Seeker wrote:they're all set correctly. 2 play:1s, 2 play:5s.
haavarda wrote:Hi Nick. I am curious about how the plugin will handle 2 play 3 units that is set to a stereo pair. When I used a sonos plugin for my Vera box it had some issues with braking the pair when I added the pair in an announcement. So I have not tried to add the pair yet in the indigo plugin. Any thoughts?
nlagaros wrote:Would you mind putting the plugin in debug mode and posting the full output from startup. Historically, this issue has been related to DNS configuration issues. I also posted an updated plugin on my wiki if you care to download.Seeker wrote:they're all set correctly. 2 play:1s, 2 play:5s.
Reloading plugin "Sonos 0.8.3"
Stopping plugin "Sonos 0.8.3" (pid 6284)
Stopped plugin "Sonos 0.8.3"
Starting plugin "Sonos 0.8.3" (pid 6290)
Schedule variable any setpoint is heatmode
Started plugin "Sonos 0.8.3"
Sonos Your plugin version, v0.8.3, is current.
Sonos Debug Getting Plugin Configuration Settings
Sonos Debug Reference ZP IP: 192.168.1.35
Sonos Debug Publish/Subscribe Port: 9999
Sonos Debug HTTP Streaming Port: 8888
Sonos Debug Sound File Path:
Sonos Debug Pandora: False
Sonos Debug Pandora User ID:
Sonos Debug Pandora Email Address:
Sonos Debug SiriusXM: True
Sonos Saved Plugin Configuration
Sonos Debug Loading Playlists...
Sonos Debug zoneIP: 192.168.1.35, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:3" parentID="SQ:" restricted="true"><dc:title>dog barking</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#3</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:2" parentID="SQ:" restricted="true"><dc:title>maiden</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#2</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:1" parentID="SQ:" restricted="true"><dc:title>test playlist</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#1</res><upnp:class>object.container.playlistContainer</upnp:class></container><container id="SQ:0" parentID="SQ:" restricted="true"><dc:title>twit</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#0</res><upnp:class>object.container.playlistContainer</upnp:class></container></DIDL-Lite></Result><NumberReturned>4</NumberReturned><TotalMatches>4</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Playlist: SQ:3, dog barking, file:///jffs/settings/savedqueues.rsq#3
Sonos Playlist: SQ:2, maiden, file:///jffs/settings/savedqueues.rsq#2
Sonos Playlist: SQ:1, test playlist, file:///jffs/settings/savedqueues.rsq#1
Sonos Playlist: SQ:0, twit, file:///jffs/settings/savedqueues.rsq#0
Sonos Debug Loading RadioTime Favorite Stations...
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/6" parentID="R:0/0" restricted="false"><dc:title>181.FM The Buzz (Alt. Rock)</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s55020?sid=254&amp;flags=32</res></item><item id="R:0/0/17" parentID="R:0/0" restricted="false"><dc:title>HardRadio</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s17292?sid=254&amp;flags=32</res></item><item id="R:0/0/16" parentID="R:0/0" restricted="false"><dc:title>KNAC.COM</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s88447?sid=254&amp;flags=32</res></item><item id="R:0/0/1" parentID="R:0/0" restricted="false"><dc:title>NewsRadio 1510 WLAC</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s30537?sid=254&amp;flags=32</res></item><item id="R:0/0/4" parentID="R:0/0" restricted="false"><dc:title>Pirate Radio</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s131240?sid=254&amp;flags=32</res></item><item id="R:0/0/5" parentID="R:0/0" restricted="false"><dc:title>Rock Nation - WRFF-HD2</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s67476?sid=254&amp;flags=32</res></item><item id="R:0/0/0" parentID="R:0/0" restricted="false"><dc:title>The Buzz</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s27658?sid=254&amp;flags=32</res></item><item id="R:0/0/3" parentID="R:0/0" restricted="false"><dc:title>twit</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-rincon-mp3radio://twit.am/listen.m3u</res></item><item id="R:0/0/15" parentID="R:0/0" restricted="false"><dc:title>TWiT Live</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s97079?sid=254&amp;flags=32</res></item><item id="R:0/0/2" parentID="R:0/0" restricted="false"><dc:title>Z Rock</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s35105?sid=254&amp;flags=32</res></item></DIDL-Lite></Result><NumberReturned>10</NumberReturned><TotalMatches>10</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos RadioTime Favorite Station: R:0/0/6, 181.FM The Buzz (Alt. Rock), x-sonosapi-stream:s55020?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/17, HardRadio, x-sonosapi-stream:s17292?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/16, KNAC.COM, x-sonosapi-stream:s88447?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/1, NewsRadio 1510 WLAC, x-sonosapi-stream:s30537?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/4, Pirate Radio, x-sonosapi-stream:s131240?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/5, Rock Nation - WRFF-HD2, x-sonosapi-stream:s67476?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/0, The Buzz, x-sonosapi-stream:s27658?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/3, twit, x-rincon-mp3radio://twit.am/listen.m3u
Sonos RadioTime Favorite Station: R:0/0/15, TWiT Live, x-sonosapi-stream:s97079?sid=254&flags=32
Sonos RadioTime Favorite Station: R:0/0/2, Z Rock, x-sonosapi-stream:s35105?sid=254&flags=32
Sonos SiriusXM: 2|2|siriushits1|siriushits1|SiriusXM Hits 1
Sonos SiriusXM: 3|3|9389|9389|Venus
Sonos SiriusXM: 4|4|8205|8205|40s on 4
Sonos SiriusXM: 5|5|siriusgold|siriusgold|50s on 5
Sonos SiriusXM: 6|6|60svibrations|60svibrations|60s on 6
Sonos SiriusXM: 7|7|totally70s|totally70s|70s on 7
Sonos SiriusXM: 8|8|big80s|big80s|80s on 8
Sonos SiriusXM: 9|9|8206|8206|90s on 9
Sonos SiriusXM: 10|10|8208|8208|Pop2K
Sonos SiriusXM: 15|15|thepulse|thepulse|The Pulse
Sonos SiriusXM: 16|16|starlite|starlite|The Blend
Sonos SiriusXM: 17|17|siriuslove|siriuslove|SiriusXM Love
Sonos SiriusXM: 700|700|8372|8372|Neil Diamond Radio
Sonos SiriusXM: 702|702|9361|9361|Velvet
Sonos SiriusXM: 703|703|9362|9362|Elevations
Sonos SiriusXM: 705|705|9138|9138|Limited Engagements
Sonos SiriusXM: 19|19|elvisradio|elvisradio|Elvis Radio
Sonos SiriusXM: 20|20|estreetradio|estreetradio|E Street Radio
Sonos SiriusXM: 21|21|undergroundgarage|undergroundgarage|Underground Garage
Sonos SiriusXM: 22|22|8370|8370|Pearl Jam Radio
Sonos SiriusXM: 23|23|gratefuldead|gratefuldead|Grateful Dead
Sonos SiriusXM: 24|24|radiomargaritaville|radiomargaritaville|Radio Margaritaville
Sonos SiriusXM: 25|25|classicrewind|classicrewind|Classic Rewind
Sonos SiriusXM: 26|26|classicvinyl|classicvinyl|Classic Vinyl
Sonos SiriusXM: 27|27|thevault|thevault|Deep Tracks
Sonos SiriusXM: 28|28|thespectrum|thespectrum|The Spectrum
Sonos SiriusXM: 29|29|jamon|jamon|Jam_ON
Sonos SiriusXM: 30|30|8207|8207|The Loft
Sonos SiriusXM: 31|31|coffeehouse|coffeehouse|The Coffee House
Sonos SiriusXM: 32|32|thebridge|thebridge|The Bridge
Sonos SiriusXM: 33|33|firstwave|firstwave|1st Wave
Sonos SiriusXM: 34|34|90salternative|90salternative|Lithium
Sonos SiriusXM: 35|35|leftofcenter|leftofcenter|SiriusXMU
Sonos SiriusXM: 36|36|altnation|altnation|Alt Nation
Sonos SiriusXM: 37|37|octane|octane|Octane
Sonos SiriusXM: 38|38|buzzsaw|buzzsaw|Ozzy's Boneyard
Sonos SiriusXM: 39|39|hairnation|hairnation|Hair Nation
Sonos SiriusXM: 40|40|hardattack|hardattack|Liquid Metal
Sonos SiriusXM: 41|41|faction|faction|Faction
Sonos SiriusXM: 713|713|9363|9363|Jason Ellis
Sonos SiriusXM: 42|42|reggaerhythms|reggaerhythms|The Joint
Sonos SiriusXM: 310|310|9174|9174|Rock Hall of Fame Radio
Sonos SiriusXM: 312|312|9352|9352|Petty's Buried Treasure
Sonos SiriusXM: 313|313|9175|9175|RockBar
Sonos SiriusXM: 316|316|9176|9176|SiriusXM Comes Alive!
Sonos SiriusXM: 319|319|9177|9177|Classic College Radio
Sonos SiriusXM: 715|715|9139|9139|Limited Engagements 2
Sonos SiriusXM: 716|716|9353|9353|Limited Engagements 3
Sonos SiriusXM: 44|44|hiphopnation|hiphopnation|Hip-Hop Nation
Sonos SiriusXM: 45|45|shade45|shade45|Shade 45
Sonos SiriusXM: 46|46|8124|8124|Backspin
Sonos SiriusXM: 47|47|hotjamz|hotjamz|The Heat
Sonos SiriusXM: 48|48|heartandsoul|heartandsoul|Heart & Soul
Sonos SiriusXM: 49|49|soultown|soultown|Soul Town
Sonos SiriusXM: 50|50|8228|8228|The Groove
Sonos SiriusXM: 724|724|9364|9364|SiriusXM Silk
Sonos SiriusXM: 725|725|9339|9339|SiriusXM Fly
Sonos SiriusXM: 51|51|thebeat|thebeat|BPM
Sonos SiriusXM: 52|52|area33|area33|Electric Area
Sonos SiriusXM: 53|53|chill|chill|SiriusXM Chill
Sonos SiriusXM: 54|54|9145|9145|Studio 54 Radio
Sonos SiriusXM: 55|55|9365|9365|Utopia
Sonos SiriusXM: 340|340|9219|9219|Tiësto's Club Life Radio
Sonos SiriusXM: 730|730|9384|9384|Limited Engagements 4
Sonos SiriusXM: 56|56|newcountry|newcountry|The Highway
Sonos SiriusXM: 57|57|9340|9340|Y2Kountry
Sonos SiriusXM: 58|58|primecountry|primecountry|Prime Country
Sonos SiriusXM: 59|59|theroadhouse|theroadhouse|Willie's Roadhouse
Sonos SiriusXM: 60|60|outlawcountry|outlawcountry|Outlaw Country
Sonos SiriusXM: 61|61|bluegrass|bluegrass|Bluegrass Junction
Sonos SiriusXM: 350|350|9178|9178|Red White & Booze
Sonos SiriusXM: 741|741|8227|8227|The Village
Sonos SiriusXM: 63|63|spirit|spirit|The Message
Sonos SiriusXM: 64|64|praise|praise|Kirk Franklin's Praise
Sonos SiriusXM: 65|65|8229|8229|enLighten
Sonos SiriusXM: 66|66|jazzcafe|jazzcafe|Watercolors
Sonos SiriusXM: 67|67|purejazz|purejazz|Real Jazz
Sonos SiriusXM: 68|68|spa73|spa73|Spa
Sonos SiriusXM: 69|69|8215|8215|Escape
Sonos SiriusXM: 70|70|siriusblues|siriusblues|BB King's Bluesville
Sonos SiriusXM: 71|71|siriuslysinatra|siriuslysinatra|Siriusly Sinatra
Sonos SiriusXM: 72|72|broadwaysbest|broadwaysbest|On Broadway
Sonos SiriusXM: 749|749|9387|9387|Jazz at Lincoln Center
Sonos SiriusXM: 750|750|8211|8211|Cinemagic
Sonos SiriusXM: 360|360|9179|9179|Krishna Das Yoga Radio
Sonos SiriusXM: 74|74|metropolitanopera|metropolitanopera|Met Opera Radio
Sonos SiriusXM: 76|76|symphonyhall|symphonyhall|Symphony Hall
Sonos SiriusXM: 760|760|siriuspops|siriuspops|SiriusXM Pops
Sonos SiriusXM: 770|770|9372|9372|70s/80s Pop
Sonos SiriusXM: 771|771|9373|9373|80s/90s Pop
Sonos SiriusXM: 772|772|9374|9374|90s/2K Pop
Sonos SiriusXM: 773|773|9375|9375|Classic Rock Party
Sonos SiriusXM: 774|774|9376|9376|Rockin' Frat Party
Sonos SiriusXM: 775|775|9377|9377|Hip-Hop Party
Sonos SiriusXM: 776|776|9378|9378|Oldies Party
Sonos SiriusXM: 777|777|9379|9379|Pop Party Mix
Sonos SiriusXM: 778|778|9380|9380|Punk Party
Sonos SiriusXM: 779|779|9381|9381|New Wave Dance Party
Sonos SiriusXM: 780|780|9382|9382|The Girls Room
Sonos SiriusXM: 781|781|9343|9343|Holly
Sonos SiriusXM: 782|782|9342|9342|Holiday Traditions
Sonos SiriusXM: 783|783|9344|9344|Holiday Pops
Sonos SiriusXM: 784|784|9345|9345|Country Christmas
Sonos SiriusXM: 785|785|9348|9348|Navidad
Sonos SiriusXM: 786|786|9346|9346|Holiday Soul
Sonos SiriusXM: 787|787|9349|9349|Radio Hanukkah
Sonos SiriusXM: 83|83|espnradio|espnradio|ESPN Radio
Sonos SiriusXM: 84|84|8254|8254|ESPN Xtra
Sonos SiriusXM: 85|85|8213|8213|Mad Dog Sports Radio
Sonos SiriusXM: 207|86|9385|9385|SiriusXM NBA Radio
Sonos SiriusXM: 210|87|8368|8368|SXM Fantasy Sports Radio
Sonos SiriusXM: 88|88|siriusnflradio|siriusnflradio|SiriusXM NFL Radio
Sonos SiriusXM: 209|89|8333|8333|MLB Network Radio
Sonos SiriusXM: 90|90|siriusnascarradio|siriusnascarradio|SiriusXM NASCAR Radio
Sonos SiriusXM: 91|91|siriussportsaction|siriussportsaction|College Sports Nation
Sonos SiriusXM: 92|92|8230|8230|SiriusXM Sports Zone
Sonos SiriusXM: 208|93|8186|8186|SiriusXM PGA TOUR Radio
Sonos SiriusXM: 94|94|9341|9341|SiriusXM FC
Sonos SiriusXM: 93|208|9395|9395|Bleacher Report Radio
Sonos SiriusXM: 211|218|8185|8185|SXM NHL Network Radio
Sonos SiriusXM: 370|370|9180|9180|SportsCenter
Sonos SiriusXM: 800|800|9146|9146|NFL-ARI
Sonos SiriusXM: 801|801|9147|9147|NFL-ATL
Sonos SiriusXM: 802|802|9148|9148|NFL-BAL
Sonos SiriusXM: 803|803|9149|9149|NFL-BUF
Sonos SiriusXM: 804|804|9150|9150|NFL-CAR
Sonos SiriusXM: 805|805|9151|9151|NFL-CHI
Sonos SiriusXM: 806|806|9152|9152|NFL-CIN
Sonos SiriusXM: 807|807|9153|9153|NFL-CLE
Sonos SiriusXM: 808|808|9154|9154|NFL-DAL
Sonos SiriusXM: 809|809|9155|9155|NFL-DEN
Sonos SiriusXM: 810|810|9156|9156|NFL-DET
Sonos SiriusXM: 811|811|9157|9157|NFL-GB
Sonos SiriusXM: 812|812|9158|9158|NFL-HOU
Sonos SiriusXM: 813|813|9159|9159|NFL-IND
Sonos SiriusXM: 814|814|9160|9160|NFL-JAX
Sonos SiriusXM: 815|815|9161|9161|NFL-KC
Sonos SiriusXM: 816|816|9162|9162|NFL-MIA
Sonos SiriusXM: 817|817|9163|9163|NFL-MIN
Sonos SiriusXM: 818|818|9164|9164|NFL-NE
Sonos SiriusXM: 819|819|9165|9165|NFL-NO
Sonos SiriusXM: 820|820|9166|9166|NFL-NYG
Sonos SiriusXM: 821|821|9167|9167|NFL-NYJ
Sonos SiriusXM: 822|822|9168|9168|NFL-OAK
Sonos SiriusXM: 823|823|9169|9169|NFL-PHI
Sonos SiriusXM: 824|824|9170|9170|NFL-PIT
Sonos SiriusXM: 825|825|9171|9171|NFL-SD
Sonos SiriusXM: 826|826|9201|9201|NFL-SEA
Sonos SiriusXM: 827|827|9202|9202|NFL-SF
Sonos SiriusXM: 828|828|9203|9203|NFL-STL
Sonos SiriusXM: 829|829|9204|9204|NFL-TB
Sonos SiriusXM: 830|830|9205|9205|NFL-TEN
Sonos SiriusXM: 831|831|9206|9206|NFL-WAS
Sonos SiriusXM: 840|840|9231|9231|Arizona Diamondbacks
Sonos SiriusXM: 841|841|9232|9232|Atlanta Braves
Sonos SiriusXM: 842|842|9233|9233|Baltimore Orioles
Sonos SiriusXM: 843|843|9234|9234|Boston Red Sox
Sonos SiriusXM: 844|844|9235|9235|Chicago Cubs
Sonos SiriusXM: 845|845|9236|9236|Chicago White Sox
Sonos SiriusXM: 846|846|9237|9237|Cincinnati Reds
Sonos SiriusXM: 847|847|9238|9238|Cleveland Indians
Sonos SiriusXM: 848|848|9239|9239|Colorado Rockies
Sonos SiriusXM: 849|849|9240|9240|Detroit Tigers
Sonos SiriusXM: 850|850|9241|9241|Houston Astros
Sonos SiriusXM: 851|851|9242|9242|Kansas City Royals
Sonos SiriusXM: 852|852|9243|9243|Los Angeles Angels
Sonos SiriusXM: 853|853|9244|9244|Los Angeles Dodgers
Sonos SiriusXM: 854|854|9245|9245|Miami Marlins
Sonos SiriusXM: 855|855|9246|9246|Milwaukee Brewers
Sonos SiriusXM: 856|856|9247|9247|Minnesota Twins
Sonos SiriusXM: 857|857|9248|9248|New York Mets
Sonos SiriusXM: 858|858|9249|9249|New York Yankees
Sonos SiriusXM: 859|859|9250|9250|Oakland Athletics
Sonos SiriusXM: 860|860|9251|9251|Philadelphia Phillies
Sonos SiriusXM: 861|861|9252|9252|Pittsburgh Pirates
Sonos SiriusXM: 862|862|9253|9253|San Diego Padres
Sonos SiriusXM: 863|863|9254|9254|San Francisco Giants
Sonos SiriusXM: 864|864|9255|9255|Seattle Mariners
Sonos SiriusXM: 865|865|9256|9256|St. Louis Cardinals
Sonos SiriusXM: 866|866|9257|9257|Tampa Bay Rays
Sonos SiriusXM: 867|867|9258|9258|Texas Rangers
Sonos SiriusXM: 868|868|9259|9259|Toronto Blue Jays
Sonos SiriusXM: 869|869|9260|9260|Washington Nationals
Sonos SiriusXM: 880|880|9266|9266|Atlanta Hawks
Sonos SiriusXM: 881|881|9268|9268|Boston Celtics
Sonos SiriusXM: 882|882|9267|9267|Brooklyn Nets
Sonos SiriusXM: 883|883|9269|9269|Charlotte Hornets
Sonos SiriusXM: 884|884|9270|9270|Chicago Bulls
Sonos SiriusXM: 885|885|9271|9271|Cleveland Cavaliers
Sonos SiriusXM: 886|886|9272|9272|Dallas Mavericks
Sonos SiriusXM: 887|887|9273|9273|Denver Nuggets
Sonos SiriusXM: 888|888|9274|9274|Detroit Pistons
Sonos SiriusXM: 889|889|9275|9275|Golden State Warriors
Sonos SiriusXM: 890|890|9276|9276|Houston Rockets
Sonos SiriusXM: 891|891|9277|9277|Indiana Pacers
Sonos SiriusXM: 892|892|9278|9278|Los Angeles Clippers
Sonos SiriusXM: 893|893|9279|9279|Los Angeles Lakers
Sonos SiriusXM: 894|894|9280|9280|Memphis Grizzlies
Sonos SiriusXM: 895|895|9281|9281|Miami Heat
Sonos SiriusXM: 896|896|9282|9282|Milwaukee Bucks
Sonos SiriusXM: 897|897|9283|9283|Minnesota Timberwolves
Sonos SiriusXM: 898|898|9284|9284|New Orleans Pelicans
Sonos SiriusXM: 899|899|9285|9285|New York Knicks
Sonos SiriusXM: 900|900|9286|9286|Oklahoma City Thunder
Sonos SiriusXM: 901|901|9287|9287|Orlando Magic
Sonos SiriusXM: 902|902|9288|9288|Philadelphia 76ers
Sonos SiriusXM: 903|903|9289|9289|Phoenix Suns
Sonos SiriusXM: 904|904|9290|9290|Portland Trail Blazers
Sonos SiriusXM: 905|905|9292|9292|Sacramento Kings
Sonos SiriusXM: 906|906|9291|9291|San Antonio Spurs
Sonos SiriusXM: 907|907|9293|9293|Toronto Raptors
Sonos SiriusXM: 908|908|9294|9294|Utah Jazz
Sonos SiriusXM: 909|909|9295|9295|Washington Wizards
Sonos SiriusXM: 920|920|9296|9296|NHL-ANA
Sonos SiriusXM: 921|921|9394|9394|NHL-ARI
Sonos SiriusXM: 922|922|9297|9297|NHL-BOS
Sonos SiriusXM: 923|923|9298|9298|NHL-BUF
Sonos SiriusXM: 924|924|9299|9299|NHL-CAR
Sonos SiriusXM: 925|925|9300|9300|NHL-CBJ
Sonos SiriusXM: 926|926|9301|9301|NHL-CGY
Sonos SiriusXM: 927|927|9302|9302|NHL-CHI
Sonos SiriusXM: 928|928|9303|9303|NHL-COL
Sonos SiriusXM: 929|929|9304|9304|NHL-DAL
Sonos SiriusXM: 930|930|9305|9305|NHL-DET
Sonos SiriusXM: 931|931|9306|9306|NHL-EDM
Sonos SiriusXM: 932|932|9307|9307|NHL-FLA
Sonos SiriusXM: 933|933|9308|9308|NHL-LA
Sonos SiriusXM: 934|934|9309|9309|NHL-MIN
Sonos SiriusXM: 935|935|9310|9310|NHL-MON
Sonos SiriusXM: 936|936|9311|9311|NHL-NJ
Sonos SiriusXM: 937|937|9312|9312|NHL-NSH
Sonos SiriusXM: 938|938|9313|9313|NHL-NYI
Sonos SiriusXM: 939|939|9314|9314|NHL-NYR
Sonos SiriusXM: 940|940|9315|9315|NHL-OTT
Sonos SiriusXM: 941|941|9316|9316|NHL-PHI
Sonos SiriusXM: 942|942|9318|9318|NHL-PIT
Sonos SiriusXM: 943|943|9319|9319|NHL-SJ
Sonos SiriusXM: 944|944|9320|9320|NHL-STL
Sonos SiriusXM: 945|945|9321|9321|NHL-TB
Sonos SiriusXM: 946|946|9322|9322|NHL-TOR
Sonos SiriusXM: 947|947|9323|9323|NHL-VAN
Sonos SiriusXM: 948|948|9324|9324|NHL-WAS
Sonos SiriusXM: 949|949|9325|9325|NHL-WPG
Sonos SiriusXM: 960|960|9220|9220|Sports 960
Sonos SiriusXM: 961|961|9221|9221|Sports 961
Sonos SiriusXM: 962|962|9222|9222|Sports 962
Sonos SiriusXM: 963|963|9223|9223|Sports 963
Sonos SiriusXM: 964|964|9224|9224|Sports 964
Sonos SiriusXM: 965|965|9225|9225|Sports 965
Sonos SiriusXM: 966|966|9226|9226|Sports 966
Sonos SiriusXM: 967|967|9227|9227|Sports 967
Sonos SiriusXM: 968|968|9228|9228|Sports 968
Sonos SiriusXM: 969|969|9229|9229|Sports 969
Sonos SiriusXM: 100|100|howardstern100|howardstern100|Howard 100
Sonos SiriusXM: 101|101|howardstern101|howardstern101|Howard 101
Sonos SiriusXM: 112|112|cnbc|cnbc|CNBC
Sonos SiriusXM: 113|113|9369|9369|FOX Business
Sonos SiriusXM: 114|114|foxnewschannel|foxnewschannel|FOX News Channel
Sonos SiriusXM: 115|115|cnn|cnn|CNN
Sonos SiriusXM: 116|116|cnnheadlinenews|cnnheadlinenews|HLN
Sonos SiriusXM: 117|117|8367|8367|MSNBC
Sonos SiriusXM: 118|118|bbcworld|bbcworld|BBC World Service
Sonos SiriusXM: 119|119|bloombergradio|bloombergradio|Bloomberg Radio
Sonos SiriusXM: 120|120|8237|8237|C-SPAN Radio
Sonos SiriusXM: 121|121|8183|8183|SiriusXM Public Radio
Sonos SiriusXM: 122|122|nprnow|nprnow|NPR Now
Sonos SiriusXM: 123|123|8239|8239|PRX Public Radio
Sonos SiriusXM: 124|124|indietalk|indietalk|POTUS Politics
Sonos SiriusXM: 125|125|siriuspatriot|siriuspatriot|SiriusXM Patriot
Sonos SiriusXM: 126|126|8238|8238|SiriusXM Urban View
Sonos SiriusXM: 127|127|siriusleft|siriusleft|SiriusXM Progress
Sonos SiriusXM: 450|450|9370|9370|FOX News Talk
Sonos SiriusXM: 796|796|9355|9355|TheBlaze Radio Network
Sonos SiriusXM: 797|797|8235|8235|SiriusXM Patriot Plus
Sonos SiriusXM: 798|798|9137|9137|SiriusXM Progress Plus
Sonos SiriusXM: 77|77|9366|9366|KIDZ BOP Radio
Sonos SiriusXM: 78|78|8216|8216|Kids Place Live
Sonos SiriusXM: 79|79|radiodisney|radiodisney|Radio Disney
Sonos SiriusXM: 80|80|9367|9367|RURAL Radio
Sonos SiriusXM: 81|81|doctorradio|doctorradio|Doctor Radio
Sonos SiriusXM: 82|82|radioclassics|radioclassics|RadioClassics
Sonos SiriusXM: 95|95|9356|9356|Comedy Central Radio
Sonos SiriusXM: 96|96|thefoxxhole|thefoxxhole|The Foxxhole
Sonos SiriusXM: 97|97|bluecollarcomedy|bluecollarcomedy|Blue Collar Radio
Sonos SiriusXM: 98|98|laughbreak|laughbreak|Laugh USA
Sonos SiriusXM: 99|99|rawdog|rawdog|Raw Dog Comedy Hits
Sonos SiriusXM: 400|400|9181|9181|Carlin's Corner
Sonos SiriusXM: 403|403|9182|9182|Just For Laughs Radio
Sonos SiriusXM: 102|102|maximradio|maximradio|Indie
Sonos SiriusXM: 206|103|8184|8184|SiriusXM Talk
Sonos SiriusXM: 105|105|9351|9351|EW Radio
Sonos SiriusXM: 106|106|siriusoutq|siriusoutq|OutQ Gay Radio
Sonos SiriusXM: 204|107|8182|8182|Oprah Radio
Sonos SiriusXM: 109|109|siriusstars|siriusstars|SiriusXM Stars
Sonos SiriusXM: 111|111|9359|9359|Business Radio
Sonos SiriusXM: 128|128|9392|9392|Joel Osteen Radio
Sonos SiriusXM: 146|146|roaddogtrucking|roaddogtrucking|Road Dog Trucking
Sonos SiriusXM: 790|790|9230|9230|Limited Engagements 5
Sonos SiriusXM: 791|791|8369|8369|Vivid Radio
Sonos SiriusXM: 794|794|0000|0000|SiriusXM Preview
Sonos SiriusXM: 129|129|thecatholicchannel|thecatholicchannel|The Catholic Channel
Sonos SiriusXM: 130|130|ewtnglobal|ewtnglobal|EWTN Catholic Radio
Sonos SiriusXM: 131|131|8307|8307|Family Talk
Sonos SiriusXM: 147|147|9396|9396|SiriusXM 147
Sonos SiriusXM: 148|148|9186|9186|Águila
Sonos SiriusXM: 149|149|9184|9184|La Mezcla
Sonos SiriusXM: 150|150|rumbon|rumbon|Caliente
Sonos SiriusXM: 152|152|9135|9135|En Vivo
Sonos SiriusXM: 153|153|9134|9134|Cristina Radio
Sonos SiriusXM: 154|154|9133|9133|Inspírate
Sonos SiriusXM: 155|155|cnnespanol|cnnespanol|CNN en Español
Sonos SiriusXM: 156|156|9199|9199|RadioFórmula México
Sonos SiriusXM: 157|157|espndeportes|espndeportes|ESPN Deportes
Sonos SiriusXM: 158|158|9357|9357|beIN SPORTS en Español
Sonos SiriusXM: 500|500|8225|8225|Viva
Sonos SiriusXM: 506|506|9185|9185|Flow Nación
Sonos SiriusXM: 520|520|9187|9187|Latidos
Sonos SiriusXM: 523|523|9188|9188|Caricia
Sonos SiriusXM: 530|530|9189|9189|Luna
Sonos SiriusXM: 533|533|9190|9190|Rumbón
Sonos SiriusXM: 540|540|9191|9191|La Kueva
Sonos SiriusXM: 563|563|9264|9264|Entretenimiento SiriusXM
Sonos SiriusXM: 970|970|9207|9207|Deportes en Vivo 970
Sonos SiriusXM: 971|971|9208|9208|Deportes en Vivo 971
Sonos SiriusXM: 972|972|9209|9209|Deportes en Vivo 972
Sonos SiriusXM: 973|973|9210|9210|Deportes en Vivo 973
Sonos SiriusXM: 974|974|9211|9211|Deportes en Vivo 974
Sonos SiriusXM: 975|975|9212|9212|Deportes en Vivo 975
Sonos SiriusXM: 976|976|9213|9213|Deportes en Vivo 976
Sonos SiriusXM: 977|977|9214|9214|Deportes en Vivo 977
Sonos SiriusXM: 978|978|9215|9215|Deportes en Vivo 978
Sonos SiriusXM: 979|979|9216|9216|Deportes en Vivo 979
Sonos SiriusXM: 980|980|9261|9261|Deportes en Vivo 980
Sonos SiriusXM: 981|981|9262|9262|Deportes en Vivo 981
Sonos SiriusXM: 982|982|9326|9326|Deportes en Vivo 982
Sonos SiriusXM: 983|983|9327|9327|Deportes en Vivo 983
Sonos SiriusXM: 984|984|9328|9328|Deportes en Vivo 984
Sonos SiriusXM: 985|985|9329|9329|Deportes en Vivo 985
Sonos SiriusXM: 986|986|9330|9330|Deportes en Vivo 986
Sonos SiriusXM: 987|987|9331|9331|Deportes en Vivo 987
Sonos SiriusXM: 988|988|9332|9332|Deportes en Vivo 988
Sonos SiriusXM: 989|989|9333|9333|Deportes en Vivo 989
Sonos SiriusXM: 990|990|9334|9334|Deportes en Vivo 990
Sonos SiriusXM: 991|991|9335|9335|Deportes en Vivo 991
Sonos SiriusXM: 992|992|9336|9336|Deportes en Vivo 992
Sonos SiriusXM: 993|993|9337|9337|Deportes en Vivo 993
Sonos SiriusXM: 994|994|9338|9338|Deportes en Vivo 994
Sonos SiriusXM: 11|11|8241|8241|KIIS-Los Angeles
Sonos SiriusXM: 12|12|8242|8242|Z100/NY
Sonos SiriusXM: 141|141|9129|9129|HUR Voices
Sonos SiriusXM: 142|142|9130|9130|HBCU
Sonos SiriusXM: 143|143|9131|9131|BYU Radio
Sonos SiriusXM: 144|144|9132|9132|Korea Today
Sonos SiriusXM: 799|799|9265|9265|SiriusXM On Demand
Sonos Debug ZonePlayer: S1GR, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.35
Sonos Debug Updating Device: S1GR, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: S1GR, State: ZP_ART, Value:
Sonos Debug Updating Device: S1GR, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: S1GR, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: S1GR, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: S1GR, State: ZP_DURATION, Value:
Sonos Debug Updating Device: S1GR, State: ZP_INFO, Value:
Sonos Debug Updating Device: S1GR, State: ZP_MUTE, Value:
Sonos Debug Updating Device: S1GR, State: ZP_STATE, Value:
Sonos Debug Updating Device: S1GR, State: ZP_STATION, Value:
Sonos Debug Updating Device: S1GR, State: ZP_TRACK, Value:
Sonos Debug Updating Device: S1GR, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: S1GR, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: S1GR, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: S1GR, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: S1GR, State: ZP_AIName, Value:
Sonos Debug Updating Device: S1GR, State: ZP_AIPath, Value:
Sonos Debug Updating Device: S1GR, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: S1GR, State: ZP_NART, Value:
Sonos Debug Updating Device: S1GR, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: S1GR, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: S1GR, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: S1GR, State: Q_Repeat, Value: off
Sonos Debug Updating Device: S1GR, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: S1GR, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: S1GR, State: GROUP_Name, Value:
Sonos Debug Updating Device: S1GR, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: S1GR, State: ZoneGroupID, Value:
Sonos Debug Updating Device: S1GR, State: ZoneGroupName, Value:
Sonos Debug Updating Device: S1GR, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: S1GR, State: ZP_ZoneName, Value: GR
Sonos Debug Updating Device: S1GR, State: ZP_LocalUID, Value: RINCON_000E585DF31401400
Sonos Adding ZonePlayer: RINCON_000E585DF31401400
Sonos Debug ZonePlayer: S2BR, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.36
Sonos Debug Updating Device: S2BR, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: S2BR, State: ZP_ART, Value:
Sonos Debug Updating Device: S2BR, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: S2BR, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: S2BR, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: S2BR, State: ZP_DURATION, Value:
Sonos Debug Updating Device: S2BR, State: ZP_INFO, Value:
Sonos Debug Updating Device: S2BR, State: ZP_MUTE, Value:
Sonos Debug Updating Device: S2BR, State: ZP_STATE, Value:
Sonos Debug Updating Device: S2BR, State: ZP_STATION, Value:
Sonos Debug Updating Device: S2BR, State: ZP_TRACK, Value:
Sonos Debug Updating Device: S2BR, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: S2BR, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: S2BR, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: S2BR, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: S2BR, State: ZP_AIName, Value:
Sonos Debug Updating Device: S2BR, State: ZP_AIPath, Value:
Sonos Debug Updating Device: S2BR, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: S2BR, State: ZP_NART, Value:
Sonos Debug Updating Device: S2BR, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: S2BR, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: S2BR, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: S2BR, State: Q_Repeat, Value: off
Sonos Debug Updating Device: S2BR, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: S2BR, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: S2BR, State: GROUP_Name, Value:
Sonos Debug Updating Device: S2BR, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: S2BR, State: ZoneGroupID, Value:
Sonos Debug Updating Device: S2BR, State: ZoneGroupName, Value:
Sonos Debug Updating Device: S2BR, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: S2BR, State: ZP_ZoneName, Value: BR
Sonos Debug Updating Device: S2BR, State: ZP_LocalUID, Value: RINCON_000E588D1EC601400
Sonos Adding ZonePlayer: RINCON_000E588D1EC601400
Sonos Debug ZonePlayer: S3BA, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.40
Sonos Debug Updating Device: S3BA, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: S3BA, State: ZP_ART, Value:
Sonos Debug Updating Device: S3BA, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: S3BA, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: S3BA, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: S3BA, State: ZP_DURATION, Value:
Sonos Debug Updating Device: S3BA, State: ZP_INFO, Value:
Sonos Debug Updating Device: S3BA, State: ZP_MUTE, Value:
Sonos Debug Updating Device: S3BA, State: ZP_STATE, Value:
Sonos Debug Updating Device: S3BA, State: ZP_STATION, Value:
Sonos Debug Updating Device: S3BA, State: ZP_TRACK, Value:
Sonos Debug Updating Device: S3BA, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: S3BA, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: S3BA, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: S3BA, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: S3BA, State: ZP_AIName, Value:
Sonos Debug Updating Device: S3BA, State: ZP_AIPath, Value:
Sonos Debug Updating Device: S3BA, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: S3BA, State: ZP_NART, Value:
Sonos Debug Updating Device: S3BA, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: S3BA, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: S3BA, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: S3BA, State: Q_Repeat, Value: off
Sonos Debug Updating Device: S3BA, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: S3BA, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: S3BA, State: GROUP_Name, Value:
Sonos Debug Updating Device: S3BA, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: S3BA, State: ZoneGroupID, Value:
Sonos Debug Updating Device: S3BA, State: ZoneGroupName, Value:
Sonos Debug Updating Device: S3BA, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: S3BA, State: ZP_ZoneName, Value: bath
Sonos Debug Updating Device: S3BA, State: ZP_LocalUID, Value: RINCON_000E58C9806C01400
Sonos Adding ZonePlayer: RINCON_000E58C9806C01400
Sonos Debug ZonePlayer: S4GAR, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.41
Sonos Debug Updating Device: S4GAR, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_ART, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_DURATION, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_INFO, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_MUTE, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_STATE, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_STATION, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_TRACK, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_AIName, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_AIPath, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_NART, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: S4GAR, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: S4GAR, State: Q_Repeat, Value: off
Sonos Debug Updating Device: S4GAR, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: S4GAR, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: S4GAR, State: GROUP_Name, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: S4GAR, State: ZoneGroupID, Value:
Sonos Debug Updating Device: S4GAR, State: ZoneGroupName, Value:
Sonos Debug Updating Device: S4GAR, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: S4GAR, State: ZP_ZoneName, Value: Garage
Sonos Debug Updating Device: S4GAR, State: ZP_LocalUID, Value: RINCON_B8E93780254E01400
Sonos Adding ZonePlayer: RINCON_B8E93780254E01400
Sonos Subscribing on port: 9999
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 194, in runConcurrentThread
File "<string>", line 1, in bind
<class 'socket.error'>: (48, 'Address already in use')
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Seeker wrote:nlagaros wrote:Would you mind putting the plugin in debug mode and posting the full output from startup. Historically, this issue has been related to DNS configuration issues. I also posted an updated plugin on my wiki if you care to download.Seeker wrote:they're all set correctly. 2 play:1s, 2 play:5s.
installed 8.3. actions seem to work, i can play playlists/radio fine, just no display of device status. thanks for your help.
here's the startup:
- Code: Select all
here's the devices in indigo with no playing state displayed:
nlagaros wrote:I'm not sure why the publishing socket is stuck. Assuming you have no other processes using port 9999, please restart the Indigo server. This should be a one time thing.
Seeker wrote:nlagaros wrote:I'm not sure why the publishing socket is stuck. Assuming you have no other processes using port 9999, please restart the Indigo server. This should be a one time thing.
You're referencing this?
- Code: Select all
No idea. Any ideas on where to look? a restart of indigo server still gives this error.
This mac mini does nothing significant other than run indigo, so I have not installed much o n it.
Thanks for your help. i'd love to get this figured out.
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 162, in actionZP_setStandalones
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 580, in actionDirect
<type 'exceptions.KeyError'>: key not found in database
Sonos Error SOAPSend warning: waiting for command execution [192.168.1.35:0]
Seeker wrote:Mavericks 10.9.5
Indigo 6.0.18
I changed the port in the sonos plugin to 9998, and it seems to work! Wonder why that worked?
I now (still?) see this in the log.
- Code: Select all
I get this after I run a 'play radio' action that groups a couple of zones, sets volume, and starts a sirius station.
nlagaros wrote:Maybe a rogue process stuck on port 9999 from a prior version of the plugin. That is my guess. You can clean up of course by rebooting your Mac. Sorry about that.
As far as this error - you have uncovered a small bug in the plugin that I can address later today. Thanks for your patience.Seeker wrote:Mavericks 10.9.5
Indigo 6.0.18
- Code: Select all
richo wrote:Nick, would it be possible to add an option in Group Anouncement to choose a variable value instead of a simple text. This way it would be possible to initiate dynamic anouncements just by changing the value of a variable that have anouncement message stored/changed.
Sent using Tapatalk
