Sonos - The Beginning
Mon Nov 11, 2013 9:59 am
eme jota ce offline
Re: Sonos - The Beginning
Nick,
Thanks for the great Sonos plugin. I upgraded to v.6 and see the following error, which repeats until I disable the plugin. While, like some of the other posters, I saw occasional errors under the prior versions, this seems to be a more persistent error in the Indigo log. Let me know if I can provide any additional info to assist.
  File "plugin.py", line 53, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 118, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 235, in checkDirect
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 263, in checkOneDirect
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 458, in parsePositionInfo
<type 'exceptions.UnboundLocalError'>: local variable 'item' referenced before assignment
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Sonos Error                     Error in plugin execution runConcurrentThread:
Tue Nov 12, 2013 6:49 pm
nlagaros offline
Appreciate the feedback. Can you give me some detail on your configuration? How many ZonePlayers do you have configured in Indigo? I see what is happening, but am surprised that an error is being thrown. I'll have to add some debugging entries and/or rework the logic.
eme jota ce wrote:
Nick,
Wed Nov 13, 2013 5:14 am
eme jota ce offline
Seven zones are configured in Indigo. Those seven are every component of our Sonos system, except for two bridges. They are ZP100's, ZP80's, ZP90's and Connect Amps. Each receives a static IP from an ASUS router ranging from 10.0.1.102 to ...108. I double checked the IP's listed in Indigo. They are correct in Indigo and show the same IP's listed in Sonos and the router.
Fri Nov 29, 2013 2:19 pm
Brian Gaiser offline
I'm having the same problem. I have 5 devices. 3 Connect:AMPs and 2 Zone Player 3s.
Sonos Adding ZonePlayer: RINCON_000E58FE8C5A01400
Sonos Adding ZonePlayer: RINCON_000E58FDA68E01400
Sonos Adding ZonePlayer: RINCON_000E58D4236201400
Sonos Adding ZonePlayer: RINCON_000E58D4236C01400
Sonos Adding ZonePlayer: RINCON_000E58D5009001400
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 118, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 235, in checkDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 263, in checkOneDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 458, in parsePositionInfo
Fri Nov 29, 2013 5:06 pm
nlagaros offline
If you are on v0.6.0, then I understand this error. I would revert to v0.5.x. I will hopefully be releasing v0.6.1 on Sunday that takes care of most of these errors. I'm in between polling and eventing.
Sun Dec 01, 2013 5:26 pm
ckeyes888 offline
Just downloaded and tried to install 0.6.1 and got an install error.
See this in the event log:
plugin "Sonos.indigoPlugin" is missing file: /Users/TV/Downloads/Sonos.indigoPlugin/Contents/Info.plist
Did I miss something?
Carl
Sun Dec 01, 2013 5:40 pm
nlagaros offline
The path is really strange. It should install in /Library/Application Support/Perceptive Automation/Indigo 6/Plugins.
Carl
Sun Dec 01, 2013 5:45 pm
ckeyes888 offline
Yea, thought it was odd myself. I tried moving the install plugin to
the desktop before installing but get the same error.
Carl
Sun Dec 01, 2013 6:04 pm
nlagaros offline
Can you open a terminal and verify if the file is actually there?
Carl
Sun Dec 01, 2013 6:06 pm
nlagaros offline
I am repackaging the plugin. Please stand by...
Sun Dec 01, 2013 6:14 pm
nlagaros offline
Give the download another shot. I think the zip file was corrupted.
Sun Dec 01, 2013 6:20 pm
ckeyes888 offline
Nuts...same error.
Carl
Sun Dec 01, 2013 6:23 pm
nlagaros offline
Can you check the package contents?
ckeyes888 wrote:
Nuts...same error.
Carl
Sun Dec 01, 2013 6:24 pm
ckeyes888 offline
Carl
Not sure what you mean. What should I enter into a Terminal window?
Carl
Sun Dec 01, 2013 6:29 pm
nlagaros offline
Let's look for the Info.plist file.
Open a terminal on the machine running Indigo. Type this:
cd "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents"
ls -al
You should see a file called Info.plist in this listing.
ckeyes888 wrote:
Carl
Carl
Page 20 of 37 1 ... 17, 18, 19, 20, 21, 22, 23 ... 37
