Sonos - The Beginning
Wed Nov 26, 2014 1:45 pm
nlagaros offline
Re: Sonos - The Beginning
Right now either one would work. I only have special logic for the Subwoofer and Playbar. But please choose connect:amp. Thanks!!!
eme jota ce wrote:
nlagaros wrote:
I added an additional config item for each ZonePlayer device. You need to click on the properties for each and select your ZonePlayer model.
Nick,
For an older ZP 100 Sonos (which has an integrated amp), should the "Model:" in the "Configure Sonos Zone Player" dialogue box be identified as "CONNECT: AMP" or as "Zone Player"?
In the Sonos desktop application, Sonos -> About My Sonos System, identifies my newer Sonos unit as "CONNECT:AMP" as shown in your list, but older units are identified as "ZP100" or "ZP80"
(See attachments)
mjc
Wed Nov 26, 2014 1:46 pm
nlagaros offline
I'm so glad it is working. I think we are on an upward trajectory with v8 of the plugin.
pereza1 wrote:
pereza1 wrote:
Got this error this morning. Still happens after Indigo server is restarted. Reverted back to 0.5.11
Running on Snow Leopard, if that makes a difference...
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 58, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 189, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 291, in initZones
<type 'exceptions.KeyError'>: key model not found in dict
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Thanks! That did it! Also, v8 is running perfectly on my Indigo6/Snow Leopard system!! Woohoo!! :)
Wed Nov 26, 2014 2:45 pm
haavarda offline
I did some more testing. Restarted indigo server and my computer, removed the plugin and installed 8.1 again. Then I managed to get it to work! Thanks for your continued work on this plugin!
Håvard
Wed Nov 26, 2014 4:04 pm
eme jota ce offline
Ditto! Thanks Nick, and Happy Thanksgiving. So glad that Sonos is working with Indigo, again.
I only see one error in the log:
Sonos Error SOAPSend warning: waiting for command execution [10.0.1.106:0]
But, things are working really well. Control pages I created long ago had lost functionality, but have regained it. Keypad scenes that integrate Sonos work, again. Announcements work, again. Thanks!!
Wed Nov 26, 2014 5:14 pm
nlagaros offline
Awesome! Don't worry about the error - I have retry logic for communicating with the ZonePlayers. It is more of a warning than an error.
Fri Nov 28, 2014 10:04 am
pereza1 offline
On plugin, shows that it is playing but it is not
Hey Nick,
Ok...when my CONNECT unit is grouped together with another group, it is always showing as PLAYING even though no content is playing on it.
When I ungroup it and it's standalone, it properly reports it's status (e.g. PLAYING, PAUSED).
Note that I'm running the latest beta of the SONOS system.
Any ideas?
Sun Nov 30, 2014 6:01 am
nlagaros offline
I'll do some testing and see what I can figure out.
Tue Dec 02, 2014 1:57 am
haavarda offline
Hi Nick. I am curious about how the plugin will handle 2 play 3 units that is set to a stereo pair. When I used a sonos plugin for my Vera box it had some issues with braking the pair when I added the pair in an announcement. So I have not tried to add the pair yet in the indigo plugin. Any thoughts?
Håvard
Sun Dec 14, 2014 11:47 am
roussell offline
I upgraded this morning to 0.8.2 and am now receiving the following errors (debug logging enabled). The previous version .0.6.21 has been working fine, I reverted to it and all is back to normal. Any clues where to look? I'm running Snow Leo 10.6.8
Starting plugin "Sonos 0.8.2" (pid 26292)
  Started plugin "Sonos 0.8.2"
  Sonos                           Your plugin version, v0.8.2, is current.
  Sonos Debug                     Getting Plugin Configuration Settings
  Sonos Debug                         Reference ZP IP:        10.0.1.60
  Sonos Debug                         Publish/Subscribe Port: 9999
  Sonos Debug                         Pandora:                True
  Sonos Debug                         Pandora User ID:        hidden (but correct)
  Sonos Debug                         Pandora Email Address:  hidden (but correct)
  Sonos Debug                         SiriusXM:               False
  Sonos Debug                         MP3 Path Override:      None
  Sonos Debug                         MP3 Path:               None
  Sonos Debug                         SMB Path:               10.0.1.100/Perceptive Automation/Indigo 6
  Sonos                           Saved Plugin Configuration
  Sonos Debug                     Loading Playlists...
  Sonos Debug                     zoneIP: 10.0.1.60, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
  Sonos Debug                     ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:1" parentID="SQ:" restricted="true"><dc:title>Downloaded</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#1</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:3" parentID="SQ:" restricted="true"><dc:title>Feeling Good</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#3</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:4" parentID="SQ:" restricted="true"><dc:title>Halloween Party</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#4</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:2" parentID="SQ:" restricted="true"><dc:title>Sonos Playlist  1</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#2</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:0" parentID="SQ:" restricted="true"><dc:title>White Noise</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#0</res><upnp:class>object.container.playlistContainer</upnp:class></container></DIDL-Lite></Result><NumberReturned>5</NumberReturned><TotalMatches>5</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
  Sonos                              Playlist: SQ:1, Downloaded, file:///jffs/settings/savedqueues.rsq#1
  Sonos                              Playlist: SQ:3, Feeling Good, file:///jffs/settings/savedqueues.rsq#3
  Sonos                              Playlist: SQ:4, Halloween Party, file:///jffs/settings/savedqueues.rsq#4
  Sonos                              Playlist: SQ:2, Sonos Playlist  1, file:///jffs/settings/savedqueues.rsq#2
  Sonos                              Playlist: SQ:0, White Noise, file:///jffs/settings/savedqueues.rsq#0
  Sonos Debug                     Loading RadioTime Favorite Stations...
  Sonos Debug                     ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/8" parentID="R:0/0" restricted="false"><dc:title>104.7 | WZZK-FM (Country)</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s24466?sid=254&amp;amp;flags=32</res></item><item id="R:0/0/17" parentID="R:0/0" restricted="false"><dc:title>Nicecast</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://10.0.1.100:8000/listen.m3u</res></item></DIDL-Lite></Result><NumberReturned>2</NumberReturned><TotalMatches>2</TotalMatches><UpdateID>2</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
  Sonos                              RadioTime Favorite Station: R:0/0/8, 104.7 | WZZK-FM (Country), x-sonosapi-stream:s24466?sid=254&flags=32
  Sonos                              RadioTime Favorite Station: R:0/0/17, Nicecast, x-rincon-mp3radio://10.0.1.100:8000/listen.m3u
  Sonos Error                     Error getting Pandora feed
  Sonos Debug                     ZonePlayer: Kitchen Sonos, Enabled: True
  Sonos Debug                     Resetting States for zone: 10.0.1.62
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_ALBUM, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_ART, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_ARTIST, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_CREATOR, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_CurrentURI, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_DURATION, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_INFO, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_MUTE, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_STATE, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_STATION, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_TRACK, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_VOLUME, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_VOLUME_FIXED, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_ZoneName, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_LocalUID, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_AIName, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_AIPath, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_NALBUM, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_NART, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_NARTIST, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_NTRACK, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: Q_Crossfade, Value: off
  Sonos Debug                         Updating Device: Kitchen Sonos, State: Q_Repeat, Value: off
  Sonos Debug                         Updating Device: Kitchen Sonos, State: Q_Shuffle, Value: off
  Sonos Debug                         Updating Device: Kitchen Sonos, State: GROUP_Coordinator, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: GROUP_Name, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_CurrentTrack, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZoneGroupID, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZoneGroupName, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZonePlayerUUIDsInGroup, Value:
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_ZoneName, Value: Kitchen
  Sonos Debug                         Updating Device: Kitchen Sonos, State: ZP_LocalUID, Value: RINCON_000E587BD98601400
  Sonos                           Adding ZonePlayer: RINCON_000E587BD98601400
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 160, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 271, in initZones
  Sonos Debug                     Method: runConcurrentThread
  Sonos Debug                     Running Concurrent Thread
Sun Dec 14, 2014 11:53 am
nlagaros offline
Would you please edit each ZonePlayer device and select a model. In the future, I will auto-detect the model. Restart the plugin and all should be well. I need this to filter some states for the PlayBar. Thanks.
roussell wrote:
I upgraded this morning to 0.8.2 and am now receiving the following errors (debug logging enabled). The previous version .7 something has been working fine.
Sun Dec 14, 2014 1:04 pm
roussell offline
Yep, that was it, thanks Nick. As always great job on this fabulous plugin!
Mon Dec 15, 2014 4:39 pm
pereza1 offline
Re: On plugin, shows that it is playing but it is not
Heya Nick,
Any updates on this?
Please advise.
Thanks for all the hard work!
pereza1 wrote:
Hey Nick,
Note that I'm running the latest production version of the SONOS sw (v5.2).
Any ideas?
Mon Dec 15, 2014 4:50 pm
nlagaros offline
Hi. I can't replicate this. Can you take me through each action you take to get to this incorrect state. And tell me what (if any) sources were playing on the single zone player and the group. Thanks.
pereza1 wrote:
Heya Nick,
Please advise.
pereza1 wrote:
Hey Nick,
Any ideas?
Sun Dec 21, 2014 11:18 am
Seeker offline
I updated from 6.2 to 8.2 this morning. I'm getting this:
Two issues i'm having:
1 -- the sonos device states are blank. the all have device types assigned. I restarted, reloaded. my speak/play actions work, but the devices do not display the state. it seems like i had this once before, but cannot remember how i remedied it.
2 -- errors in log
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 169, in runConcurrentThread
  File "<string>", line 1, in bind
<class 'socket.error'>: (48, 'Address already in use')
Thanks for any help, especially on #1.
edit: downgraded to 6.2, device states show properly
Sun Dec 21, 2014 6:08 pm
roussell offline
On #1, make sure you go into the settings for each Sonos device and set the type of player. That's a new drop-down field with this version. It bit me too. Also #2 is related to #1
Page 26 of 37 1 ... 23, 24, 25, 26, 27, 28, 29 ... 37
