Sonos - The Beginning
Tue Mar 17, 2015 6:25 am
wideglidejrp offline
Re: Sonos - The Beginning
Nick,, thanks for your great work. I use the plugin every day all day. However, I consistently get the following error throughout the day. Is there something I should do about it?
Sonos Error SOAPSend warning: waiting for command execution [192.168.1.61:0]
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 175, in actionZP_Pandora
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 968, in actionDirect
<type 'exceptions.UnboundLocalError'>: local variable 'pstation' referenced before assignment
John R Patrick
Author of
Home Attitude
Tue Mar 24, 2015 12:32 pm
nlagaros offline
Please download the latest version of the plugin I just posted (v0.8.10). It has fixes for changes Pandora made to their website.
Tue Mar 24, 2015 6:29 pm
mlooss offline
Nick,
just upgraded to v0.8.10 but I still can't get announcements to work? I am running 10.10.2 on a Mac mini and I just rebuilt this server from scratch. I had announcements working on Yosemite until I updated the plug-in.
Any help would be greatly appreciated, for an otherwise awesome plug-in.
Trigger SONOS Announcement Test
File "plugin.py", line 169, in actionZP_announcementMP3
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1048, in actionAnnouncement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1035, in actionStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 433, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/socket.py", line 348, in read
<class 'socket.error'>: [Errno 54] Connection reset by peer
Wed Mar 25, 2015 6:18 am
nlagaros offline
Can you give me some detail on your configuration - as in what model ZonePlayers you have configured as devices in Indigo. Thanks.
mlooss wrote:
Nick,
Wed Mar 25, 2015 12:18 pm
mlooss offline
Nick,
I have the following Sonos equipment:
2 x Play 5's (one each in a room)
2 x Play 1's (paired in stereo mode in another room)
1 x Playbar, 1 x Sub and 2 Play 1"s configured in surround sound
2 x Airport Express attached to the line-in on each Play 5
1 x Sonos Bridge (not configured in INDIGO)
1 x Sonos Boost (not configured in INDIGO)
I confirmed each INDIGO device is setup with the correct type and IP address (IP's are fixed by DHCP reservation)
Your plugin version, v0.8.10, is current.
Sonos Saved Plugin Configuration
Sonos Playlist: I removed all the playlist and Pandora stations to clarity
Sonos Adding ZonePlayer: RINCON_000E585C199401400
Sonos Adding ZonePlayer: RINCON_B8E937B8F3BA01400
Sonos Adding ZonePlayer: RINCON_B8E937B8F39401400
Sonos Adding ZonePlayer: RINCON_000E58840AB201400
Sonos Adding ZonePlayer: RINCON_B8E937BF82CC01400
Sonos Adding ZonePlayer: RINCON_B8E9378FCA9401400
Sonos Adding ZonePlayer: RINCON_B8E9377A416B01400
Sonos Adding ZonePlayer: RINCON_B8E9376106AE01400
Sonos Subscribing on port: 9999
Sonos SonosEvents INFO: Publishing on port: 9999
Sonos Event Ignition...
Sonos Serving HTTP Streamer on 10.0.1.137 [0.0.0.0], port 8888
Sonos LineIn: RINCON_000E585C199401400, AirPlay Device:Family Room
Sonos LineIn: RINCON_000E58840AB201400, AirPlay Device:Master Bedroom
Wed Mar 25, 2015 12:22 pm
nlagaros offline
Can you edit the device settings for the SUB and make sure that you select SUB in the dropdown. I think that is what is causing the bomb.
Wed Mar 25, 2015 5:49 pm
mlooss offline
Nick,
I reselected the Sub, it was already selected. I disabled communication for the Sub and then deleted the Sub device and I keep getting the same error message. I also reloaded the plug-in and get the same old error :-(
Wed Apr 01, 2015 5:20 am
nlagaros offline
Two things:
1. Please download the latest version of the plugin (.0.8.11) from my wiki.
2. If the error still persists, can you enable the debug options and post the output. I should be able to isolate the issue from there.
Thanks.
mlooss wrote:
Nick,
Thu Apr 02, 2015 6:21 pm
mlooss offline
Hi Nick,
I upgraded to v0.8.11 and 0.8.12, I continue to get the same error? I enabled debugging and this is the error message I get. I reloaded the plug-in, restarted the INDIGO server and rebooted the Mac mini running INDIGO.
Trigger Sonos announcemnet test
Sonos Debug zoneIP: 10.0.1.110, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.110, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.12, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.12, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.13, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.13, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.196, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.196, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.208, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
File "plugin.py", line 172, in actionZP_announcementMP3
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1052, in actionAnnouncement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1039, in actionStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 437, in SOAPSend
nlagaros wrote:
Two things:
Thanks.
mlooss wrote:
Nick,
Fri Apr 03, 2015 1:53 am
nlagaros offline
OK.. this is a good start. What is the model of ZonePlayer with ip 10.0.1.208. This is the one that is causing the plugin to crash.
mlooss wrote:
Hi Nick,
nlagaros wrote:
Two things:
Thanks.
mlooss wrote:
Nick,
Fri Apr 03, 2015 7:02 pm
mlooss offline
It is a Play 1 setup as the left surround speaker.
Fri Apr 03, 2015 7:14 pm
nlagaros offline
Can you pull up this url in a browser: http://10.0.1.208:1400/status/zp
Fri Apr 03, 2015 7:16 pm
mlooss offline
Yes, I can, here is a screenshot of the page that loads.
Fri Apr 03, 2015 7:23 pm
nlagaros offline
Can you turn on the XML debug in the Plugin options and try the action again. Thanks.
Sat Apr 04, 2015 4:19 am
nlagaros offline
Please turn on the event debugging as well and include the startup events that show each ZonePlayer getting the first batch of state updates. Thanks!
Page 30 of 37 1 ... 27, 28, 29, 30, 31, 32, 33 ... 37
