Sonos - The Beginning
Fri Nov 21, 2014 1:00 pm
eme jota ce offline
Re: Sonos - The Beginning
Hi Nick,
Just upgraded to v0.8.0
Not loading. Here is the log. I have 8 zones, and have added all of them (in prior plugin versions) into Indigo. Each has a static IP, assigned by the router, based on MAC address of the Sonos unit.
Reloading plugin "Sonos 0.8.0"
Starting plugin "Sonos 0.8.0" (pid 63393)
Sonos Subscribing on port: 9999
Sonos Sonos Ignition... [7]
Sonos Sonos Ignition... [6]
Sonos Sonos Ignition... [5]
Sonos Sonos Ignition... [4]
Sonos Sonos Ignition... [3]
Sonos Sonos Ignition... [2]
Sonos Sonos Ignition... [1]
Sonos Error Error in plugin execution InitializeMain:
File "plugin.py", line 19, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 122, in __init__
File "<string>", line 1, in bind
<class 'socket.error'>: (48, 'Address already in use')
Fri Nov 21, 2014 2:05 pm
nlagaros offline
restart the plugin after 1 minute and you should be good to go. i have to fix a socket close/timeout issue. thx.
Sat Nov 22, 2014 7:34 pm
eme jota ce offline
Restarted the plugin, but still not loading:
Stopping plugin "Sonos 0.8.0" (pid 41442)
Stopped plugin "Sonos 0.8.0"
Error plugin "Sonos 0.8.0" (pid 41442) failed to start -- restarting in 20 seconds
Other suggestions?
Sat Nov 22, 2014 8:30 pm
chobo offline
Hi Nick - Experiencing the same error here with 0.8.0 and 10 zones. Restarting after a minute had no effect. Thanks as always for the great plugin and your help!
Sun Nov 23, 2014 8:17 am
nlagaros offline
I posted v0.8.1 to the wiki. It addresses the startup issues. Thanks to all for downloading the newest version.
Sun Nov 23, 2014 1:03 pm
chobo offline
Hi again, Nick -
Downloaded and installed v0.8.1 a few minutes ago and I'm seeing what seems to be the same error:
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 127, in __init__
This occurs even after stopping the Indigo server and restarting the machine. Any thoughts?
Sun Nov 23, 2014 2:20 pm
wideglidejrp offline
I also installed 0.81 and getting an error....
Nov 23, 2014, 9:33:52 AM
Action Group Sonos Play 1 Black Volume Up
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 117, in actionVolumeUp
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 638, in actionDirect
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
John R Patrick
Author of
Home Attitude
Sun Nov 23, 2014 4:43 pm
eme jota ce offline
Thanks for addressing it, Nick.
Installed 0.8.1, but still seeing error:
EDIT: Restarted the Indigo server, and the plugin is working. I have a few keypad buttons that trigger SONOS actions. Still seeing and error (but the trigger is doing what it's supposed to be doing)
Sonos Error SOAPSend warning: waiting for command execution [10.0.1.105:0]
Mon Nov 24, 2014 3:19 am
haavarda offline
I am also seeing a error when I try to start the plugin:
24 Nov 2014 10:09:30
Reloading plugin "Sonos 0.8.1"
Starting plugin "Sonos 0.8.1" (pid 3487)
Stopping plugin "Sonos 0.8.1" (pid 3487)
Stopped plugin "Sonos 0.8.1"
Error plugin "Sonos 0.8.1" (pid 3487) failed to start -- restarting in 20 seconds
Just let me know if there is anything I can do to help fault finding.
regards
Håvard
Mon Nov 24, 2014 7:09 am
nlagaros offline
Looks like I have a python version issue. Been working perfectly on Yosemite with Python 2.6. In going to set up a treat system to work on this. Stay tuned...
Mon Nov 24, 2014 11:04 am
haavarda offline
Hi again.
I am using Yosemite on my Indigo server.
regards
Håvard
Tue Nov 25, 2014 1:23 pm
pereza1 offline
Got this error this morning. Still happens after Indigo server is restarted. Reverted back to 0.5.11
Running on Snow Leopard, if that makes a difference...
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 58, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 189, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 291, in initZones
<type 'exceptions.KeyError'>: key model not found in dict
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tue Nov 25, 2014 2:09 pm
nlagaros offline
I added an additional config item for each ZonePlayer device. You need to click on the properties for each and select your ZonePlayer model.
Tue Nov 25, 2014 3:38 pm
eme jota ce offline
Nick,
For an older ZP 100 Sonos (which has an integrated amp), should the "Model:" in the "Configure Sonos Zone Player" dialogue box be identified as "CONNECT: AMP" or as "Zone Player"?
In the Sonos desktop application, Sonos -> About My Sonos System, identifies my newer Sonos unit as "CONNECT:AMP" as shown in your list, but older units are identified as "ZP100" or "ZP80"
(See attachments)
mjc
Screen Shot 2014-11-25 at 4.35.52 PM.png (106.61 KiB) Viewed 3645 times
Screen Shot 2014-11-25 at 4.28.57 PM.png (109.45 KiB) Viewed 3645 times
Wed Nov 26, 2014 1:41 pm
pereza1 offline
Thanks! That did it! Also, v8 is running perfectly on my Indigo6/Snow Leopard system!! Woohoo!! :)
Page 25 of 37 1 ... 22, 23, 24, 25, 26, 27, 28 ... 37
