Sonos - The Beginning
Mon Dec 30, 2013 2:24 pm
wideglidejrp offline
Re: Sonos - The Beginning
Nick, thanks for the great support! I am out of town now and will return on Thursday to try these latest suggestions. Thanks again and Happy New Year!
John R Patrick
Author of
Home Attitude
Fri Jan 03, 2014 11:40 am
I installed the new version. Here is what I got....
Sonos Debug Method: runConcurrentThread
Sonos Debug Running Concurrent Thread
Reloading plugin "Sonos 0.6.14"
Stopping plugin "Sonos 0.6.14" (pid 21771)
Sonos Debug Method: stopConcurrentThread
Sonos Debug Stopping device: Sonos - Living Room
Sonos Debug Stopping device: Sonos - Master BR
Sonos Debug Stopping device: Sonos - Playbar
Sonos Debug Method: shutdown
Stopped plugin "Sonos 0.6.14"
Starting plugin "Sonos 0.6.14" (pid 21776)
Sonos OSTYPE: 13
Sonos Subscribing on port: 9999
Started plugin "Sonos 0.6.14"
Sonos Your plugin version, v0.6.14, is current.
Sonos Debug Getting Plugin Configuration Settings
Sonos Debug Reference ZP IP: 192.168.1.62
Sonos Debug Publish/Subscribe Port: 9999
Sonos Debug Pandora: True
Sonos Debug Pandora User ID: john353
Sonos Debug Pandora Email Address: john@patrickweb.com
Sonos Debug SiriusXM: True
Sonos Saved Plugin Configuration
Sonos Debug Loading Playlists...
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 126, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1132, in getPlaylistsDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 240, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 860, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 732, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 699, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 683, in connect
<class 'socket.timeout'>: timed out
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Jan 3, 2014, 12:39:00 PM
Action Group Sonos - LR - Mute
Sonos Debug Sonos Action: Mute
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 108, in actionMute
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 503, in actionDirect
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
John R Patrick
Author of
Home Attitude
Mon Jan 06, 2014 8:25 am
eme jota ce offline
eme jota ce wrote:
nlagaros wrote:
Appreciate the feedback. Can you give me some detail on your configuration? How many ZonePlayers do you have configured in Indigo? I see what is happening, but am surprised that an error is being thrown. I'll have to add some debugging entries and/or rework the logic.
Seven zones are configured in Indigo. Those seven are every component of our Sonos system, except for two bridges. They are ZP100's, ZP80's, ZP90's and Connect Amps. Each receives a static IP from an ASUS router ranging from 10.0.1.102 to ...108. I double checked the IP's listed in Indigo. They are correct in Indigo and show the same IP's listed in Sonos and the router.
Hi Nick,
Upgraded to v0.6.14 and also ran an ethernet cable to the sonos zone player that was farthest away / had the weakest connection. Seeing the same error message in the Indigo log:
File "plugin.py", line 138, in actionZP_RT_FavStation
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 683, in actionDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 243, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 1199, in getreply
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 928, in getresponse
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 385, in begin
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 343, in _read_status
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/socket.py", line 372, in readline
Does it matter which zone is listed as the Reference Player in the plugin setup?
Mon Jan 06, 2014 8:56 am
My latest test produced the following....
Jan 6, 2014, 9:54:33 AM
John R Patrick
Author of
Home Attitude
Sat Jan 11, 2014 5:41 am
nlagaros offline
I just posted v0.6.15. This may help with the problem we are having here. Thanks.
eme jota ce wrote:
Hi Nick,
Sat Jan 11, 2014 5:42 am
nlagaros offline
And to answer your question, it does not matter which ZonePlayer is the reference as long as you do not use the Bridge ip address.
eme jota ce wrote:
Hi Nick,
Sat Jan 11, 2014 5:44 am
nlagaros offline
I just posted an update. I don't think it will help, but think it is worth installing. Are your ZonePlayer states updating? Is it just the actions that are not working?
Sat Jan 11, 2014 9:35 pm
Hello Nick. I am up and running again now. I changed the reference zone player and that did the trick. What does zone reference player mean? Does it matter which ZP you select? Seems some commands apply to only a specific ZP and other commands apply to all; for example, Sonos Stop. Right? One other question: Is there a way to make the Sleep function be 5 minutes instead of the current minimum of 15 minutes? Thanks!
John R Patrick
Author of
Home Attitude
Sun Jan 12, 2014 7:37 am
nlagaros offline
I'm glad you got it working. The reference ZonePlayer can be any ZonePlayer in your system, but not a bridge. It is used to retrieve what is common across all systems like playlists, Pandora stations and RadioTime favorites. If you have ZonePlayers grouped, commands will be applied across all in the group.
As far as the sleep timer goes, I will add a 5 minute option and make it available in the next release.
Sun Mar 02, 2014 4:11 pm
Rrich1125 offline
It appears that the link does not work https://vulture.lagaros.com/wiki/pages/ ... lugin.html
I receive an error everytime I try to access it. Is there an updated link?
Sun Mar 02, 2014 4:21 pm
Rrich1125 offline
I upgraded to indigo 6.0.10. Before I upgraded, the sonos plugin worked fine. When I upgraded I started getting this error
File "plugin.py", line 53, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 89, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1087, in getPlaylistsDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 176, in SOAPSend
<class 'socket.error'>: (60, 'Operation timed out')
Thu Apr 24, 2014 11:48 am
mattggarland offline
Rrich, I am having the same issues and the same error messages. Please, someone help, I know no python what so ever!
Sun Jun 08, 2014 4:47 am
haavarda offline
There has been a long time since a update on this plugin. Has the development stopped? This is a very important plugin for many of us, so I hope someone can continue to work on it.
regards
Håvard
Sun Jun 08, 2014 6:38 am
The Future of the Sonos Plugin
I too am hopeful that the Sonos plugin will have a continued future of development and support. I am most appreciative of this outstanding plugin. It is an integral and important part of my home automation environment.
John R Patrick
Author of
Home Attitude
Mon Jun 09, 2014 8:07 pm
Indy_Larry offline
I just got my first Sonos for Fathers Day and have been working on trying to get the Sonos Plugin up and going in my HA environment as well.
Larry
Insteon, Z Wave, Hue, Sonos
Page 23 of 37 1 ... 20, 21, 22, 23, 24, 25, 26 ... 37
