Starting plugin "Sonos 0.6.1" (pid 13297)
Sonos Error Error in plugin execution InitializeMain:
File "plugin.py", line 9, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 31, in <module>
File "./lib/zmq/__init__.py", line 35, in <module>
<type 'exceptions.ImportError'>: dlopen(./lib/zmq/utils/initthreads.so, 2): Library not loaded: /Users/admin/Documents/zmq/lib/libzmq.1.dylib
Referenced from: /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-1.indigoPlugin/Contents/Server Plugin/lib/zmq/utils/initthreads.so
Reason: image not found
Stopping plugin "Sonos 0.6.1" (pid 13297)
Stopped plugin "Sonos 0.6.1"
Error plugin "Sonos 0.6.1" (pid 13297) failed to start -- restarting in 20 seconds
wideglidejrp wrote:I am using v0.6.12 and am having the same problem. Image not found.
wideglidejrp wrote:No. I was not aware of such a script. I then got it from your site but not sure what to do next.
wideglidejrp wrote:I never saw the dialog you mentioned. Here is a screen shot....
wideglidejrp wrote:I was able to complete setup after running the script. My test did not work, however. Here is error message....
Dec 30, 2013, 8:00:04 AM
Action Group Sonos - LR - Mute
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 103, in actionMute
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 495, in actionDirect
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
wideglidejrp wrote:This is all I see. It is in debugging mode and I reloaded.
Sonos Debug Sonos Action: Mute
