime_|_14::R::NONE::Rdio_|_15::R::NONE::Slacker_|_16::R::NONE::Songl_|_17::R::NONE::Sonora_|_18::R::NONE::Sonos Playlists_|_19::R::NONE::Spotify_|_20::R::NONE::Spotify_|_21::R::NONE::Stitcher SmartRadio_|_22::R::NONE::Twitter_|_23::R::NONE::WiMP_|_24::R::NONE::Wolfgang's Vault_|_25::R::NONE::多米音乐_|_MESSAGE::Returned 80 of 80._|_
Tue Mar 13, 2012 6:10 pm
nlagaros offline
OK - I think I figured it out. Terry - your Line-In is called Mac Mini. I was under the impression that Line-In was the hardcoded name. I need to mess around for a few and see how I can dynamically validate the Line-In sources. In the Sonos Desktop Controller, can you tell me what is listed there?
Thanks.
Tue Mar 13, 2012 6:18 pm
nlagaros offline
So mat - you will have an issue to with Line-In, unless it is called just that. I have some work to do. I'm guessing that I will have to query each ZonePlayer to get the Line-In name and detect if it is fact a Line-In. If you could also go the the Line-In tab in the desktop controller and give me a screen shot, that would be helpful. Also, if you change the Reference ZonePlayer to each device that has a Line-In and startup in debug mode, I will then understand from the output how I need to code it. This is too difficult with just one ZonePlayer!!
Tue Mar 13, 2012 6:32 pm
terrydew offline
Yes I checked the enclosing folder and it was 13d1950. To be sure I deleted rebooted and downloaded again.
Loaded V 2.6 and turned polling on and debug on
Results
Reloading plugin "Sonos 0.2.6"
  Stopping plugin "Sonos 0.2.6" (pid 682)
  Sonos Debug                     Method: stopConcurrentThread
  Sonos Debug                     Method: shutdown
  Plugin "Sonos" disconnected
  Starting plugin "Sonos 0.2.6" (pid 696)
  Plugin "Sonos" connected
  Plugin "Sonos 0.2.6" started
  Sonos Debug                     Getting Plugin Configuration Settings
  Sonos Debug                         Connection Type: Socket
  Sonos Debug                         Socket IP:            192.168.1.202
  Sonos Debug                         Socket Port:          50101
  Sonos Debug                         Reference ZonePlayer: Office
  Sonos                           Saved Plugin Configuration
  Sonos                           Loading ZonePlayers...
  Sonos Debug                     Message: http://192.168.1.202:50101/data/deviceData
  Sonos Debug                     http://192.168.1.202:50101/data/deviceData
  Sonos                              ZonePlayer: Guest Room (ZP)
  Sonos                              ZonePlayer: Library (ZP)
  Sonos                              ZonePlayer: Master Bedroom (ZP)
  Sonos                              ZonePlayer: Office (ZP)
  Sonos                              ZonePlayer: Portable (ZP)
  Sonos                              ZonePlayer: Shop (ZP)
  Sonos                              ZonePlayer: Sitting Room (ZP)
  Sonos                           ----------------------------------------
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rootData?data=S::Office%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rootData?data=S::Office%20%28ZP%29
  Sonos Debug                     1::R::NONE::AUPEO!_|_2::R::NONE::Deezer_|_3::R::NONE::Global Search_|_4::R::NONE::iheartradio_|_5::R::NONE::Juke_|_6::R::NONE::Juke_|_7::R::NONE::Mac Computer_|_8::R::NONE::MOG_|_9::R::NONE::Music Library_|_10::R::NONE::Music Shares_|_11::R::NONE::Napster_|_12::R::NONE::QQ音乐_|_13::R::NONE::RadioTime_|_14::R::NONE::Rdio_|_15::R::NONE::Slacker_|_16::R::NONE::Songl_|_17::R::NONE::Sonora_|_18::R::NONE::Sonos Playlists_|_19::R::NONE::Spotify_|_20::R::NONE::Spotify_|_21::R::NONE::Stitcher SmartRadio_|_22::R::NONE::Twitter_|_23::R::NONE::WiMP_|_24::R::NONE::Wolfgang's Vault_|_25::R::NONE::多米音乐_|_MESSAGE::_|_
  Sonos Debug                     Loading Playlists...
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Office%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Office%20%28ZP%29
  Sonos Debug                     QUEUE::QQ::R::ZP_QUEUE::Current Queue_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/getData?data=18::R::NONE::Sonos%20Playlists::1,0,100
  Sonos Debug                     http://192.168.1.202:50101/data/getData?data=18::R::NONE::Sonos%20Playlists::1,0,100
  Sonos Debug                     18_1::C::ZP_LIST::Acker Bilk::SQ:16::SONOSMUSICSERVER_|_18_2::C::ZP_LIST::AcKer Bilk Terry::SQ:19::SONOSMUSICSERVER_|_18_3::C::ZP_LIST::ben::SQ:25::SONOSMUSICSERVER_|_18_4::C::ZP_LIST::Ben::SQ:13::SONOSMUSICSERVER_|_18_5::C::ZP_LIST::Christmas::SQ:10::SONOSMUSICSERVER_|_18_6::C::ZP_LIST::Claironet +  Memory::SQ:20::SONOSMUSICSERVER_|_18_7::C::ZP_LIST::Classical::SQ:26::SONOSMUSICSERVER_|_18_8::C::ZP_LIST::Country List::SQ:22::SONOSMUSICSERVER_|_18_9::C::ZP_LIST::Easy Listening::SQ:12::SONOSMUSICSERVER_|_18_10::C::ZP_LIST::Il Divo & Enya::SQ:23::SONOSMUSICSERVER_|_18_11::C::ZP_LIST::Pictures::SQ:21::SONOSMUSICSERVER_|_18_12::C::ZP_LIST::POP::SQ:15::SONOSMUSICSERVER_|_18_13::C::ZP_LIST::Reading::SQ:6::SONOSMUSICSERVER_|_18_14::C::ZP_LIST::Rick Nelson::SQ:14::SONOSMUSICSERVER_|_18_15::C::ZP_LIST::Sharon::SQ:11::SONOSMUSICSERVER_|_18_16::C::ZP_LIST::Terry::SQ:9::SONOSMUSICSERVER_|_18_17::C::ZP_LIST::TOP 50's::SQ:17::SONOSMUSICSERVER_|_18_18::C::ZP_LIST::Walk::SQ:8::SONOSMUSICSERVER_|_18_19::C::ZP_LIST::Xxxxx::SQ:24::SONOSMUSICSERVER_|_RETURN::19:19_|_
  Sonos Debug                        Playlist: SQ:16, Acker Bilk
  Sonos Debug                        Playlist: SQ:19, AcKer Bilk Terry
  Sonos Debug                        Playlist: SQ:25, ben
  Sonos Debug                        Playlist: SQ:13, Ben
  Sonos Debug                        Playlist: SQ:10, Christmas
  Sonos Debug                        Playlist: SQ:20, Claironet +  Memory
  Sonos Debug                        Playlist: SQ:26, Classical
  Sonos Debug                        Playlist: SQ:22, Country List
  Sonos Debug                        Playlist: SQ:12, Easy Listening
  Sonos Debug                        Playlist: SQ:23, Il Divo & Enya
  Sonos Debug                        Playlist: SQ:21, Pictures
  Sonos Debug                        Playlist: SQ:15, POP
  Sonos Debug                        Playlist: SQ:6, Reading
  Sonos Debug                        Playlist: SQ:14, Rick Nelson
  Sonos Debug                        Playlist: SQ:11, Sharon
  Sonos Debug                        Playlist: SQ:9, Terry
  Sonos Debug                        Playlist: SQ:17, TOP 50's
  Sonos Debug                        Playlist: SQ:8, Walk
  Sonos Debug                        Playlist: SQ:24, Xxxxx
  Sonos Debug                     ----------------------------------------
  Sonos Debug                     Loading RadioTime file
  Sonos Debug                     Radio_Continents: Africa
  Sonos Debug                     Radio_Continents: Asia
  Sonos Debug                     Radio_Continents: Australasia
  Sonos Debug                     Radio_Continents: Central America
  Sonos Debug                     Radio_Continents: Europe
  Sonos Debug                     Radio_Continents: North America
  Sonos Debug                     Radio_Continents: South America
  Sonos Debug                     Resetting States for zone: Guest Room
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                     Resetting States for zone: Library
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Library, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                     Resetting States for zone: Master Bedroom
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Master Bedroom, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                     Resetting States for zone: Office
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                     Resetting States for zone: Portable
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Portable, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                     Resetting States for zone: Shop
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Shop, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                     Resetting States for zone: Sitting Room
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_CLASS, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_ONNOW, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_PERCENT, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_POSITION, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_TYPE, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Sonos Sitting Room, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Guest%20Room%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Guest%20Room%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Guest%20Room%20%28ZP%29
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 46, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 80, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 115, in checkForMessages
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 135, in sendMessage
  File "/Library/Application Support/Perceptive Automation/Indigo 5/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 85, in errorLog
<class 'Boost.Python.ArgumentError'>: Python argument types in
    ServerInfo.log()
did not match C++ signature:
    log(CCString message, CCString type='', bool isError=False)
  Sonos Error                     plugin runConcurrentThread function returned or failed; will attempt again in 10 seconds
  Sonos Debug                     Method: runConcurrentThread
  Sonos Debug                     Running Concurrent Thread
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Guest%20Room%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Guest%20Room%20%28ZP%29
  Sonos Debug                     POSITION::_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::PLAYING_|_ART::_|_
  Sonos Debug                     Parsing:Guest Room:POSITION::_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::PLAYING_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Guest Room, State: ZP_STATE, Value: PLAYING
  Sonos Debug                     NOCHANGE::0_|_
  Sonos Debug                     Parsing:Guest Room:NOCHANGE::0_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Library%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Library%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: Library%20%28ZP%29
    ServerInfo.log()
    ServerInfo.log()
Tue Mar 13, 2012 6:39 pm
terrydew offline
Turned polling off and reloaded plugin. No errors! Issued a play and stop on my office zone, Results with debug are below
  Stopping plugin "Sonos 0.2.6" (pid 696)
  Starting plugin "Sonos 0.2.6" (pid 772)
Mar 13, 2012 8:33:16 PM
  Smartphone Radar                "Iphone Sharon" state is now Home.
  Smartphone Radar                All smartphones are now Home.
  Action Group                    Sonos Office Play
  Sonos Debug                     Sonos Action:
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererAction?data=PLAY
  Sonos Debug                     http://192.168.1.202:50101/data/rendererAction?data=PLAY
  Sonos Debug                     POSITION::0:00:4294967295 / 0:03:36_|_PERCENT::1988410784.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::PAUSED_PLAYBACK_|_ART::_|_
  Sonos Debug                     Parsing:Office:POSITION::0:00:4294967295 / 0:03:36_|_PERCENT::1988410784.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::PAUSED_PLAYBACK_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_POSITION, Value: 0:00:4294967295 / 0:03:36
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_PERCENT, Value: 1988410784.0
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_VOLUME, Value: 46
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_VOLUME_FIXED, Value: 0
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_MUTE, Value: 0
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_STATE, Value: PAUSED_PLAYBACK
  Sonos Debug                     Sonos Action Poll:
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererPoll?data=R::Office%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererPoll?data=R::Office%20%28ZP%29
  Sonos Debug                     Parsing:Office:NOCHANGE::0_|_
  Sonos Debug                     POSITION::0:00:00 / 0:03:36_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::PLAYING_|_ART::_|_
  Sonos Debug                     Parsing:Office:POSITION::0:00:00 / 0:03:36_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::PLAYING_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_POSITION, Value: 0:00:00 / 0:03:36
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_PERCENT, Value: 0.0
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_STATE, Value: PLAYING
Mar 13, 2012 8:33:54 PM
  Action Group                    Sonos Office Stop
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererAction?data=STOP
  Sonos Debug                     http://192.168.1.202:50101/data/rendererAction?data=STOP
  Sonos Debug                     POSITION::0:00:00 / 0:03:36_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                     Parsing:Office:POSITION::0:00:00 / 0:03:36_|_PERCENT::0.0_|_VOLUME::46_|_VOLUME_FIXED::0_|_MUTE::0_|_STATE::STOPPED_|_ART::_|_
  Sonos Debug                         Updating Device: Sonos Office, State: ZP_STATE, Value: STOPPED
Tue Mar 13, 2012 6:42 pm
terrydew offline
With polling still turned off tried to setup a line-in action but the "edit action Settings" dialog was empty and would not let me select a zone player so I could not test.
Tue Mar 13, 2012 7:05 pm
nlagaros offline
Sorry for all the piecemeal posts terry, I see that I'm not properly handling the Line-In inputs. Can you go to the Sonos Desktop Controller on your Mac and give me a readout of what is displayed? It would also be incredibly helpful to startup the plugin in debug mode while changing the Reference ZonePlayer to each of your ZP that actually has a Line-In. That will help me figure this all out. I only have one ZP so made many (incorrect assumptions). Thanks!!!!
Tue Mar 13, 2012 9:47 pm
terrydew offline
here is a screen shot of what my sons desktop shows for line-in. Do you want polling on or off or does it matter to run the debug reports. I will try to do with off tonight and if you need with on I will do in am. Where are you located?
sonos linein.tiff
sonos linein.tiff (52.8 KiB) Viewed 3512 times
Tue Mar 13, 2012 9:55 pm
terrydew offline
With Office set as reference
  Stopping plugin "Sonos 0.2.6" (pid 942)
  Starting plugin "Sonos 0.2.6" (pid 3521)
  Sonos Debug                         Reference ZonePlayer: Portable
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rootData?data=S::Portable%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rootData?data=S::Portable%20%28ZP%29
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Portable%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Portable%20%28ZP%29
With Shop set as reference
  Stopping plugin "Sonos 0.2.6" (pid 3521)
  Starting plugin "Sonos 0.2.6" (pid 3562)
  Sonos Debug                         Reference ZonePlayer: Shop
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rootData?data=S::Shop%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rootData?data=S::Shop%20%28ZP%29
  Sonos Debug                     1::R::NONE::AUPEO!_|_2::R::NONE::Deezer_|_3::R::NONE::Global Search_|_4::R::NONE::iheartradio_|_5::R::NONE::Juke_|_6::R::NONE::Juke_|_7::R::NONE::Line-In_|_8::R::NONE::MOG_|_9::R::NONE::Music Library_|_10::R::NONE::Music Shares_|_11::R::NONE::Napster_|_12::R::NONE::QQ音乐_|_13::R::NONE::RadioTime_|_14::R::NONE::Rdio_|_15::R::NONE::Slacker_|_16::R::NONE::Songl_|_17::R::NONE::Sonora_|_18::R::NONE::Sonos Playlists_|_19::R::NONE::Spotify_|_20::R::NONE::Spotify_|_21::R::NONE::Stitcher SmartRadio_|_22::R::NONE::Twitter_|_23::R::NONE::WiMP_|_24::R::NONE::Wolfgang's Vault_|_25::R::NONE::多米音乐_|_MESSAGE::_|_
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rendererData?data=R::Shop%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rendererData?data=R::Shop%20%28ZP%29
  Sonos Debug                     Loading LineIn...
  Sonos Debug                     Message: http://192.168.1.202:50101/data/getData?data=7::R::NONE::Line-In::1,0,100
  Sonos Debug                     http://192.168.1.202:50101/data/getData?data=7::R::NONE::Line-In::1,0,100
  Sonos Debug                     7_1::T::MS_PLAY::Line-In::AI:0::MUSICSERVER_|_RETURN::1:1_|_
  Sonos Debug                        LineIn: AI:0, Line-In
With Master Bedroom as reference (has errors)
  Stopping plugin "Sonos 0.2.6" (pid 3562)
  Starting plugin "Sonos 0.2.6" (pid 3603)
  Sonos Debug                         Reference ZonePlayer: Master Bedroom
  Sonos Debug                     Message: http://192.168.1.202:50101/data/rootData?data=S::Master Bedroom%20%28ZP%29
  Sonos Debug                     http://192.168.1.202:50101/data/rootData?data=S::Master Bedroom%20%28ZP%29
  Sonos Error                     Error getting ZonePlayer data: ZProotData
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 72, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 434, in ZProotData
    ServerInfo.log()
Tue Mar 13, 2012 10:30 pm
terrydew offline
nlagaros
Sorry but I just found what was probably at least some of the problem. When I reloaded sonospy today to get the line-in feature, I forgot that I had to edit files to change the port to 8005 as my security spy has 8000. I will rerun all tests tomorrow as some of the results might have been invalid.
Not now but later is it possible to wrap sonospy into the plug-in (or another) to allow for gui changes to ports and to auto load sonospy when plugin is loaded? Would also give you the ability to control which sonospy version is used. Just a thought.
Hope I didn't waste your time. My first quick run after changing port looked very promising even with polling turned on.
Terry
Wed Mar 14, 2012 10:06 am
terrydew offline
Spoke to soon last night. It reloads with polling enabled and looks good for a short period of time then errors start.
I can see the sonospy web interface and the line-in source does appear. However if I look at the activity monitor for processes running, I do not see any process named sonospy or anything similar? Does this mean anything?
Here is log with polling and debug on
  Stopping plugin "Sonos 0.2.6" (pid 350)
  Starting plugin "Sonos 0.2.6" (pid 404)
  Sonos Error                     Error getting ZonePlayer data: Portable
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 73, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 454, in getPlaylists
    ServerInfo.log()
    ServerInfo.log()
Page 9 of 37 1 ... 6, 7, 8, 9, 10, 11, 12 ... 37
Users browsing this forum: Google [Bot] and 8 guests
