Sonos - The Beginning
Fri Aug 26, 2016 8:54 am
noel1983 offline
Re: Sonos - The Beginning
Sorted!!! I'd upgraded a while back and hadn't noticed the new setting to choose an Event Processor. Found that whilst enabling debugging.
All great now, thanks!
Noel
Sat Aug 27, 2016 12:14 pm
jfeger offline
Londonmark wrote:
I'm having trouble with the play toggle - only seems to play rather than toggle
False alarm - restarting the plugin has got it working again. Sorry.
Interesting. I was having an issue with my Hue Bridge complaining about an unknown hostname. I had encountered this before, and a reboot of the server (The entire computer) fixed it. So I did this, and upon the fresh start, the Sonos plugin Toggle issue you had was present. It would start the Play 1, but not stop/pause the player. Thanks to your note, a road of the plugin worked.
Sat Aug 27, 2016 12:52 pm
Londonmark offline
Seems to happen reasonably often. Not sure why. Reload is always the answer but it's a bit frustrating.
Sun Aug 28, 2016 7:47 pm
gsades offline
nlagaros wrote:
You Sonos ZonePlayers up addresses are likely setup for dynamic up address assignment which is their default. Do you know how to setup static assignments on your DHCP server?
You are right. The problem was the Indigo device declaration which holds the original IP address. Now I reserved several IP addresses in my router for some devices, sonos speakers among them.
Thanks a lot!
Sun Aug 28, 2016 11:07 pm
MarcoGT offline
Uhm...actually it seems thatmy problem started when I installed the new Sonos Plugin...
Tue Aug 30, 2016 10:00 am
gsades offline
I set my first announcement through an action group, which plays a chime (mp3 file) and then says the actual announcement. It works ok (even when it takes very long between the chime and playing the TTS audio). The problem is that after the announcement ends, my sonos speakers don't resume playing TV output.
The configuration I have in this zone is a Playbar and 2 Play:1 set up in surround (5.0, not 5.1 since no SUB is present). The only device which is declared in Indigo is the Playbar (commander).
How can I get the plugin to resume playing TV audio?
Tue Aug 30, 2016 1:35 pm
nlagaros offline
Are you running those two announcement actions concurrently? The plugin needs time to restore state after each announcement - and I'm guessing it does not complete before the second announcement action starts.
Tue Aug 30, 2016 3:26 pm
gsades offline
I was running them in the same action group. Now I deleted the chime and left the TTS alone, which is the only action of the group. When I run it, the result is the same: TV sound goes off, the announcement is played and the speaker keeps silent.
Here are the log entries:
Action Group Prueba Sonos 1
Sonos Announcement: Esto es una prueba, Volume: 10
Sonos remove zone from group: lg.so.sb
Sonos ZonePlayer: lg.so.sb, Stop
Sonos ZonePlayer: lg.so.sb, Current Volume: 43, New Volume: 10
Sonos Announcement Length: 2.052
Sonos ZonePlayer: lg.so.sb, Play
Sonos ZonePlayer: lg.so.sb, Clear Queue
And these are with some debugging options enabled:
Sonos Debug zoneIP: 10.0.1.24, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.24, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.27, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.27, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.25, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.25, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.22, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.22, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.26, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.26, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug Announcement: set standalone
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: BecomeCoordinatorOfStandaloneGroup
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetAVTransportURI
Sonos Debug Announcement: add announcement zones to group
Sonos Debug Sonos Action: Stop
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Stop
Sonos Debug Announcement: set volume
Sonos Debug Sonos Action: Volume
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /RenderingControl, soapAction: SetVolume
Sonos Debug Updating Device: au.so.p1, State: ZoneGroupID, Value: RINCON_B8E937BF15F201400:12
Sonos Debug Updating Device: au.so.p1, State: ZoneGroupName, Value: Aura
Sonos Debug Updating Device: au.so.p1, State: ZonePlayerUUIDsInGroup, Value: RINCON_B8E937BF15F201400
Sonos Debug Update all states to slave ZonePlayers...
Sonos Debug Updating Device: cc.so.p1, State: ZoneGroupID, Value: RINCON_B8E937E3E2DE01400:27
Sonos Debug Updating Device: cc.so.p1, State: ZoneGroupName, Value: Cocina
Sonos Debug Updating Device: cc.so.p1, State: ZonePlayerUUIDsInGroup, Value: RINCON_B8E937E3E2DE01400
Sonos Debug Updating Device: ac.so.p1, State: ZoneGroupID, Value: RINCON_B8E937E8F44601400:25
Sonos Debug Updating Device: ac.so.p1, State: ZoneGroupName, Value: Antecomedor
Sonos Debug Updating Device: ac.so.p1, State: ZonePlayerUUIDsInGroup, Value: RINCON_B8E937E8F44601400
Sonos Debug Sonos Action: PlayMode NORMAL
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetPlayMode
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Play
Sonos Debug Restore States: RINCON_B8E9377BE34901400:RINCON_B8E9377BE34901400:lg.so.sb
Sonos Debug 01:Q_Crossfade: False
Sonos Debug 02:Q_Repeat: False
Sonos Debug 03:Q_Shuffle: False
Sonos Debug 04:ZP_MUTE: 0
Sonos Debug 05:ZP_STATE: STOPPED
Sonos Debug 06:ZP_VOLUME: 43
Sonos Debug 07:ZP_CurrentURI:
Sonos Debug 08:CurrentURI MetaData:
Sonos Debug 09:ZP_CurrentTrack: 0
Sonos Debug 10:GROUP_Coordinator: true
Sonos Debug 12:Relative Time: NOT_IMPLEMENTED
Sonos Debug 13:ZonePlayerUUIDsInGroup: RINCON_B8E9377BE34901400
Sonos Debug RINCON_B8E9377BE34901400: Restore URI:
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /Queue, soapAction: RemoveAllTracks
Sonos Debug RINCON_B8E9377BE34901400: Restore Mute: 0
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /RenderingControl, soapAction: SetMute
Sonos Debug RINCON_B8E9377BE34901400: Restore Volume: 43
Sonos Debug zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetCurrentTransportActions
Sonos Debug RINCON_B8E9377BE34901400: Restore Play State: STOPPED
Tue Aug 30, 2016 3:29 pm
gsades offline
I found what was wrong: model was not selected.
Your plugging is terrific!
Wed Aug 31, 2016 4:12 pm
nlagaros offline
Awesome. I'm glad it's working. I think it is time to lock this thread. It was the first. Please start new threads for any issues or comments.
