Installed your latests release, but my announcement are still not working, I restarted the INDIGO server and the Mac mini already and I also changed the default ports.
Trigger LEFT Garge Door Opened Announcement Family SONOS
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 169, in actionZP_announcementMP3
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1045, in actionAnnouncement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1032, in actionStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 430, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/socket.py", line 348, in read
<class 'socket.error'>: [Errno 54] Connection reset by peer
nlagaros wrote:Would you mind trying the latest version I just posted (v0.8.9)? Thanks!
mlooss wrote:Yes, it is the same error every time.
Trigger SONOS Announcement Test
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1012, in actionAnnouncement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 999, in actionStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 408, in SOAPSend
